Question about Reddy Portable Forced Air Propane Heater w/ Variable Heat Ouput
I have a reddy heater model M100D, when I turn it on it runs for about 30 seconds and then the circuit breaker trips and shuts the heater off.
  • 6,927 Answers
Check the fan motor to make sure there is no obstruction on the intake for the motor,and clean out the intake filter,and see if the fan motor spins freely by hand,if it is restricted in turning at all,the blower motor is bad,I have a pdf I can send you if you like,this will help you,it is a manual.If it will help,let me know,,by email,I can send it,,,roniecon@gmail.com
Posted on Oct 12, 2010
How to bypass the relay on a Reddy M100D
Best change the switch ,than bypass it .
Jan 03, 2017 | Reddy Heating & Cooling
Vogelzang kerosene heater will not ignite (no spark)
There is an igniter module and then the igniter electrodes (check the air gap) that produces the spark to start the fuel burning, both could be defective.
May 18, 2017 | Reddy Heater-30-55,000 BTU Variable
Heaters runs for a few minutes then shuts off.
was working fine refilled it and now it will run 5sec. and kick the breaker on it.It's an old 80's model 35,000 B.T.U. I cleand the photo eye with a cloth no change. Any solution's
Jan 29, 2010 | Reddy Heater-30-55,000 BTU Variable
Starts to run. Then pops CB in about 2 seconds. Ignition is OK. I think it momentarily lights off. REDDY HEATER made by DESA of Bowling Green, KY
Hi, when a circuit trips that quik, it indicates a dead short somewhere or even a motor drawing way to much amps for the breaker to handle. If this heater is a forced air type, try and find the wiring that controls the blower motor and disconnect it for just a few minutes to test it. You may want to do this with other control componants one at a time, just by- pass each one by unplugging or disconnecting each one and start it. If the breaker holds when you do this, you will then know which part is causing the breaker to trip. Keep me posted on your progress.
Shastalaker7
Jan 18, 2010 | Reddy R155D Utility Heater
Have a 155000 btu ready heater
It sounds like the unit is tripping the breaker because the breaker is not rated high enough to handle the heaters power usage! If its not that then it may very well be the thermostat needs replaced in unit!
Test at a friends house to see if its your system or the unit!
Dec 18, 2008 | Reddy Heater-30-55,000 BTU Variable
50K BTU Reddy Heater Trips Circuit Breaker
If the unit lights Check the photo cell this can be done with an ohm meter and good light. Should have continuity in light.
Jan 14, 2008 | Dayton E50 Heater
Reddy Portable Forced Air Propane Heater w/ Variable Heat Ouput Logo
254 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
