Question about Nintendo Game Boy Advance SP Console
Is there a way to get water out with not tacking it abart
  • 37 Answers
Assuming that you haven't turned it on yet, in which case you are probably screwed, set it out underneath a sunlamp for a few days. Make sure that it does not get TOO hot, as it WILL MELT!!! But so long as you keep it at a reasonable temperature, the water should evaporate out. Again, do NOT TURN IT ON! This could easily short out the circuits and ruin it permanently. Just leave it as is for a few days under a sun lamp. Tell me how it works out, and hope this helps!
Posted on Oct 12, 2010
How do I weld upright posts on square tube base so that same size square tube stays 90 degree when tacked.
Anytime you weld something or even tack anything together, your joints are going to move some. You could position your pieces to compensate for this or you could clamp them down. But no matter what, when that weld puddle solidifies, it will pull and the stresses exerted on your work piece can be pretty high. If you can't clamp it in place to minimize movement, try tacking one spot on one side, then--using a your favorite hammer--influence your piece back straight and tack the other side. Once you have solid tacks that are going to hold your piece as square as you can make them, then weld it out, alternating sides and direction of travel. Of course minimize heat input as much as possible. Travel speed has more to do with heat input than amperage or voltage in many cases. Its a little hard to give you specific recommendations on your project without knowing more about your set up there. So tack, straighten, tack, straighten, tack straighten and so one...then weld it out.
Apr 25, 2016 | Welding Tools
Instrument panel guages work one day the not the next, whats the problem?
It's tach, not tack, short for tachometer. Were these gauges installed by unionized people? It could have been the gauges' day off, as per their collective agreement.
Most instrument panel woes are caused by bad grounds. Most panels are below the front glass, and if this leaks, guess where the water goes? Dashboard problems are a bear to fix sometimes, and costly in terms of labor. Have someone steal the car.
Jun 21, 2012 | 2005 Chevrolet Monte Carlo
When i started it the motor sound like it a marbles rolling around in it now it wont start at all
Sorry to say but it sounds like your rod's come abart, This will sound like junk in your engine , Befor you really know you need to pull the oil pan and see if thereis pieces of metal in your pan, If so you will need a overhaul or salvage replacement, Best of luck if i can help in any way just let me know.
Apr 07, 2011 | 2003 Chevrolet Cavalier
Is there a depth adjustment r tension adjustment
As far as I can tell this unit does not have an adjustment. Normally such an adjustment would only be included on much more expensive and specialised units generally listed for professional use.
If you need more pressure then hitting the tack with a hammer is the general answer.
If you need less pressure, i.e. the tack is cutting through the insulation/wire you are tacking then a cushion may help.
Suggestions for cushion material include one or more layers of paper or a thin (e.g. 3mm) piece of neoprene foam. After tacking the wire in place the foam/paper can be removed almost completely to produce the desired result - a tacked wire with no damage.
Hope this helps. For more power I favour the Stanley PowerShot series: they are absolute brutes and shoot most variations of staples, tacks and nails.
Jul 29, 2010 | Stanley CT10C Heavy Duty Staple Gun/Cable...
How do a take abart antique bit brace
Clamp the Brace and turn the chuck counterclockwise to release.
Sep 08, 2009 | Stanley Hand Tools
IT DROPS BACK A CYLINDER AND THE TACK GOES TO 0
I have a 94 magna that had the very same problem. I thought it was a problem with a stopped up carb or gas line but determined the battery connections had worked loose. Tighten the battery connections. Since you are there also check the fluid level in the battery. Only use distilled water to refill the cells NEVER tap water. You can buy distilled water at most grocery stores or WalMart for about a buck a gallon. Hope this helps.
Jul 08, 2009 | Honda VT 500 C Motorcycles
Tachometer doesnt work on my 86 ford escort.how do i fix this problem?
if the car has a distributor ignition system, the tack wire comes from the distributor plug, not sure what color the wire is, the tack gets it's reading from one of these wires. check wire from back of tack. trace to distributor and check connections. if connected, tack is probably bad.
Jan 26, 2009 | 1991 Ford Escort
Nintendo Game Boy Advance SP Console Logo
22 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
