Question about Dell Computers & Internet
Wireless Car Issues
My wifi adapter looks to be enabled, but I can't pick up my wireless signal. I've checked the properties for the adapter and it seems to be functioning. Not sure what the problem is.
Any help would be awesome.
    Problem Solver:
  • 18 Answers
Is It XP or vista?Click on start & then run .type in services.msc
click xp check if Wireless Zero Configuration & Background Intelligent Services are enabled.If Not double click on them & enable them.In vista its WLAN.Try detecting the connections.Check if it works.Hope it works.All the best
Posted on Jun 06, 2008
I cannot enable my wireless adapter.
go to start, control panel, network and internet, then double click your network adaptor (your wifi router) click properties, write down your I.P address given to you on screen. then open internet explorer, and type that I.P address into the search bar and press enter. you should now have access to the main router settings. it could be your routers wifi setting is turned off. just go through the menu and look for it, the menu depends on the router so i cant say which menu to go to, but its normally under advanced tab. dont change anything else unless your sure you know what your doing!!
Jul 16, 2012 | Acer Aspire 4235 4240 4535 4535G 4540...
No matter what I do I cannot get onto wireless internet. There's nothing wrong with the router, I've configured it for vistas, the signal is good so it says and it says it's connected to talk...
Try this solution. 1. Go to your device manager, try to disable your wireless network adapter for awhile and enable it again. 2. Then go to wireless gaijinproxy.gif signal and click Troubleshoot problems.Apply fixed if ask. 3.if failed go to your wireless status then click and diagnose.
gaijinproxy.png 4. If still failed go to your network properties and tried to enable automatic obtain an ip address. 5. Try to reinstal drivers of your wireless adapter. 6. If none of this work your chances are to reset your router try using a usb wireless adapter just to know if your wireless are low signal or not working anymore.
Sep 09, 2011 | Computers & Internet
Wifi not picking up any signal
make sure your wireless is enabled check the fn f1-12 keys for a wireless icon, or a switch on the side of your laptop to enable wireless, lastly make sure your wireless is enabled in windows
Jun 13, 2011 | Toshiba Computers & Internet
Im not picking up any wifi at all its saying that theres no wireless network
make sure wifi switch is on on machine (some laptop comes with a button (check the edges of laptop - a small button and must be there a small blinking led )and some like dell comes with a combination of key Fn+F2 ,some times just f2) go to network properties and check wlan is enabled (for windows 7 go to change adapter settings and check wlan is enabled)
Oct 01, 2010 | Computers & Internet
Cannot connect to wireless networks, where is
First of all check these are ok: Check your network adapter settings to see if you have your wireless card enabled. If that is ok, see if you can pick up any other wifi access points apart from your own. If you can see others fine, this means your wifi card is working correctly. If you can see your own access point and not connect to it, check the signal strength, items like microwaves and cordless phones can interfere with the signal. If you have a good signal try connecting. If it is asking for a key/password, then you will need to find the authentication key for your wireless access point.
If you cannot see your wifi access point but can see others, then you may have SSID broadcasting disabled, or the wifi might not be functioning correctly. Check these in your access point settings.
May 15, 2010 | Dell Inspiron E1505 Notebook
I have a belkin n1 nimmo router. & a wireless n1 stick on my other computer and it's not picking up the router anymore it used to.and my router is saying no wireless devices doesnt apear to be...
The above mentioned scenario is not descriptive enough to assist. hence i am herewith mentioning some steps which could help you (with my assumption of what you have).
Please follow the mentioned step to check if the Wireless card is installed properly
Step 1 :
> click on start (assuming it to be a windows OS)
> right click on "my computer" and select "Properties"
> you will have the system Properties window pop-up
> under the Hardware tab, click on Device manager button
> under the device manager list look for network adapters
> you should now be able to see your wireless card under network adapter - check if the adapter is enabled ( if not kindly enable by right clicking on the adapter)
> once the adapter is active - it will have a green icon with not error on it.
Once you complete the above task you may follow the below mentioned step.
Following the below mentioned step will help the Microsoft to take control over the card and try to connect (instead of the software provided by the card manufacturer to control the device)
Apr 27, 2010 | Belkin N1 Wireless-N Wireless Router
Low signal strength
Low signal strength could be an issue of the Wireless adapter. Check the property page of the Wifi card and in the Network tab check for the freequency ex: 802.11 b/g if the wifi supports the freequency to the max which is to be set.
Usually this issue happens when you have a wifi card or driver Installed.
Feb 13, 2010 | Computers & Internet
How do I enable the wireless on my Acer Aspire one?
Open control panel scroll down to Internet connections and click to display. Right click wireless wizard then click choose enable. After this you will be prompted with a box that will show you that the computer has detected wifi connection in the surrounding.
Jun 22, 2009 | Acer Aspire One PC Notebook
Wireless does not work on hp pavillion ze 2000 after xp reinstall
Try this to check the wireless.
Click on start> Control panel> network and internet connection> from left pane click on view network connection after that right click on the wireless adopter icon and select enable.
this will resolve the issue if it is not helpful
try to check wireless driver from
1) Go to Start, right click My Computer and then click on Properties.
2) System Properties window will appear. Go to Hardware tab and click Device Manager.
3) Device Manager window will appear, and you can check all hardware drivers' status here. Scroll down and look for Network adapters and expand it, then right click the wireless adapter you want to check and click Properties.
Nov 24, 2008 | HP Pavilion ze2000 Notebook
wow! thats a very nice wifi card. prism.
anyway, here is a link for your windows 2000.
this connects you to any wifi hotspot other than boingo.
Mar 27, 2008 | Fujitsu LifeBook P1120 Tablet PC
Computers & Internet Logo
90 people viewed this question
Alun Cox
