Question about Sony Playstation 3 (PS3) Console
I turn on the main power in the rear then touch the power button in the front it trys to start, it beeps once then the lights go green, blue, yellow and then flashing red with three beeps. The person I got it from said it needed the hard drive reformatted. What is wrong withy playstation?
    President:
  • 1,139 Answers
Unfortunately this is known as the Yellow Light of Death (YLOD). This indicates a general hardware failure normally due to overheating. When these PS3's were produced Sony decided to use lead free solder. The problem with lead free solder is that it is not as flexible as leaded solder but it is cheaper and more environmentally friendly. When the console gets hot and cools down hairline cracks appear within these solder joints and a good electrical contact cannot be made. This then causes the console to fail. It could be on a number of different components including the CPU, GPU or memory. There is a temporary cure that may or may not work but ultimately the console will need to be repaired professionally or replaced. If it is out of warranty Sony will not replace it but will offer a refurbished unit for around £130. If you look on Youtube for Yellow light of death fix there is a way that you can re-heat the solder joints using a heat gun but if you are not confident taking apart electrical items then this really may not be something you want to try.
I am sorry I cant give you any better news but unfortunately it is a very common problem with the PS3
Hope this helps
and thanks for using Fixya
Posted on Oct 16, 2010
I have a 1999 Ford contour lx neither the brake lights nor the turn signals will work what would cause this
a fuse number 24,,,
The following specifications are for the Ford Contour and Mercury Mystique manufactured throughout 1995-2000.
Fuses Rating Color Circuit Engine bay fuse box 1 80 Black Power supply to main fuse box 2 60 Yellow Radiator fan 3 60 Yellow ABS 4 20 Yellow Daytime running lights 5 30 Light green Fog lamp 6 30 Light green Not used 7 30 Light green ABS 8 30 Light green Air pump 9 20 Light bue PCM module 10 20 Light bue Ignition switch 11 3 Violet PCM memory 12 15 Light bue Horn & hazard flasher 13 15 Light bue Oxygen sensor 14 15 Light bue Fuel pump 15 10 Red Right-hand low beam Passenger compartment fuse box 16 10 Red Left-hand low beam 17 10 Red Right-hand high beam 18 10 Red Left-hand high beam 19 7.5 Brown Heated door mirrors 20 10 Black Windshield wipers 21 30 Light green Electric windows 22 7.5 Brown ABS 23 15 Light bue Reverse lights 24 15 Light bue Brake lights 25 20 Yellow Door locks 26 20 Yellow Main light 27 15 Light bue Cigarette lighter 28 30 Light green Power seats 29 30 Light green Heated rear window 30 7.5 Brown Engine management 31 7.5 Brown Instrument pannel lights 32 7.5 Brown Radio 33 7.5 Brown Front and rear sidelights (left) 34 7.5 Brown Interior lighting & clock 35 7.5 Brown Front and rear sidelights (right) 36 30 Light green Air bag 37 30 Light green Heated blower 38 Unused Relays Color Circuit Location Engine bay fuse box R1 Green Daytime running lights (Canada) R2 Black Radiator fan (high speed) R3 Blue AC cut-out R4 Brown AC clutch R5 Dark green Radiator fan (low speed) R6 Yellow Starter R7 Brown Horns R8 Brown Fuel pump R9 White Low beam headlights R10 White High beam headlights R11 Brown PCM power supply Passenger compartment fuse box R12 White Interior and courtesy lights R13 Yellow Heated rear window R14 Yellow Heated blower R15 Green Windshield wiper motor R16 Black Ignition R17 Unused R18 Black One touch window switch Driver's door R19 Blue Cruise control cut-off Central fuse box bracket R20 Unused R21 Unused R22 White Fog lights Interface module bracket R23 Black Turn signals Steering column R24 White Left-hand flasher Door lock module bracket R25 White Right-hand flasher Door lock module bracket R26 Unused Bulbs / Lights Wattage Type Low beam headlamp 55 9006 Halogen High beam headlamp 55 9005 Halogen Parking / Side light 5 2357A Wedge Front turn signal 21 2357A Bayonet Rear turn signal 21 1157 Bayonet Tail light 21 1157 Bayonet Stop light 21 1157 Bayonet High mount stop light 5 2723 Bayonet Fog/Driving light 55 893 Halogen License plate 5 6418 Festoon Reverse light 21 1156 Bayonet Front sidemarker 5 2357A Wedge Glove box Map light 5 64111 Wedge Dome light 10 6411 Feston Step/Courtesy light Trunk/Cargo area Engine compartment 10 89 Wedge Instrument-general Automatic trans indicator
Apr 15, 2015 | 1999 Ford Contour
Tip
Fuse list ford contour
Engine bay fuse box
3 60 Yellow ABS
22 7.5 Brown ABS
32 7.5 Brown Radio
38 Unused
Engine bay fuse box
R3 Blue AC cut-out
R4 Brown AC clutch
R6 Yellow Starter
R7 Brown Horns
R8 Brown Fuel pump
R16 Black Ignition
R17 Unused
R20 Unused
R21 Unused
R26 Unused
Glove box
Step/Courtesy light
Trunk/Cargo area
Instrument-general
on Apr 15, 2015 | Ford Contour Cars & Trucks
2000 KIA SPORTAGE STEREO WIRING DIAGRAM
You can use the attached diagram for assistance, but here goes:
1. Blue/Yellow (Pin 1) - Illumination (+12V) (when headlights on)
2. Black/Yellow (Pin 1) - Main Power (+12V)
3. Light Green/Black (Pin 2) - Memory Power (+12v)
4. Black (Pin 11) - Ground
5. Blue/Red (Pin 9) - Left Front Spkr Return (-)
6. Green (Pin 19) - Left Front Spkr Signal (+)
7. Brown (Pin 10) - Right Front Spkr Return (-)
8. Light Green/Yellow (Pin 20) - Right Front Spkr Signal (+)
9. Blue/Orange (Pin 7) - Left Rear Spkr Return (-)
10. Green/Yellow (Pin 17) - Left Rear Spkr Signal (+)
11. Green/Red (Pin 8) - Right Rear Spkr Return (-)
(Note here that the wire color at the rear speaker is
Green/Blue - not sure if this is a misprint (see diagram))
12. Yellow (Pin 18) - Right Rear Spkr Signal (+)
Nov 10, 2013 | Vehicle Parts & Accessories
What is the wiring diagram for the stock radio
Check this...
1998 Ford Taurus Car Stereo Radio Wiring Diagram
Radio Constant 12V+ Wire: Green/Yellow
Radio Switched 12V+ Wire: Yellow/Black
Radio Ground Wire: Black/Light Green
Radio Illumination Wire: Light Blue/Red
Radio Dimmer Wire: N/A
Radio Power Antenna Trigger Wire: N/A
Radio Amplifier Turn On Trigger Wire: N/A
Front Speakers Size: 5" x 7" Speakersir?t=modilife-20&l=as2&o=1&a=b00009uhre
Front Speakers Location: Doors
Left Front Speaker Wire (+): Orange/Light Green
Left Front Speaker Wire (-): Light Blue/White
Right Front Speaker Wire (+): White/Light Green
Right Front Speaker Wire (-): Dark Green/Orange
Rear Speakers Size: N/A
Rear Speakers Location: N/A
Left Rear Speaker Wire (+): Gray/Light Blue
Left Rear Speaker Wire (-): Tan/Yellow
Right Rear Speaker Wire (+): Orange/Red
Right Rear Speaker Wire (-): Brown/Pink
Hope helps (remember to rate and comment this answer).
Feb 16, 2011 | 1998 Ford Taurus
-it is a power problem. -i turn on my ps3 system using the main power button on the back of the console and the red light comes on in front. -i then touch the standby button in front and the red light...
You can fix it yourself. The CPU was to hot and the solder has come off. Bad part is the solder is under the CPU and must be heated up. It is lead free so it needs more heat then lead and you need to add flux. I would start by getting the board out. Remove the thermal paste off the CPU. Add flux with a flux pen. You want to get the flux under the CPU so you might want to tip it on its side. After you have a good amount of flux under the CPU you want to start to heat the parts around the CPU. I would use a heat gun with temp. settings. You first want to heat around the CPU to keep solder on the other parts from cracking. You dont want to over heat the parts. After you preheat the board you want to heat the CPU. It needs to be around 400 or 500 degs f. a good 15 or 30 sec. keep moving the heat gun. After heating the CPU you want to start the cool down. Same as warming up the board but you want the board to cool down slow. After all this you want to add New thermal paste to the CPU. This helps transfer from the CPU. This is a must because your PS3 is overheating as it is. After you do all this some people say it only works for 2 to 6 weeks. Its all on how you fix the board and how good of a job you did. I would back up your hard drive. Then hope for the best!! good luck and i hope this helps you out.
Dec 26, 2010 | Sony Playstation 3 (PS3) Console
Need Wireing diagram to hook up a Wire Harness to a Kenwood BT645U to a 2000 Jeep Grand Cherokee
2000 Jeep Grand Cherokee Stereo Wiring Constant 12V+ Red/White Switched 12V+ White/Red Ground Black Illumination n/a Dimmer Orange Antenna Right Front Front Speakers 6" x 9" Doors Left Front (+) Light Green/Red Left Front (-) Light Green/Green Right Front (+) Light Blue/Red Right Front (-) Light Blue/Black Rear Speakers 6 1/2" Rear Door Left Rear (+) Dark Green/White Left Rear (-) White/Dark Green Right Rear (+) White/Purple Right Rear (-) Tan/Dark Green
Kenwood Wires:
Red: Switched 12volt
Yellow: Constant 12volt
Black: Chassis Ground
Blue: Not used
Light Blue/Yellow: Steering wheel control
Brown: Mute Control
Blue White: Power Antennae (or Amplifier remote turn on)
White - White/black: +/- left front
Gray - Gray/black: +/- right front
Green - Green/Black: Left rear
Purple - Purple/black: right rear
Dec 21, 2010 | Car Audio & Video
Wiring diagram for a Clarion CZ109
Clarion uses the industry standard wiring colors. Not every unit will have all of the listed wires
SPEAKERS:
White = Left Front +
White/Black = Left Front –
Gray = Right Front +
Gray/Black = Right Front –
Green = Left Rear +
Green/Black = Left Rear-
Violet = Right Rear +
Violet/Black = Right Rear –
POWER/ACCESSORY:
Yellow 14ga = Battery Main/Memory
Yellow 18ga = Battery CeNET Power/Memory
Red = Accessory (ignition on)
Black = Ground
Blue = Antenna Turn On +
Blue/White = Remote Turn On (amps) +
Orange/White = Dimmer
Brown = Phone Mute
Orange or Mint Green= Parking Brake Video Lockout
White/Red = CCD (camera) input instant on +
RCA Cables:
Gray = Front Output
Black = Rear Output
Purple = Non-Fade or Subwoofer Output
Aug 29, 2009 | Clarion CZ109 Car CD Player
Need a wiring diagram for a clarion db185mp
SPEAKERS:
Green = Left Rear +
POWER/ACCESSORY:
Black = Ground
Brown = Phone Mute
RCA Cables:
Gray = Front Output
Black = Rear Output
Dec 27, 2008 | Clarion DB185MP Car CD/ MP3 Player
Digital clock
Here is a wiring diagram of the radio by wire color:
Radio Ground Wire: Black/Green
Radio Dimmer Wire: n/a
Radio Antenna Trigger Wire: Blue
Radio Amp Trigger Wire: Blue (Same as Antenna Trigger)
Front Speakers Size and Location: 5′ x 7′ Doors
Rear Speakers SIze and Location: 5′ x 7′ Rear Deck
Aug 14, 2008 | 1988 Ford Mustang
Stereo wiring diagram
2000 Hyundai Elantra Stereo Wiring Constant 12V+ Light Green Switched 12V+ Brown Ground Black Illumination Dark Green/White Dimmer Dark Green/Black Antenna Left Rear Front Speakers 5 1/4" Doors Left Front (+) Green/Red Left Front (-) Light Green/White Right Front (+) Red/Blue Right Front (-) Light Green/Black Rear Speakers 6" x 9" Rear Deck Left Rear (+) Yellow/White Left Rear (-) Yellow/Blue Right Rear (+) Green Right Rear (-) Green/Blue
Jul 29, 2008 | Hyundai Elantra Cars & Trucks
Sony Playstation 3 (PS3) Console Logo
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
