Question about Fisher and Paykel GWL11 Top Load Washer
Will not turn on..power to wall and plugged in...circuit breaker has not popped...
  • Fisher and P... Master
  • 713 Answers
Hi just read your posting.Now the 2 reasons your machine will not turn on if you 100% have power to the machine is the drain pump is faulty or the control module is faulty.Would you like assistance to test and locate the faulty component?Please reply and I am sure I can help you rectify this problem.Looking forward to your reply.
Posted on Oct 12, 2010
My Amana PTAC PTC153B00AM has no power at all. It is wall plugged, but no lights come on on the board. It was working fine and showed no signs of going bad. Can this be a blown fuse or transformer?
Check the GFI plug where it plugs into the wall and reset it. Also, plug something else into that plug to make sure you didn't pop the circuit breaker
Aug 05, 2016 | Amana Heating & Cooling
How do I replace the door light switch?
I appreciate your post, Deborah!
From what you have described you need to replace the door light switch on your Frigidaire freezer. In order to assist you further I would need your model number. You can locate your serial tag (which lists your model number) on the inside wall of your freezer. I look forward to assisting you. -Matt
Apr 27, 2015 | Frigidaire Freezers
Fuse replacement
No fuse or rest switch. Usually a power surge will destroy the tv's circuit boards. Check wall plug or power bar to make sure the breaker did not pop.
Jul 20, 2014 | ON Technology RCA LED40C45RQ 40" 1080p...
While playing my unit we had a brief power outage. When the power supply returned the " PROTECT PUSH POWER " message comes on. Is there a button that I can push to reset my unit-LBT-X50 .
Your sound system may have a circuit breaker.
Check the rear of the sound system for a circuit breaker that has popped out, Then push it back in.
It may be labelled.
  • circuit breaker
  • protect push power
Otherwise unplug your unit from the wall and wait 5min before you plug it back in, then press the power button on the front of your system and your remote control.
I hope this helps
MobileJB
Jul 13, 2011 | Sony LBT-LX50 CD Shelf System
I have an Amana ptac hotel type thru the wall unit. The unit won't turn on - it's plugged in. The gfi button is popped out. There is power to the wall plug. Any ideas?
If you reset the GFCI button and then when you go to turn it on the button pops again, then you have a short inside the units probably in the fan motor or the compressor..
heatman101
May 14, 2011 | Amana PTH123B25AJ Heat Pump Air...
DEWALT DG6300B NO POWER OUTPUT
Hello avid.....
If there is no power to the receptacles:
1. Turn the circuit breaker switches off and disconnect all electrical loads from the generator.
2. Turn the circuit breakers on and test the GFCI's by following the procedures in this manual
on page 1 -
TO TEST A GFCI:
Start the generator. Turn the auto idle switch off. Push in the TEST button (A) on the receptacle.
The RESET button (B) will pop out. Power is now off at the receptacle.
If the RESET button does not pop out, the GFCI is not working. Do not run
generator until the problem can be corrected. To restore power to receptacle,
push the RESET button in. If the RESET button pops out during operation,
stop the generator and check the generator and equipment for defects.
3. Place the voltage selector to the 120 Volt only positions (unless you are using a tool that
requires 240 Volts).
4. Turn the idle control switch off.
5. Turn the circuit breaker(s) off and reconnect the electrical loads. Be sure that the plugs are
securely connected to the receptacles.
6. Turn the circuit breaker(s) on.
7. If there is still no power at the receptacles, take the generator to an authorized DEWALT
service center. To locate a DEWALT service center nearest to you, call 1-800-4-DEWALT
Joe
Thanks for choosing Fixya!
Nov 27, 2010 | Garden
No electrical power
You must find the reason the main breaker is popping ...
I'd start by unplugging everything and remove all breakers. Turn the main on ... does it pop? If it pops here look between the breaker panel and the end of your cord. Turn the power off - reinstall the first breaker - turn power back on. What happens ... keep doing this until the main or individual breaker pops - investigate that circuit to find your short.
If you get all breakers back in with out popping anything ... start plugging stuff back in. Something is shorting somewhere.
Let me know what you find please.
thanks
a
Oct 06, 2009 | Hilltop Rv 60 AMP CIRCUIT BREAKER CARDED
Model ;LD-14aw2 will not turn on
Before you suspect the dishwasher, check the circuit that supplies power to it.
Determine if the DW's power is provided by a cord that plugs into a wall outlet or not. If the power is supplied through a wall outlet, unplug the dishwasher and plug in something like a light or a vacuum cleaner and turn on. It it comes on, then the problem is inside the dish washer.
If the power is provided through a direct connection from the circuit breaker, go to the circuit breaker box and track down which kitchen circuit ~may~ have tripped.
If the problem is inside the DW, solving that problem is not trivial and requires some special knowledge. If you investigate on your own, be 100% certain that the power has been removed from the DW for your safety.
Good Luck
Aug 16, 2009 | LG Dishwashers
My Mitsubishi Plasma Won't Power On
it is very possible that it has died. If you can, try taking it off the wall and plugging a lamp in to make sure the outlet works, even thou you said that you have checked your circuit breakers. Sometimes the outlet can die without even setting the circuit breakers off. I would still leave the mount on the wall
Apr 05, 2009 | Televison & Video
NO POWER, POPPED CIRCUIT
Two possible causes.
First (and most likely) the circuit is being overloaded. This kitchen circuit may be shared with another appliance (like the refrigerator) which is drawing enough power when both are running to trip the breaker. A Typical kitchen circuit is 20 amp with #12 wiring. So an 1800 watt microwave might draw 13 or 14 amps while a fridge compressor kicking in can surpass 7 amps before it levels off. If this is an older home the kitchen may have a 15 amp circuit with #14 wiring. If the circuit is a 20 amp you will have to split the appliances onto separate circuits. (Under code a kitchen must have a minimum of 2 separate appliance circuits). If it is a 15 amp you might be able to split them as well or may be looking up upgrading the breaker and the wiring from 15amp #14 to 20 amp #12 (but you could still have the same problem).
The other possibility is a short or loose connection. If splitting appliances onto their own circuits doesn't fix this you would probably want an electrician to come in and check for other underlying causes which could represent a fire hazard.
Hope this helps.
Apr 01, 2008 | Whirlpool GH6177XP Microwave Oven
Fisher and Paykel GWL11 Top Load Washer Logo
24 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
marley mcelhinney
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
