Question about KitchenAid Refrigerators
Kitchenaid superba fridge cooling performance is low. It looks like internal fan does not work.
  • 828 Answers
Replace or have the fan replaced by a service tech. Also check for frost build-up in the freezer compartment. This will also ****** air circulation.
Posted on Jun 01, 2008
Kitchenaid superba making noise
Check the fan on the back and blow air through it to clear any dust accumulation.
May 04, 2017 | KitchenAid Superba KSRG25FK Side by Side...
Refrigerator is not working. The bottom of the freeze is working but the rest is not. The airflow fan motor was replaced.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
Jul 05, 2011 | KitchenAid Superba Architect KSCS25INSS...
Hi, I have a KitchenAid KSRB25FKSS02 and our refrigerator is not cooling and it is already set to the coldest setting, but our freezer is working just fine.
This is a fairly common problem and is likely caused by the failure of a concealed fan that is responsible for distributing cooled air from the freezer section to the refrigerator side.
SearsDirect parts department has full information on your KitchenAid fridge at the link below:
The fan I suspect is shown here:
Distribution parts
Looking at the various pages should give you an idea if you consider this a DIY task or call a pro.
Jul 04, 2011 | KitchenAid Superba Architect KSCS25INSS...
The divider between the freezer and fridge is hot to the touch. What is wrong?
there is a problem with your cooling fan motor in the lower back of the fridge it is either blown or has jammed.
Jul 13, 2010 | KitchenAid Superba Architect KSCS25INSS...
Freezer works great but food is spoiling and not cold enuff in fridge. dosent seem to be air flowing out of vents in the side in fridge. is there a fan that quit or could it need freon
when you fridge is running open the freezer door and listen for a fan there may aslo be on ein the fridge compartment,also look for frost build up on the back wall of the freezer.if there is ice build up you need to defrost it.when the unit is in the cooling mode and you do not here the fan running on the inside of the unit the the fan needs to be replaced.
Jan 31, 2010 | KitchenAid Superba Architect KSCS25INSS...
Kitchenaid Superba Side by side, refrigerator side not cooling
Assuming that your fridge is set at max thermostat setting, and still it cools to 8 degrees only. It only mean
one thing, and that is have your refrigerant level check,
and have it loaded. E-mail to us your comments.
Oct 07, 2009 | KitchenAid Superba Architect KSCS25INSS...
Ksrs25ikss01 kitchen aid fridge portion not
1.check if the fan inside the freezer is running
2. if ref runs none stop, defrost timer is out.
3. or it could be the high limit that paired in series with the defrost heater
good luck!
Jun 25, 2009 | KitchenAid Superba Architect KSCS25INSS...
Freezer works fine, fridge is not cooling. Side by Side KitchenAid Superba - KSRS25C
sounds like fridge fan is out,sometimes they stick and do not send cold air to otherside,replace or repair.
Apr 24, 2009 | Refrigerators
Kitchen aid superba fridge not cooling
Check your evaporator fan, defrost thermo., or defrost heater. One of these parts out are what causes ice to buildup on your evaporator.
Sep 01, 2007 | KitchenAid Superba Architect KSCS25INSS...
Refrigerators Logo
75 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
