Question about Blue Microphones Snowball Professional Microphone
I can not get my bluesnow ball microphone to connect with my cubase studio 5
  • 3 Answers
How to use USB device like a USB microphone, or USB guitar Cable in CubaseThis was a frustrating problem for me and I found most forums did not really helpAfter hours of annoyance I finally figured it out and it's a very easy and quick fix.1.Download free ASIO4ALL 2.8 here http://download.chip.eu/en/ASIO4ALL-2.8_108174.html and then restart cubase2.Click Devices and Open Device Setup3Click Vst Audiobay and Change the Master ASIO Driver to ASIO4ALL v24.Underneath Vst AudioBay Click ASIO4ALL and Click Control Panelhighlight All devices you wish to use and Enable them.5.Still in Device Setup hit VST Inputs and check to make sure all Devices are there6.Exit Device Setup and under the Devices open VST connectionsClick add bus, and Add Busses. Your Sound Device should be the first Bus that pulls upand the other busses will automatically be whatever the USB Devices you enabled were.7.Last thing and very important, when you open up a new Audio track Right click where it shows Stereo in. Your usb devices will start at stereo in 2 and depending on how many you enabled go up in numbers from there.In my particular case I have a Blue Snowball usb mic as my first Device (stereo 2)and a Usb Guitar Cable interface as my second device (stereo 3)*If you would like to hear and test your sound prior to playback simply click the monitor button and unclick it at playback.That simple, there you go.This will work, takes and takes less than a minute.
Posted on Dec 16, 2010
Heres the link http://amzn.to/2jjpYRWi can not get my - 9_12_2017_4_07_18_am.jpg
Posted on Sep 12, 2017
I NEED THE ELICENSER CODE FOR CUBASE STUDIO 4 MAC
Fixya will not give out any serial numbers, Activation Codes,
or Key Codes. It is illegal to pirate software
Oct 08, 2012 | Steinberg Cubase Studio 4 Upgrade Version...
How do i get levels from my g track mic im using cubase le 5 i only get one side level how do i fix this issue?
The mic is only on the Left channel, and instrument input is on the Right channel. So in Cubase you need to select only the Left channel in your first track, and then only the Right channel in your second track, and then you can record Vocals and Instrument at the same time on 2 different tracks.
May 02, 2011 | Samson G-TRACK USB RECORDING MICROPHONE...
Using a Tascam US 122 with Cubase SX, when recording vocals red light (clipping) on the Tascam and in the Cubase mixer, I need to know how to set levels on Tascam, so there will be no clipping on vocal...
Make sure the switch is set to "mic/line" and not "guitar"
Your input level will be set by the "input L" or "input R" knob, depending on which side you are using. Start with them all the way down and then sing into the mic, turning them up until you get a signal about halfway up the bar in Cubase. That should give you plenty of headroom for clean vocals.
It may be difficult to get a good sound if you have one of those cheap mics that has a "1/4" jack instead of a 3-pin XLR jack. You might want to go to your local music/pro audio store and invest in a "condenser" microphone, which is good for vocals in the studio.
Feb 26, 2011 | Tascam US122 Audio/MIDI Interface with...
Crackling and popping during playback/recording, latency issues. Using Firestudio Project, Windows 7 and Cubase 5.
Turn OFF all resource hogs such as Anti-virus, Anti-pop-up, and other background programs. Disconnect all internet access such as wireless and Ethernet service programs. All these resource hogs and programs for instance that keep track of when to run scans just cause interrupts of the servicing of the high speed audio grabbers. Your machine should be BARE of all these hogs.
Feb 23, 2011 | PreSonus Firestudio 2626 26x26 + Cubase...
How do i get my samson c01U mic to work with windows vista and cubase le?
plug your condenser microphone into your computer before starting up the cubase program; then after you plug it into your computer start cubase; when cubase loads, press the [F4] key, then that will bring you to the audio configuration menu, there will be a speaker option and microphone option or what ever that stuff is; go to the microphone option and choose the microphone that you are using, then after you choose your microphone setting click close; then after that make create a [audio] then on the audio tab you will see a red button, by pressing that it will allow you to record, but there is another button beside it called a [monitor], press that button then it will allow you to hear your voice while you record your vocals. hope this help.
Apr 21, 2010 | Samson Audio C01upak C01u Microphone and...
Where can I get a cubase studio 4 operation manual?
English
Download PDF
ZIP Package
31 MB
(in this zip file you will find:
  • Getting_Started.pdf
  • Mackie_Control.pdf
  • Menu_Reference.pdf
  • MIDI_Device.pdf
  • New_Features.pdf
  • Operation_Manual.pdf
  • Plug-in_Reference.pdf
  • Remote_Control_Devices.pdf )
If you need an other language other then enlgish go to
http://www.steinberg.net/index.php?id=882&L=1
please mark this fixya if it was helpful.
Dec 04, 2009 | Steinberg Cubase Studio 4 for Mac/Win
Omega Studio won't record to computer
The omega is like an external sound card. It has to be connected via your computer with a device driver,the software that came with the lexicon. Then you record on a software program such as Cubase.
Go to the guitar center for more help or go to google .com and type in lexicon omega. Lots of sights to look for answers or better yet go to lexicon omega's home site.
Feb 28, 2009 | Lexicon Omega Desktop Computer Recording...
Cannot record
Im having the same probz, got a Hp Pavilion Vista using mobile pre amp usb when i record using a condenser mic XLR nothing is picked up from the channels in Cubase or Nuendo. Im trying to record vocals but the Mic is not picked up and i cannot hear myself in the headphones and it wont transfere to cubase.
It has worked before when i had a desktop, but this only worked with a separate m-audio sound card inside the desktop and i plug in the output jax leads from the desktop (soundcard) to the m-audio usb pre amp
Is this why it is not working for the laptop do i need a Jax connection and where is this audacity
Sep 15, 2008 | M-Audio M AUDIO MOBILE PRE - USB MIC...
Tascam us 144
make sure you select it as the interface device in cubase.
Thanks,
Nate
Mar 27, 2008 | Tascam DP01 All-In-One Recording Package...
How to use blue usb mic
It depends on your operating system, but in XP, open Cubase. Go to the audio input settings, and be sure to select "USB Audio Codec" or "USB Audio Microphone" as the input device.
In Vista, right click on the speaker icon in the taskbar (usually lower right hand corner of the screen) and select "Recording Devices". Make sure to select the "USB Audio" device, then try Cubase again.
Dec 25, 2007 | Blue Microphones Ball Professional...
Blue Microphones Snowball  Professional Microphone Logo
1,323 people viewed this question
Top Blue Audio Players & Recorders Experts
Colin Stickland
Colin Stickland
Are you a Blue Audio Player and Recorder Expert? Answer questions, earn points and help others
