Question about Frigidaire GLEH1642DS Front Load Stacked Washer/Dryer
Dryer stopping mid cycle
Hi only had the dryer for seven months and the dryer is stopping mid cycle can you please tell me what can solve this problem? or what is wrong?
  • 2 more comments
  • nyln Jun 01, 2008
    before it stops it keeps a 'grinding' noise then it stops but you can restart it immeadiately
  • nyln Jun 01, 2008
  • nyln Jun 01, 2008
  • nyln Jun 01, 2008
    thank you I will have my Hubby look at it and confirm with you. Thanks for your prompt response.
    President:
  • 2,712 Answers
Open the dryer door and try to turn the drum by hand. If it won’t turn then you have something stuck in the blower chute – clean it out.
If you gain access to your control panel there should be a mini manual to help diagnose the problem, step by step. Your unit has a electronic mositure control and thermisters to control when it shuts off. Either the thermisers are causing the problem or the board itself...
Posted on Jun 01, 2008
  • Swilin Sampson
    Swilin Sampson Jun 01, 2008
    It could also be that the heating element or the motor is overheating causing the dryer to stop. It's possible that the motor could use lubrication and the best way to do that is to take the motor apart.
    Does the shaft of the motor turn easily? If not, you need to lubricate
    the motor. If the motor's shaft turns easily, then the problem is a bad
    motor.
    To test this, remove the motor from the dryer and rig it up so that you
    can plug it directly into a wall outlet. Obviously, do this
    carefully... particularly when twisting wires together for the
    temporary connection. Use tape and have the motor resting on a solid
    surface, such as a good workbench or even the floor. (After all, the
    running motor can't fall off the floor!)
    If you rig up this temporary test, you will probably find the motor
    will get hot and shut down. If it doesn't, you have a problem somewhere
    else, probably the timer.
    If you are unsure how to do all this, I would recommend getting a repair guy to diagnose/fix the problem for you. Unfortunately, we can only guide you as to the possible causes for the issue, but you will have to do the repair yourself or get someone to do it for you.
  • Swilin Sampson
    Then its most likely the motor or the drum bearing. Please inspect the drum bearing as well.
    Scholar:
  • 198 Answers
Are u by any chance overloading the dryer... may be its not taking the load...
check out the wiring connections , if any wire s loosely connected fix it properly...
  • Frigidaire Master
  • 19,396 Answers
You have to test several parts, common causes are defective termic sensor, or fault program control.
Post model number for more details
  • Ginko
    Ginko Jun 01, 2008
    from repairclinic:
    If your dryer doesn't work at all, or stop in the middle of cycle it could be because of problems with:
    Door switch
    Thermal fuse
    Wiring
    Door switch
    If
    the door switch or the door-switch actuator is defective, the dryer
    won't work and you need to replace the failed component. The switch is
    inside the dryer main housing near the door frame. Sometimes you need
    to raise or open the top or front of the dryer to reach the switch.
    Thermal fuse
    On many dryers, there's a thermal fuse (a heat-sensitive fuse
    that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an
    inch long. It's usually embedded in black resin and mounted in a white plastic housing.
    If the fuse has blown, it has no continuity. When this happens, your
    dryer either just stops heating, or it doesn't work at all. Be sure to
    inspect the venting/heating system before replacing the fuse to put the
    dryer back into operation. (You can't re-set this type of fuse.)
    Wiring
    Often
    the main wiring connection from the house, at the dryer, burns and the
    connection breaks. In this has happened to your dryer, you need to
    replace the power cord and the terminal block inside the dryer to which
    the wire is attached.
  • Ginko
    Ginko Jun 01, 2008
    If you hear a grinding noise often this is due to a foreign object in the tub, many dryer have a trap for foreign objects, usually you need to open the tub to access it.
MY DRYER SERIAL NUMBER X073808040 STOPS AFTER 20 MINUTES
Kenmore Dryer - heats & runs but stops mid-cycle - Ask Me Help Desk
https://www.askmehelpdesk.com/.../kenmore-dryer-heats-runs-but-stops-...
Kenmore Dryer - heats & runs but stops mid-cycle. Asked Aug 30, 2006, 12:25 PM - 10 Answers .... Unfortunately it shuts off after a few minutes, I'll estimate about 5.After waiting about 30 minutes, ... New Member. Jun 16, 2010, 09:20 AM ...
Sep 15, 2015 | Dryers
GE dryer stops mid-cycle. If I try to restart it, it won't. Once I wait a few minutes for it to cool down, it will restart. I never know how long it run till it stops. A load last night stopped at...
I would say thermal fuse, here is a website that will tell you how to check, it also has other possibilities, Hope This Helps Tim:
http://www.partselect.com/dryer+dryer-wont-start+repair.htm
Oct 21, 2010 | GE Dryers
Our dryer stopped working mid cycle. light
with no light it tells me you have lost L1 check your outlet, and your wire connections
Sep 30, 2009 | Maytag HYE3658AY Electric Dryer
My dryer has been difficult to start lately especially if stopped mid cycle. The lights are all on but it won't start up. Today I only used it 2 times and it was very difficult to start after pressing many...
You may be experiencing "Heat Retention" by stopping your dryer mid-cycle, which you should NOT ever have to do! If you have a minor vent restriction or if you open the dryer mid-cycle when the heat is on, this will cause a disruption in the airflow and rising temperatures can keep the dryer from restarting until it has been cooled long enough.
Check your vent all the way to the outside for restrictions/obstructions every 6 months. Clean your lint filter after each load and DO NOT stop the dryer mid-cycle!
Note: Stopping the dryer mid-cycle can also cause severe burns and even melt polyester fibers.
Jul 05, 2009 | Maytag Neptune MDE5500AY Electric Dryer
I have a zwd12270w. Seven second after pressing
The problem is with the tumble drier heating element. If you remove the top of the machine (disconnect it from the electricity supply first!) you will find a big metal oblong "bar" that runs from the front to the rear of the machine. At the rear there are 4 white wires connected to the metal "bar". Make a note of where they go and remove them. You may need pliers to get a good grip of them. Once removed, the washing machine should work just fine but obviously the tumble drier will not. This is a well known fault and it may be worth contacting Zanussi as they MUST know about it!
Jun 28, 2009 | Zanussi ZWD12270 Front Load Washer / Dryer
Frigidaire Model FSE446RHS shuts off mid cycle
Hi, If the motor is shutting down mid cycle and can not be restarted untill cooled, the motor will need changed. It is shutting off on a safety overload. These motors cost about $145.00
Please let me know if I can assirt you further.
Vic
Jun 01, 2009 | Dryers
Dryer overheats, stops mid-cycle
Hi, Will the dryer restart right away? Sounds like a motor going bad. With a model #, I can get you part#s if you need them. Is this a whirlpool brand?
Let me know if I can assist you further.
Thanks
Vic
May 17, 2009 | Dryers
My dryer stops in mid cycle and gives me an error code of E1
It is a bad thermistor on the blower housing
http://forum.appliancepartspros.com/dryer-repair/1379-kenmore-elite-e1-sensor.html
Apr 18, 2009 | Kenmore Elite Oasis 6808 Electric Dryer
Dryer stopped in mid cycle.
Sounds like you might need a new motor.
Mar 06, 2009 | Kenmore 62602 Electric Dryer
Whirlpool gas dryer stops in mid cycle and then starts up again
make sure of mode# make inside door and I will help you. also how old is your drier?
Feb 01, 2009 | Whirlpool LER4634J Electric Dryer
Frigidaire GLEH1642DS Front Load Stacked Washer/Dryer Logo
167 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
