Question about Haier HTE21WAAWW Top Freezer Refrigerator
Haier i have a haier frig model hte18waaww the frig part isn't working at all and the freezer is frosting over have had a defrost time put in but no help.i think it need recharging. there is no place to do that. is there a part you can get to allow you to do that
  • Haier Master
  • 5,568 Answers
In units with physically separate sections, there is a fan that circulates the cold air between the two with some provision for adjusting the airflow to balance the temperature between the two chambers.
The cooling system is normally a totally closed loop that is charged in the factory through a nipple that is then pinched and welded shut.
This nipple must be cut and resealed to recharge the system.
Posted on Jul 19, 2008
Refrigerator turns off restart a couple days later haier hnde03
the is an electronic timer for defrost mode on all frost free frig/ freezers it goes bad to find that in your frig call the manufacturer or a good repair man
Aug 24, 2014 | Haier HNDE03VS (32 cu ft) Compact...
GE refrigerator isn't cold at all
you need to have the frig defrost the passage is in the back going from the frig to the freezer so if it is frosted in the back than the air is not moving correctly
Sep 18, 2012 | GE Refrigerators
Frig has suddenly become warmer than usual. Freezer is at 20 degrees and frig at 60. Tried to vacuum coils but very dificult to reach them underneath the unit. Any other hints?
what the problem most likely is a failed part of the defrost system Do you see a bunch of frost built up on the back wall of the freezer? If you do frost build up, take off the back wall of the freezer and replace the defrost heater and defrost thermostat. A hair dryer could be used to melt the built up frost from the coil behind the back wall. Another part that will cause frost build up is the defrost control, that isn't the freezer behind the back wall but instead it is part of the main computer board on the back of the refrig. I would replace heater/defrost thermostat first though, since they are the most likely to fail parts.
I hope my answer will help you to fix your refrigerator,
Gene
Aug 05, 2011 | Whirlpool GS6NBEXR Side by Side...
Our jenair is not cold. the freezer is working, but fridge isn't and the motor keeps running.what is wrong with it?
need model # to give best help // but look for ice in freezer area it may be blocking the air flow .. and will cause long run times .. . if ice is found in ( no frost frig ) then you have a defrost problem .. mm hope this helps .. mm feed back pls ..
Jul 10, 2011 | Jenn-Air Refrigerators
I have Haier refrigerator moderl number HTQ21JAARSS the Freezer is freezing and the refrigerator is not cooling .
Thank you for contacting fixya.com.
Check the coils on the rear of the refrigerator and make sure they are clean and dust free. Also check the back wall or floor of the freezer section for frost. Check the evaporator fan to see if it is running. Check the condenser coils under the unit for blockage from dust. Check the condenser fan under the unit to see if it is running. If you have frost in the freezer there is a problem with the defrost system and the freezer will start to warm eventually as well as the fresh food section. If that is the problem you can check the defrost terminator, defrost heater/s, and the defrost timer or adaptive defrost control If used on your unit or the main control board if so equipped. Also check the freezer to ensure it isn't over loaded with food stuff, reason being air must flow freely threw out the entire refrigerator in order for the thermostat to work correctly.
Defrost the freezer by disconnecting the power to the refrigerator and letting it sit for at least 24 hours with both the doors open to allow the frost to melt completely but it will build up again in 1-2 weeks and start the warming up again.
Please get back to us if you have further query else please accept the suggestion.
Jun 01, 2011 | Haier HTQ21JAAWW Top Freezer Refrigerator
I have a model # HTS22GBMBRCC Hoypoint Refrigerator. the fan in the back runs all the time and I the fan inside the freezer is running all the time. Neather the Freezer or the frig is getting cold. I have...
Your model has no defrost timer . It works off a main control board . If there is frost on the rear panel inside the freezer , then you have a defrost problem . This would be another paragraph ( but let us know if there is frost and someone will be glad to help ) . If not any frost , then the compressor may not be running . If the compressor not running , main control board is bad Pt # WR55X10942 . You will have to pull out refrig and remove the panel covering at the bottom to check . The main control board , is behind the 8 " X 10 " panel at the top left , behind the refrig .
Sep 05, 2009 | Refrigerators
My MAYTAG FREEZER IS RUNNING ALL THE TIME AND FROSTING UP , ALL OF A SUDDEN. FRIDGE PART IS WORKING FINE. IT IS A TOP FREEZER MTB1976HE MODEL.
Sounds like your condenser is icing up and is not blowing enough cold air into the frig compartment to satisfy the thermostat.That is why the compressor with not shut off. You probably have a defrost problem due to a bad defrost heater of defrost thermostat (different from control thermostat) One solution is to shut of the frig to allow ice to melt off and restart to see if it repeats the same problem. Hope this helps
Jul 26, 2009 | Maytag MTB1976HR Top Freezer Refrigerator
Refrigerator not cold
first check your damper door from the freezer to the refrigerator compartment make sure its in the proper position. Then turn off the refrigerator for a few hours until the heavy frost melts away. turn on the refrigerator check the refrigeration cycle, is it working properly, is it going into defrost are the defrost heaters working.
Feb 21, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
How Do i have a Haier HRF-388AE, Do you know how to defrost the Freezer while leaving fridge on?
CAN'T BE DONE AS THE FRIG WORKS OFF THE FREEZER,THE FREEZER MAKES ALL THE COLD AIR FOR FOR FRIG.IF IT'S NOT FROST FREE JUST TURN THE THERMOSTAT OFF TILL FREEZER IS DEFROSTED,IF FROST FREE YOU SHOULD'NT HAVE TO DO ANYTHING,HOPE THIS HELPS-MIKE
Jun 07, 2008 | Haier Refrigerators
Frig not cooling and now freezer is frosting
Val sounds like a defrost problem..go ahead and defrost your freezer again... check your evaporator drain your fan motors let let me know and I can help you Krazytech
Mar 27, 2008 | Maytag MZD2766GES Side by Side...
Haier HTE21WAAWW Top Freezer Refrigerator Logo
242 people viewed this question
Top Haier Refrigerators Experts
John Tripp
John Tripp
doggzzz
Level 1 Expert
Vernon Taylor
Are you a Haier Refrigerator Expert? Answer questions, earn points and help others
