Question about Kenwood Car Audio & Video
I have two different amps, one for my subs, and one for my mids/highs. One day, my mids and highs cut out, and nothing is coming out of them. Only the subs are working. I checked the amps, and the fuses, everything has power. I'm not sure if it's a setting from the deck or what. It happened once before about a week ago, and what I did was turn it off, and then turn it back on and it worked. But this time it's not working. I hope you can help me with this.
  • 70 Answers
I tried disconnecting everything from the amps and re-connecting it and it worked
Posted on Jun 12, 2008
When playing a record, the preamp does not produce a powerful bottom end. There is not enough power coming from the bottom. Only the highs and mid range are clear
pre-amps do not produce bottom end (subs) that is the job of the main amp, but then again, these days, it's all built into one unit
audio reproduction is 99% good speakers - i can deafen you with a 9 watt amplifier,, with the right speakers
Feb 28, 2015 | Audio Players & Recorders
My mids and highs have cut off but my subs still work
are mids and highs amped? if so check fuse. many people forget about fuses. if running off head unit only, then the internal amp in the stereo in probably burnt up. if this happened you can run an external amp from the front rca outputs and problem solved with better sound than before!!
Jan 08, 2013 | Car Audio & Video
How do I hook up subwoofer sony cxs-gt08hp
NO!!NO!!NO!! Dont hook up just a sub to rca outputs. they run at around 2-3 volts and maybe 1 watt. the difference in the settings is for a sub amp(sub) or a amp for mids and highs (amp). the only way you will not need to run an amplifier is if you get a powered subwoofer, as these already have an amp built in.
Dec 24, 2012 | Sony Car Audio & Video
I put a sub in my 2002 Altima but when I turn it up the bass cracks on the door speakers??? What do I do to get all the bass on the sub
Hi Ethan,
What you're looking for is called a "crossover". A crossover is an electronic filter for an audio or speaker circuit. In an audio circuit, a crossover is used to prevent or pass certain frequencies or a range of frequencies from passing through it. Since your sub will reproduce the bass or low frequencies, you don't want other speakers to reproduce them. A band pass filter on your door speakers will do this for you. A band pass filter passes only a range or "band" of frequencies and blocks those that are above and below the range or band of frequencies selected. Installing a band pass filter will prevent the very high & very low frequencies from getting to the door /dash speakers. Likewise, you should consider connecting a low pass filter to your subs, too. The low pass filters work a little differently from of the way band pass filters work - they only allow low frequencies to get to the sub - blocking all the other higher frequencies (your other speakers are better suited to reproduce those). Lastly, you would install a high pass filters on tweeters. Tweeters are designed to reproduce only the high frequencies - sending mid and low frequencies to them is wasting power and can cause damage to them.
You purchase the filters for specific crossover points (the block / unblocked point) as determined by the individual speakers. If a sub has a frequency response of 20Hz - 100Hz, a low pass filter of 100Hz would be ideal. Remaining filters would need to begin at 100Hz - assuming the mid-range speakers have a frequency response beginning at 100Hz. A band pass filter of 100Hz - 3KHz would fit the bill nicely if the mid-range speakers go up to 3Khz Match the high end of the band pass to the high end of the frequency response of the mid-range speakers. Next, a high pass filter at 3KHz would allow only the high frequencies to your tweeters. Basically, you want to have the entire audible range 20Hz - 20KHz covered by the speakers and have the crossover points that match the frequency response ranges of the speakers.
I hope this helps & good luck!
Apr 12, 2012 | Pioneer Car Audio & Video
I Have a Gem Sound EVA3955 amp an TR-150 subs sub stop wroking
Yes and Yes. If bypassing that noise filter, has no effect your subs could have blown.
Jan 05, 2010 | Car Audio & Video
Sub Selectroin
try to find a the specs for a box for those subs. A box has a great deal to do with highs, mids and lows.
Jan 09, 2009 | Car Audio & Video
I plugged int he rca's but he the lowest sounding bass possibe
kicker subs arnt ment to hit the lowest bass, unless you go spend a **** load of money, im talking 3000 wat amp, ant some 15' or bigger subs. the most commen kickers are 12' subs, so im asuming you have 12' subs, if not, this (said lightly) should work. try turning the bass boost screw on the amp to the middle of its turning range. this will offer the greatest balance between high and low bass. if you want more low bass, turn it past half. if you want more high bass, turn it down. i have mine set to mid range, but i also recently purchased 2 18' kickers. with every new set of subs, you should spend at least 15 min tuning the amp to get the best performance. every sub is different. hope this helps, good luck.
Jun 27, 2008 | Kicker KX800.2 Car Audio Amplifier
Sony Xplod 500w green power light no sound
try running the system with a cross-over configuration.
So your left + will be left + and your right + will be in the right + but put the right (-) where the left (-) is and left (-) where the right (-) is. If that doesnt work, then that means that you shorted out your audio out channels. the only way you can fix that is if you have good soldering skills. But other than that I'de say scrap it, unless you have the high outputs and then buy another amp, some mids and highs and connect the mids and highs to the xplod
Feb 23, 2008 | Sony Xplod XM-1652Z Car Audio Amplifier
Off and On at mid and high volumes
sounds like you have a problem with your grounding on you amplifier. check for shorts on your amplifier and the place where you have it grounded. (or check the power wire also.)
Nov 01, 2006 | Kenwood KAC-7202 Car Audio Amplifier
Car Audio & Video Logo
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
