Question about Eureka 2961AVZ Bagless Upright Vacuum
My Eureka model 2961 does not **** up larger particles. You can see it picks up dust and dirt. Am trying to remove bottom guard plate to check belt but can't take it off.
  • 1,040 Answers
Here is a Link to one of my Tips:
www.fixya.com/support/r6311178-vacuum_brush_bar_not_spinning
This should solve the problem.
Good Luck!
Jim
Posted on Oct 12, 2010
  • Jim Parker
    Jim Parker Oct 17, 2010
    Was this helpful?
    Jim
My eureka multicyclonic vaccuum isn't spinning or picking up any dirt, what do I do?
Try open the bottom cover where the motor is located. It seems the the power belt is broken. Guides and Manuals Eureka
Apr 13, 2014 | Eureka Vacuum Cleaners; AIRSPEED One...
Broken belt i need a replacement belt for eureka altima bagless vacuum
Eureka says size U BELT... NO!! I have tried this numerous times. I finally took off a belt from an old vac. and it works !!! dirt devil size 5 belt is the way to go!!
May 08, 2010 | Eureka Altima Upright Vacuum Model 2996AVS...
Eureka bagless model 2961 partswere do i get them
It depends on the parts you are looking for. If you go to your local vacuum repair shop they might have parts for your model. If not then there are parts available on Eureka's website. If you need replacement belts for your model you can get them here:
Eureka 2961 Replacement belts
Nov 08, 2009 | Vacuums
What is the belt size for the Eureka model 2961 type bvz
The belt size for your particular model is belt
54312C
Worse case if you can't find this part at the store you can purchase directly from http://eureka.com/servlet/ListParts
Sep 14, 2009 | Eureka Altima Upright Vacuum Model 2996AVS...
What belt do I use for the Eureka Altima 2961?
Click this link and it will take you to Eureka's website. Just enter your model number and part description and it show you parts you can order for your model. There is also an owners guide you can download.
Hope this helps.
http://www.eureka.com/parts.jsp
Aug 21, 2009 | Eureka 2961AVZ Bagless Upright Vacuum
Spinning debris in cup
If the 2 stage filters inside the bin chamber have not been washed then they will need to be - they sound like they are clogged or somewhere there is dirt which is blocking up the system. Also check the side part duster to ensure that the airways are not clogged with dirt.
When you turn the machine on, have a look to see if the moving brush is actually spinning. Then switch off and remove the base plate to see if anything is clogged in the main dirt channel which is usually located on the left or right hand side - where the dirt goes in from the floor.
This model is based on an Electrolux model in the UK which can be notorious for clogging dust. Check the hoses at the bottom where they come from the main dust bin and the air ways to check no dust is stuck.
Apr 18, 2008 | Eureka Altima Upright Vacuum Model 2996AVS...
Need to get access to the belt on my Eureka model 4475
Eureka Model #4475
need to get access to the belt on my Eureka model 4475
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
There may be 2 different ways to get to the belt, I checked the Eureka website and I believe you have to remove the bottom plate and the brushroll and belt are exposed and you would hook the belt on the brushroll 1st and then use a screwdriver with a bent hook and then you can pull the belt onto the pulley, once the belt is on the pulley then you can track the belt by rolling it on the brushroll & belt pulley --- the other way is that there are 2 screws on the bottom of the of the vacuum – remove the screws and then the top cover should lift off the vacuum to expose the belt – then follow the same procedure ads listed above. Check with you local vacuum dealer in your area in the yellow pages or use the Eureka website or customer service phone number listed below:
http://www.eureka.com Customer Service Phone Number
1-800-282-2886 Hours of Operation
Monday thru Friday 8:00 am to 7:30 pm CST
Saturday and Sunday 10:00 am to 6:30 pm CST
Apr 16, 2008 | Vacuums
Smoking belt
Belt is slipping because the bearings on the beater brushes, which it turns, are jammed or full of dust.
Alternatively the belt has stretched after being overheated and needs replacing because it now slips.
Dec 22, 2007 | Eureka 2961AVZ Bagless Upright Vacuum
Eureka 2961AVZ Bagless Upright Vacuum Logo
98 people viewed this question
Top Eureka Vacuums Experts
JoeVacs
Alan Matzke
Alan Matzke
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
