Washer will not spin or agitate. found a round rubber piece on floor under washer with six plastic teeth like parts that appear to be broken off.
    President:
  • 1,554 Answers
The motor coupler is broken and the black round rubber piece you found under the washer is the rubber grommet that connects the coupler parts. The six plastic teeth are the coupler prongs, 3 for each coupler part. Replace the motor coupler.
Disconnect power and release the console from the top of the cabinet depending on the model of your machine then pull forward and up on the console and lay it back on the hinges.
Disconnect the lid switch harness connector by pressing on the tab locawasher will not spin or - 9698f29.jpgmiddle and pulling it up.
The cabinet is attached to the rear of the washer by two brass-colored retaining clips. Insert a flat blade screwdriver into the turned-up edge of the clip, located on both sides, and thewasher will not spin or - 4e2277c.jpgto release the clip from the slot in the cabinet.
Open and hold the lid while grabbing the cabinet front opening then tilt the top of the cabinet toward you by pulling the cabinet away from the base. This releases the front and back slots of the cabinet from the tabs in the front and back of the base. Using the side of your leg and/or body awasher will not spin or - 8df0387.jpg for the front of the cabinet, carefully lift up and set the cabinet aside.
Disconnect the motor harness then remove the screw securing the bottom clip holding the motor and remove thwasher will not spin or - f70a498.jpgold the motor from the bottom while loosening the screw securing the top clip holding the motor. Remove the clip then pull the motor out of the washer.
f70a498.jpgRemove the broken coupler parts from the transmission and the motor shaft then tap the new coupler parts in place or until the splines are even with the edge owasher will not spin or - 2870fd6.jpger.
Remove the motor mounting plate to remove the coupler part in the transmission side more easily.
Once the coupler parts are properly installed, put the rubber grommet into the coupler in the motor then line up the remaining slots on the grommet with the coupler prongs in the transmission and put them together.
Secure the motor with the clips and the clips with the screws then reconnect the motor wiring harness to the motor terminals and reinstall the pump in reverse order of the removal steps.
Bring the cabinet to the front of the washer then slide the front bottom rail of the cabinet under the rail at the base of the machine then lay down the cabinet into position. Make sure the slots in the cabinet sit into the tabs at the base of machine.
Reconnect the lid switch harness then push the retaining clips back down into position to secure the cabinet to the rear of the machine. Reinstall and secure the console to complete the repair.
Posted on Oct 12, 2010
I was washing and it made a clicking sound then it didn't spin or agitate. My hubby leaned it over to look behind and a black round piece fell out from under it. Where did it come from and what part is...
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (110.#######) and you'll see a list of major sub-components with diagrams and parts.
Kenmore / Whirlpool top load, direct drive washers use a "Motor Coupler" between the motor and transmission.
It's used as a fail safe device and consists of three parts.
Two of the parts are the same, plastic units with three prongs that fit on one of the motor output shafts and the other on the transmission input shaft. Between them is a rubber piece with six holes.
The power from the motor is transmitted through the rubber piece to the transmission.
The other shaft on the motor directly drives the pump. This is likely why the machine drains.
If the motor coupler is broken, or worn, the motor may not be able to send full power to the transmission for agitating or spinning.
See the following for how to remove the cabinet, pump, motor and motor mounting plate to inspect and replace the motor coupler.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
If the coupler looks damaged, it's a relatively easy fix.
Pry the plastic pieces from the motor and transmission. Some people use a claw hammer but I've found that using a small (6 inch) pry bar works well.
Carefully fit the plastic pieces over the motor and transmission shafts and press them in place (Use a 1/2" of larger socket to put pressure equally around the pieces.
Put the rubber piece on the transmission plastic piece.
Replace the motor mounting plate.
Carefully line up the plastic prongs on the motor based plastic piece to the three un-used holes in the rubber piece. If they don't line up right, the coupler could be damaged.
Mount the motor, don't forget the two screws, put the pump back on the motor and use its' clips.
Put the cabinet back on, don't forget to plug the lid switch back in and re-mount the console.
Dec 30, 2010 | Washing Machines
My kenmore washer will not agitate or spin. It makes a noise when it is trying to agitate the clothes or in the spin cycle.
May 11, 2010 | Kenmore 24032\24036 Top Load Washer
I have a kenmore series 70 heavy duty washer. The agitator stopped spinning. I moved the washer out of the laundry closet and found broken plastic pieces and a torn up white rubber thing under it. I...
If this is a basic top load, direct drive washer, there is a rubber-band like device that fits around the brake drum. It's a sound deadening device and won't hurt anything if it's broken or missing. That's likely what the "belt or gasket" is.
May 02, 2010 | Washing Machines
It makes a lot of noise and doesn't seem to agitate as well, there is a rubber substance I found on the floor upon moving it
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Look in the section for the motor, pump gearcase and you'll see the Motor Coupler.
Two of the parts are the same, plastic units with three prongs that fit on one of the motor output shafts and the other on the transmission input shaft. Between them is a rubber piece with six holes. (Possibly the source of the rubber on the floor.)
Apr 10, 2010 | Kenmore 24032\24036 Top Load Washer
My washer won't aggitate under medium to heavy load .it also clicks when starting spin cycle
The "clicking" may be the six plastic prongs hitting each other.
Mar 25, 2010 | Kenmore Washing Machines
Washer agitator seems to have quit working
First (and least expensive) thoughts are a broken motor coupler.
If the motor coupler is broken, or worn, the motor may not be able to send power to the transmission for agitating or spinning.
Jan 11, 2010 | Kenmore 24032\24036 Top Load Washer
The tub quit spinning, i looked under and there was a chunk of rubber on floor, it looks like it was a joiner between motor and gearbox, is this all i need?
six holes.
Nov 07, 2009 | Kenmore 24032\24036 Top Load Washer
Washer motor running but not agitating.it happened before and i change some kind of round rubber with plastic that have 3 tab in it.i just cant remember how did i do that to replace it or where did i take...
See the section on the Motor.
Kenmore / Whirlpool top load, direct drive washers use a "Motor Coupler" between the motor and transmission. It's used as a fail safe device and consists of three parts. Two of the parts are the same, plastic units with three prongs that fit on one of the motor output shafts and the other on the transmission input shaft. Between them is a rubber piece with six holes. The power from the motor is transmitted through the rubber piece to the transmission.
Oct 20, 2009 | Kenmore Washing Machines
Will not agitate or spin
Enter your model number and you'll see a list of major sub-components with diagrams and parts.
The top load, direct drive, neutral drain Whirlpool / Kenmore washers use a "Motor Coupler" between the transmission and motor.
When the motor goes into drain / spin mode, it reverses and drives the pump to drain the washer.
If the motor coupler is damaged / broken, the motor cannot get power to the transmission to agitate or spin.
This is a relatively easy fix for the basic Kenmore / Whirlpool washers.
http://www.fixya.com/support/r385250-replacing_motor_coupling_kenmore_top
Follow the instructions for removing the cabinet and pulling the pump, motor and motor mounting plate.
The coupler has two plastic pieces with three prongs each. In between is the rubber coupler with six holes.
Oct 05, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore...no drain but clicks instead...agitates and drains fine 110.92195110
not sur if you found your problem bu I found what was happening with my washer. I pulled the trans and motor assembly out and found a plastic gear / cam broken. I think the part number is 64194. it's found between the clutch and drive to the drum.
Jan 06, 2008 | GE Profile WPRE6100G Top Load Washer
Washing Machines Logo
551 people viewed this question
Top Washing Machines Experts
