Question about Maytag Refrigerators
We have a 13-month old Maytag, top freezer, Model M1TXEMMWQ. We just discovered a large pool of water underneath the right side of the refrigerator. The is no evidence that the water supply for the ice maker is leaking at either the wall or at the back of the refrigerator. Any idea what could be causing the leak?
peyton32034
  • 410 Answers
SOURCE: drain pan leaking?
there is a drip pan located underneath you ref but most likely your prob is a plugged drain line coming from the freezer. when you ref goes into automatic def the water doesnt run out into the drip pan but instead onto your floor..
you can clean the drain line by removing the rear cover in the freezer compartment and using hot water to thaw the drain below the evap coil.
Posted on Dec 12, 2007
  • 833 Answers
SOURCE: Ge profile side By side ice maker water leak
This sounds like the float mechanism has gone bad. Remove it and have a look. It may be the float or the switch on it that is bad. There is also a solenoid valve. Parts kits are available. Shut off the water first!
Posted on Dec 22, 2007
jtbjtb
  • 135 Answers
SOURCE: Roper Refrigerator, top freezer leaking water into refrigerator
This is usually caused by a plugged freezer drain. The back wall (or floor) of the freezer may come out to access the drain. Clear out anything visible and run a stiff wire thru it. Test with a cup of water. Hope this helps!
Posted on Jan 01, 2009
  • 87 Answers
SOURCE: Water pooling underneath bottom drawers
Find the drain line from the freezer to the evaporation pan near the motor. Often the line is visible on the back of the fridge. That line is plugged either with food residue or the collection point in the freezer is solid ice. The self defrost feature melts the frost and drains it to the evap pan. If you remove the floor from the freezer area, you will see the collection point. When the line gets plugged with food, no water drains and then freezes to block the line even worse. So, if there is ice at the collection point, remove it somehow, maybe a hair dryer, and then clear the line by blowing compressed air from the bottom of the drain hose through to the collection point.
Posted on May 28, 2009
Sea Breeze
  • 4654 Answers
SOURCE: 8 year Maytag refrigerator drips water from
Carl would you get me the model number of your whirlpool. Most times found inside the fresh food compartment door frame and near bottom. Your problem sounds like a blockage in the defrost drain tube that leads to the condensate pan under the refrigerator. Thank You, Sea Breeze
Posted on Jun 10, 2009
I have an LG french door bottom freezer refrigerator. Water is coming out of the back freezer vents and then pooling and freezing on the freezer floor. If we don't remove it periodically it leaks onto the...
This has nothing to do with the ice maker. The defrost drain has frozen over. Inside the freezer you will see that the whole back is a panel. Unplug the unit and gently pry at the top of this panel. It will come forward and then you can lift it out. unplug the fans and take the panel out. You will see the coils. and underneath the coils, the drain pan. Mine was completely filled with ice. I used a hair dryer to melt it and remove the large chunks. Be gentle. Use a turkey baster to remove excess water. Then pour some very hot water in to clear the drain itself.
Sep 04, 2013 | LG LFX28968ST Refrigeration : Refrigerator...
We have a Maytag Peforma Model PBB2255GES Maytag Refrigerator. It has a bottom freezer drawer. We have water pooling under the right front leg of the freezer.
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer or on floor
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Aug 29, 2011 | Maytag Refrigerators
MTB2656G Top Freezer Refrigerator: Water is leaking and pooling below crispers in ref...
Clean the drain pan and drain line in the back of the freezer section underneath the evaporator coil. Make sure water drains when you pour it in. If it doesn't - also clean drain tube on the back of the unit behind the cover. When done - make sure to put the tube exactly where it was.
Good luck! :)
Vlad
First Choice Appliance
May 06, 2010 | Maytag MTB2656G Top Freezer Refrigerator
Water pooling under right front of refrigerator
is there any ice on freezer floor or is the bottom rack iced in?if so you have a blocked drain in the freezer,or if that's ok you could have a crack in one of the plastic water lines,also check the catch pan where the water drains into when the fridge defrosts,you can pour water down the drain in the freezer to check that,roll the fridge forward and take the bottom panel off the back,should be easier to check for leaks and take off the front kick panel,while you're in there vac out all the dust in there,front and back,you should do this every 6 months
Jan 23, 2010 | Maytag MSD2756G Side by Side Refrigerator
Periodically, water flows out of the bottom of the freezer door and pools on the floor. The water supply for the icemaker isn't hooked up, so it can't be that.
This is the water coming from your defrost cycle. I'm not sure on this model, but the auto defrost will always generate some water. Some brands use a pan underneath that collects the water and then lets it evaporate, and some put the water in the condenser coil that's under the unit. Yours must have the line that runs from the freezer to the place it's supposed to go unhooked or misrouted. It could also be clogged inside the freezer.
Aug 26, 2009 | Maytag MSD2756G Side by Side Refrigerator
Ice maker quit qorking
The chute where the ice drops through could be icing up, try removing the I bin and cleaning the ice build up out.
Jun 16, 2009 | Maytag MSD2456G Side by Side Refrigerator
New Maytag Refrigerator drains water into a pan underneath
check for clogged drain line bottom of inside of the freezer,or you can check it at back side underneath
Mar 12, 2009 | Maytag MSD2542VE Side by Side Refrigerator
Water leaking underneath refrigerator/water freezing in bottom of freezer
I'm dealing with the same problem right now with the same refrigerator. The cold water tank (for the front dispenser) has a hole in it that leaks every time someone dispenses water from the front door. You will find the water tank behind the top slide-out drawer in the fridge. The leaked water flows down one of the water tubes through a hole in the bottom of the fridge and onto the floor. I'll bet you have the same problem. Good Luck.
Jun 14, 2008 | Maytag MSD2758G Side by Side Refrigerator
Maytag Side By Side Problem
Check and make sure the drain pan under the refrigerator is in position and the drain hose is in the pan. If it misses the pan it will put water on the floor.
May 31, 2008 | Maytag MSD2456G Side by Side Refrigerator
Refrigerators Logo
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
isaac johny
isaac johny
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
