Question about Garden
Was running good for about 10 minute, started losing power for about 2 minute,then engine just die out. try for awhile to start its and finally started , just die out slowly and now its ,really hard to start its. what can I do for this.would appreciates your answer. ted
  • 1,041 Answers
Here is a Link to one of my Tips:
www.fixya.com/support/r6081786-trimmer_weed_eater_only_runs_10_15
I realize it sounds too simple; but believe it!
Jim
Posted on Oct 12, 2010
  • Jim Parker
    Jim Parker Oct 17, 2010
    Was this helpful?
    Jim
My car is sputtering and dying. If I try to restart it, it will immediately go into sputtering/dying mode. If I wait a while an hour or so it will start up and drive fine.
When was the last time that the carburetor was stripped and cleaned? Also have you checked the fuel filter? Finally, the problem seems to come and go as the engine is run (and it gets hot) check that the fuel line and any electrical cables are well away from the hot engine as far as is possible.
Jun 16, 2015 | Cars & Trucks
Losing power and dying.
Yes it could be the coil or a number of other electrical components.
You would need to figure out if you have lost spark to the plugs or fuel pressure when the engine quits. It could be a relay, the fuel pump, the coil or igniter, or a long list of other things.
May 04, 2013 | 1985 Nissan Pickup
Engine dies while idling, then car won't start for a few minutes
One possibility is a blocked fuel line or filter. It basically runs out of fuel and you have to wait for it to come through slowly. The other possibility is the ignition system is losing spark as something heats up. You have to wait until it's cooled down before it runs again.
Oct 22, 2017 | 1999 Mercedes-Benz E-Class
Hello i have a 2001 honda odyssey my engine dies after awhile i drive it so what i do to to get running back again is for me to take out the fuse fuel pump from the kick panel on the driver side and it...
My 2001 Honda Odyssey would completely lose power, foot on the gas pedal and nothing there. There were no warning lights prior to the losing power. After letting the car set for a few minutes it would start and run okay. This happened intermittently over a couple of weeks until finally it didn't want to start at all. When turning the key the car sounded like it wanted to start but wouldn't. After a quick trip to the closest Honda dealership and asking a few questions we were told that it sounded like the main relay needed to be replaced. They showed us where it was located on the Honda, we bought a new one and we easily installed it ourselves. The old relay did have a slight burned smell. My Honda is working fine now and it has been over a week with no problems. I hope this helps someone else.
Aug 21, 2010 | 2001 Honda Odyssey
I have a 7 year old toro timecutter zero turning radius 16/42" mower. It starts and mows fine but after about 10 minutes of mowing it loses power and dies abruptly. After sitting for 10 or more minutes it...
could be a ignition unit (s)breaking down when it getts hot ?
could be a tank breather not working or a restriction in flow of fuel
could be a valve not opening fully or closing fully ie tight valve
fit in line ignition tester and run unit and see if spark disapears when unit gets hot if so ignition prob if not its other problems
worth a look
cheers
Jun 30, 2010 | Garden
Husqvarna 2009 Tractor Run 30 minutes, sputter, loses power, dies
hi it seems to me either a lack of compression when she is warm /hot /check tappets or a weak mixture /air leak on the inlet someware hope this is of some help merlinv12
Aug 20, 2009 | Parks Optical 13.5hp Briggs And Stratton...
Mercury Topaz loses power while driving, and stalls out
Check fuel pressure. Sounds like a bad pump or plugged fuel filter.
Mar 19, 2009 | 1989 Mercury Topaz
Alero will crank awhile before it finally starts w/ more details
May have small fuel leak or fuel pump sending unit leak down. Or fuel pump psi low.
After 30 minutes try this turn key on. do not try to start wait 10 seconds turn key off then on again 10 seconds then try & start if it starts right away fuel system is losing PSI either back through the fuel pump or a leak in line. If you can find no leaks would suggest replace fuel pump & assembly.
Another possible but rare fuel injectors may be leaking fuel over time & dropping PSI needed for start up.
Mar 08, 2009 | 2001 Oldsmobile Alero
Garden Logo
50 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
