Question about HP RT810UTABA - HP dc7700 small form factor, Core Duo E6300, 80GB hard drive 7200 SATA, no floppy, DVD/... PC Desktop
Hp dc 7700 windows xp not reconising hard 2nd drive
4 Suggested Answers
melnavz
  • 1226 Answers
SOURCE: for 2nd int. hard drive ? SATA or IDE -HP Media Center a1640n
You can contact your vendor. Or at ebay
( http://computers-networking.shop.ebay.ph/Computers-Networking__W0QQ_sacatZ58058 )
copy an dpaste the link your Internet browser address bar
melnavz
Posted on Feb 23, 2009
GeniusWorks
SOURCE: Installation of a 2nd hard drive steps & tips
Step 1: Back up and scout around
First, back up your critical files (don't forget your Outlook .PST archive) to optical discs, an external drive, or online storage. Then check whether a CD comes with the drive, providing drive-specific information and general upgrade assistance. It may also later help you copy the contents of one drive to another. Install this software first. Then, power down your PC, unplug all cables, and open the case. Next, ground yourself by touching a metal portion of the chassis.
Look inside—your first task is to determine where your new drive will go. Bays for internal drives are usually located below the wider, front-accessible bays that house CD or DVD drives. If you plan to replace your boot drive with the new drive and don't have an empty bay, your upgrade will involve more steps than we can cover here. But if you're replacing your boot drive and you have an empty bay, follow our steps for adding a second drive. After formatting it, use Norton Ghost (or a similar program) to clone your boot drive's contents to the new drive. Then, revisit steps 3 and 4 to direct your PC to boot from the new drive.
We'll be installing a SATA drive, but the process is similar for the other common drive type, IDE. SATA drives use a thin, seven-pin data cable; IDE drives use a 40-pin ribbon cable that's usually gray. If you're unsure which drive type your PC already has, check its documentation or label. Most PCs more than a year or two old employ IDE hard and optical drives, and don't support SATA unless they have a SATA PCI card installed. More-recent desktops may use (or just support) SATA drives but should support IDE, too.
Tip: If you transfer Windows XP from one drive to another, you may have to reauthorize Windows.
Step 2: Examine data and power connections
Most hard drive kits include a data cable (SATA or IDE, depending on the drive), a power adapter cable (with some SATA drives), and screws. If yours doesn't include cables, you can purchase them separately.
First, the data connection. If you're installing a SATA drive as secondary storage, follow the data cable from your current drive (assuming it's SATA, too) to the other end. See if an unused SATA port lies nearby on the motherboard or an interface card. If you can't find one, consult your PC's documentation.
If you're adding an IDE drive as a second drive, you may be able to connect it to the same data cable as your primary IDE drive, or along with an IDE optical drive. Look for a third, free connector in the middle of the cable that connects your currently installed IDE drive to the motherboard. Note that some older PCs use 40-conductor IDE cables, not the 80-conductor ones current drives require. (Compare your kit cable to the one installed—the 80-conductor variety has much thinner wires.) 80-conductor cables are backward-compatible (both types use the same 40-pin connector), so you can swap out a 40-conductor cable for your kit's 80 if need be. (The "master" drive goes at the end—see step 3.)
Next, consider the power connection. Our SATA drive has a 15-pin SATA power connector. If you already have a SATA drive installed, follow its power cable (the wider of the two connectors) to see if an unused power-supply lead with the same connector is nearby. If so, earmark that lead for your new drive. If it can't reach the empty bay, see if any bundled adapters help.
Some SATA drives also support familiar legacy Molex four-pin power connectors—you can use a Molex or SATA connector. If so, hunt for a free Molex-style lead. Still no match? Then you'll need an adapter, such as a Molex-to-SATA adapter (some kits bundle one), or a Y-adapter that splits a lead in two.
IDE drives are simpler: They always use Molex connectors. You just need a free Molex-style lead (or a Y-splitter).
Step 3: Mount and connect the drive
When installing SATA drives, jumper settings usually aren't an issue. That's not true of IDE, where a jumper indicates whether a drive is a primary ("master") or secondary ("slave") drive. Check its documentation for the proper setting. If your PC has only one IDE hard drive, it's probably set to "master." Assuming you chain another IDE drive off its cable, the new drive should be set to "slave." (You'll later have to change the jumper to "master"—and attach the drive to the cable's end—if you remove the original boot drive and make the new drive the boot drive.) Another option: Set both IDE drives on an 80-conductor cable to the Cable Select (CSEL) jumper setting. The PC will determine master/slave status according to the drives' placement on the cable ("master" at the end, "slave" in the middle).
Next, look at your current hard drive to see if mounting rails are attached to its sides. If so, screw a set onto the new drive (look inside the case for spares), then slide the drive into its bay. Otherwise, screw it directly into the bay. Four screws are sufficient. Usually, the label side points up; mimic the boot drive.
Attach one end of the SATA data cable (which is keyed for correct insertion) to a SATA port on the motherboard or interface card, the other to the drive. IDE data cables, also keyed, usually have a red stripe that lines up with the "pin 1" marking on the drive.
Next, plug the power-supply lead (keyed, too) that you scouted out in step 2 into the drive, including any necessary extender or adapter. Then close the case.
Step 4: Configure the BIOS
Next, boot into your PC's BIOS-setup utility to verify that it recognizes the new drive and positions it correctly in the drive hierarchy. (Check your PC's startup screen to determine which key launches the utility.) Once there, also check that "auto-detect" is selected for the drives, if an option. If the utility lets you select the boot order, give your intended boot drive priority over any other hard drive. This information may be under Boot Options, Boot Order, or Boot Sequence.
Save changes and exit the utility. Your PC will reboot.
Tip: Using a SATA PCI interface card? It may have its own BIOS to check.
Step 5: Partition and format your hard drive
Our PC runs Windows XP, which lets you partition and format drives within Windows. Older Windows versions, such as 98 and Me, make you do this from DOS.
With XP and 2000, though, use Windows' Disk Management utility. Click Start > Control Panel > Administrative Tools > Computer Management, and choose Disk Management from the tree at left. Your new drive should appear, with a black bar indicating it isn't partitioned. Right-click the bar, and choose New Partition to launch the New Partition wizard.
Click Next, and check that Primary Partition is selected; click Next again, to the Specify Partition Size screen (don't change the partition size in the "Partition size in MB" field); and click Next to advance to another screen, on which "Assign the following drive letter" should be selected. Click Next yet again (to the Format Partition screen), and ensure that "Format this partition with the following settings" is selected and that the "File system" drop-down reads "NTFS." Click Next a final time, hit Finish, and formatting begins.
Formatting could take an hour or more, depending on drive capacity. But don't be surprised if your formatted drive has less capacity than the package claims. A 320GB drive, for instance, formats to about 300GB. Drive manufacturers advertise preformatted size, but a portion of the drive is inaccessible.
Posted on Dec 29, 2009
intower18
  • 957 Answers
SOURCE: how can i install my
Just download a driver online for free. Just click the link below:
Just click_here so that you will be redirected to the exact site. Just click on the download then follow all the prompts then you are good to go.
Thanks.
Posted on Sep 20, 2011
No signal on monitor for hp dc-7700
how many hard drives do you have two or more when reset bios default it can happen.you must be sure to start from the drive there windows is.bios optimal default probely changed drives
Apr 01, 2013 | HP Compaq dc7700 PC Desktop
Install 2nd Hard Drive with different connectors and different OS.
yes you can use either sata power or molex(4 pin) plug to power your new SATA hard drive but not both at the same time.
Mar 19, 2012 | Samsung SpinPoint SP8004H 80 GB Hard Drive
How can i install my hp compaq dc 7700 945 audio driver
HI,
Installing the HP DC 7700 Drivers is a little tricky. You may have installed the drivers and its not working I guess. This is because the HP DC-7700 has HD Sound and it required "Microsoft Universal Audio Architecture Bus, which can be downloaded/ installed from the following link. Choose the Operating system you have on your PC and get the drivers.
HP DC7700 Drivers
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Sep 20, 2011 | HP Compaq Business Desktop dc7700 -...
59.30 error code on HP 5550. Solution? tried replacing fuser, same error.
It's not a fuser problem. It's the fuser drive assembly(RG5-7700-000CN) or it could be the DC Controller(RG5-7684-000CN)
Jan 08, 2011 | HP LaserJet 5550 Printer
I replaced a hard drive and after loading windows xp, my laptop wont boot, it only gives a hard drive read error.
Remove it then insert again. if the problem as is use another hard drive... also check the set up setting of your unit.
Aug 19, 2010 | HP Compaq Evo n800c Notebook
Hard drive feel out and it dosent seem to reconise the drive know, it comes up with no bootable device
First of all, which do you want on the thing, Vista or XP?
Second, if you want XP, most likely you didn't install the Sata drivers for the OS disk from a floppy (must be downloaded in advance), and you should do that at the F6 prompt.
Third, do you have your boot order set to:
CDRom - 1st
Floppy - 2nd
Sata Boot Drive - 3rd
Fourth, do you have your boot order initially set the Boot Device Priority setting under the hard drive area to have the Sata you are using to boot as the first in boot order?
Fifth, clear up the raid issue for us, do you plan on using raid, or do you not. If not, then you must turn off the Raid controller in the Bios.
These are some common must-do things before we get too far
Oct 29, 2009 | Computers & Internet
Hard drive installation problem
Yes it is possible but you need to set it up as a dual boot system with XP installed on the 2nd drive (slave drive).
Mar 16, 2009 | HP Compaq nx6110 PC Laptop
I use hp pc computer with xp windows and cant use hp photosmart 7760 printer . how can i setup this printer 2 ma software ??????
Find another HP Printer Driver that will allow you to have most of the features you had. You always seem to lose features when dealing with this. This is your only option. Search the HP.com website for suggestions. Put 7760 and XP in the search box.
Jan 20, 2009 | HP COMPAQ Floppy Drives ADAPTER MULTIBAY...
Hp dv6000
There is option in BIOS called something about automated SATA recognition or similar - disable it. It is under System configuration. And if you are putting new drive in then run full test from BIOS (Hard drive selftest - takes about 79min.)
I tried to reinstall Windows Media center on my HP dv6000 because my previous hdd crashed - When I put in installation cd - it said that it can't find hdd. I spent week to figuring that out. The thing is - as far as you haven't disabled that SATA thing in BIOS - PC doesn't recognize hdd. But only with Windows media center edition. With all other windows xp - there is no such problems. Strange.
Feb 11, 2008 | Computers & Internet
HP RT810UTABA - HP dc7700 small form factor, Core Duo E6300, 80GB hard drive 7200 SATA, no floppy, DVD/... PC Desktop Logo
53 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
