Question about Bissell Vacuums
The vaccum will not **** anything. All areas have been cleaned model 6595- bissel
  • 1,041 Answers
Here is a Link to one of my Tips:
www.fixya.com/support/r6311178-vacuum_brush_bar_not_spinning
This should solve the problem.
Good Luck!
Jim
Posted on Oct 12, 2010
  • Jim Parker
    Jim Parker Oct 17, 2010
    Was this helpful?
    Jim
My bissel vaccum got very loud all of the sudden
Your belt may be broken, your dirt cup may be full, or you may need to clean your filters. Look at these areas and you can find addional troubleshooting at this link (just select the type of vacuum you have in the dropdown menu): http://www.bissell.com/faqs/?c=330&sc=345&cid=ccsocial
Jan 07, 2012 | Bissell 3576 CleanView II Bagless Upright...
My Bissell bagless vacuum does not seem to work anymore. It will start to with a suction and then instead of picking up the dirt, it appears to blow the dirt out almost in a cloud of dust and debris from...
this is caused by a dirty air filter and/or a blocked vacume hose ( most of the time the blockage is at the bend where the hose enters the floor sweeper area ) ---
remove and tap out and brush the filter ( or use a air compressor to blow out filter ).
then with the vacume on its side - remove the bottom plate ( like you were going to change the belt ) and use a coat hanger and clean out the hose between the floor sweeper and where the suction hoes attaches. this will restore your vacume to full operation.
c...
Jan 23, 2011 | Bissell 6595 Lift Off Bagless Upright...
The brush on my vaccum stopped rotating, we replaced the belt thinking that could be the problem. It seems that the belt is working fine and the brush will not rotate even manually- what can I do to get it...
Remove the brush from the machine and clean as best you can. At each end of the brush there is a plastic clip that holds it into the vacuum. Add some WD40 between the clip and the brush and turn the clip around the brush until it moves freely. Do this for both ends. Reassemble making sure the belt is properly installed.
Oct 13, 2010 | Bissell 6595 Lift Off Bagless Upright...
Bissell 6595 problems with roller brush. I've had this happen with two of the same model. Each one didn't last more than seven months! First, it became loud when vacuuming, then there was a burning smell....
Hair and dust will work its way under the endcaps of the brushroll causing friction which can melt the brushroll and get hot enough to melt the nozzle housing as you have found. You will need to remove the endcaps to clean the debris out before it causes damage. I don't believe the endcaps are removable on your model. It will save you a lot of money in the long run to purchase a new vacuum that has a metal brushroll with removable endcaps. I have a durable long lasting Riccar vacuum with a metal brushroll available at ThatVacGuy.com. With this model you can pull the brushroll out once a year to clean it and install a new belt. With simple routine maintenance you can do yourself this model will perform great for many years.
Mar 16, 2017 | Bissell 6595 Lift Off Bagless Upright...
I have a bissell model 6595 lift off bagless the motor went out. Do u know where i can buy a new one?
I would check out ebay first you could save a lot of money that way instead of paying retail
Jan 24, 2010 | Bissell 6595 Lift Off Bagless Upright...
I replaced the belt on my bissell model number 3576-2, but when i put it back together, the brushes wont move...the belt tries to move, but the rubber just burns..
something is binding ... i dont know what ... you will have to remove all parts and reinstall again. Make sure the bearings spin on the brush when it is out ... remove all hair and string.
good luck ... im sure it is someething simple.
Nov 10, 2009 | Bissell 6595 Lift Off Bagless Upright...
Bissell lift off, brush won't move smell burning rubber belt fine
OK - so your brush roller is jammed. And yes, the belt is melting! Unplug the machine, remove the belt (you will need another new one anyway) then see if you can turn the roller by hand. If it turns freely without you doing anything else, then you may have put the new belt in incorrectly. However, you will probably find you can't turn it, or it's hard work (it should rotate freely). Remove the roller and check the bearings - there may well be something tangled up at one end of the roller. If you can get the roller rotating freely, all should be well.
Good luck
Mar 08, 2009 | Bissell 6595 Lift Off Bagless Upright...
Bissell 6595-1 with broken electrical connector
YES! If you haven't contacted Bissell yet (or bought a new vacuum) do so. They sent me a nice refurbished machine for free.
Dec 12, 2008 | Bissell 6595 Lift Off Bagless Upright...
Vacuums Logo
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
