Question about Onkyo TX-SR605 Receiver
Why does my tuner shut off when the volume is turned up to 40?
Does it turn off and then back on repeatedly at higher volumes? if you back the bass off will it allow you to turn it higher? if so i would think your impedance is off causing the amp to overheat or the power requirements for your speakers are way higher than your amp can produce
Posted on Oct 12, 2010
Hii I have sony shake 6D system and whenever I turn the volume up it reaches upto 40 and shows the error of 'protect E01' while the maximum volume is 50. Please help
Most likely, your unit is shutting down due to overheating. You cannot run an amp at that kind of volume very long. It is shutting down to protect itself. Try running the amp at 1/3 your normal level. Most likely, it will not shut down.
Aug 05, 2015 | Sony Audio Players & Recorders
User guide for a sanyo DP40142
I assume you don't have the TV muted, right? Otherwise you may have a sound processing issue in the tuner.
Jun 22, 2014 | Sanyo LCD-40E40F 40 inch Multi System LCD...
No volume from turntable, even with volume turned to max, are ther internal fuses ?
You don't state which model the turntable is. Without this we are working blind. If the turntable has a built in amp then that will have failed. A blown fuse would shut down everything. If it has no built in amp and you have it connected to a separate amp, then you have either connected it to the wrong socket - it needs a phono socket - or if the amp doesn't have one you need a magnetic cartridge preamp.
Apr 12, 2013 | Audio Players & Recorders
What's your problem?Kenwood kac-6295 shuts off then turns back on at high volumes
You got a (Problem) I have never heard of a amp doing that, In the 40 pus years, That i was a certified electronc technician, But like they stay you learn something new everry day,
Nov 06, 2012 | Car Audio & Video
I have a technics ST-X933L tuner as part of a separates system and the volume on the amplifier has to be turned up to almost full volume to be heard. All other inputs are playing at the expected volume for...
You can answer the question by jacking the tuner's outputs into any other Line Level input on your amp/receiver. If it's still low, the tuner is at fault.
BTW: NEVER use full volume as a test unless you intend to blow up your speakers.
Mar 05, 2011 | Audio Players & Recorders
The NEC 4010 i have comes on backlight lights up no information shows on the screen then it shuts off.any idea whats going on here.
Yes,Ur Main Tuner board is defective,it shorted not letting the incomming signal go through the Tuner board,that why u getting a blank baclklight on the LCD screen.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish Tuner board for the replacement.
May 04, 2010 | NEC MultiSync LCD4010 40 in. Television
Sound quality has diminished after power outage
Tries unplug,replug an hour later,let the tv reset itself back to factory setting.After,turn on the tv,go to the menu,go to sound on ur menu go down to reset the sound.The functions should go back to normal,not than.Ur tv Tuner signal board have a short,in the power outage occurance.
Apr 14, 2010 | LG RZ-37LZ30 37 in. LCD Television
Kenwood Receiver VR 806 turning off
Sounds like the music amplifier is different to the tuner audio amp. The music amplifier is now looking at an unbalanced impedance which is less than it should be. Therefore the output chip of the music amp has more current through it than it wants so it gets hot and shuts down.Put a four ohm wirewound resistor ( from Radio Shack ) in series with each surround speaker to reduce the current flow through the amplifier output.
Apr 09, 2010 | Kenwood VR-806 Receiver
Problem's with volume control for PIONEER C-73(control amplifier)
Try cleaning it with WD40. or some other penitrating fluid. Or just a hoover nozle. It's just dirt in the control.
Jun 09, 2009 | Pioneer VSX-D510 Receiver
Shuts down at high volume
If you have your reciever in an entertainment center that is enclosed or a tight fit for the reciever you need to remove it and put it on top of the center. I have a VR407 and it was doing the same thing. This keeps your unit much cooler and the overheat relay will not turn it off. also I found it much easier to add or wire components much easier.
Steve T. PA
Nov 25, 2007 | Kenwood VR-407 Receiver
Onkyo TX-SR605 Receiver Logo
130 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
