Question about Sceptre X9G Komodo IV 19" Flat Panel LCD Monitor
Schematic Diagram for Sceptre X9g monitor - Sceptre X9G Komodo IV 19" Flat Panel LCD Monitor
  • Klove Oct 12, 2010
    Jay,
    The pictorial parts id is a help, but to track down and understand my problem I need the interconnection diagram. My monitor seemed to stop recognizing video and would not "wake up when video became present". For a day or two prior to total failure, it would vacillate between "no video present" message and shut dpwn. Finally, it was total shutdown. I did have a rapidly blinking green pilot light
    As it is, I have no idea of which component fits where in the chain to even troubleshoot. If this is a problem common to this unit, perhaps you could suggest where to start.
    Thanks,
    Kellie Love
  • Klove Oct 21, 2010
    Model X9g
  • 15,935 Answers
What is the model # please?
Thanks!
Posted on Oct 12, 2010
  • 857 Answers
Check This out and see if it helps you.
Power outage at home. Monitor (Sceptre x9g) no longer powers up.
pop the back off of it and remove the power board, (it's the one that looks more primitive) look at the solder points on the back of the board for any burns or bubbles....
if not then you need to order a new power suply
Feb 06, 2011 | Sceptre X9G-NagaIV 19" LCD Monitor
Sceptre x9g naga v
May i know the exact detailed model/maker of your unit...?
Jun 13, 2008 | Computers & Internet
I have a sceptre x9g-naga III
Not an expert, but from what Ive read, this is a cfl inverter issue. I had the same problem on my Sceptre. Good luck finding parts. My solution: get another monitor.
Feb 27, 2009 | Sceptre X9G-NagaIV 19" LCD Monitor
Sceptre X9G-NagaV
I had a word with a technician of these boards, and R88 and C63 are factory removed.
Jan 28, 2009 | Sceptre X9G-NagaIV 19" LCD Monitor
Sceptre x9g nagaV
you cannot connect your vga monitor to your rca vcr its not compatible unless you have a vga to rca converter
Nov 03, 2008 | Sceptre X9G-NagaIV 19" LCD Monitor
Sceptre X9G Komodo IV 19" Monitor
Hi dgp1952, Check with www.lcdrepair.net if you want a repair. Something is wrong with your backlight or the circuit supplying power to it. If your technically endowed, you may want to open the monitor case and clean the dust and lint from around the circuits using a Small paint brush to sweep away any built up dust. Dust can cause the circuitry to heat up faster and put the power supply into Clamp mode. Clamp mode will turn the supply off to certain circuits which may be the reason your display is going black after 5 minutes.
Oct 09, 2007 | Sceptre X9G Komodo IV 19" Flat Panel LCD...
Sceptre X9G-Komodo IV
I recently came accross one of these monitors (Planar PE191M) with the identical issue. The resolution was to replace the two 470ufd 25V capacitors that are located on the main power board. The main power board also contains the audio circuit and more importantly the inverter circuit that drives the CCFL backlighting. The suspect caps were identified using an ESR meter; if you happen to have one of these meters you can confirm this is the issue with your unit(s), alternatively you can just replace the two capacitors and see if it resolves your issue. Hope this info helps someone out there.
Sep 05, 2007 | Sceptre X9G Komodo IV 19" Flat Panel LCD...
Sceptre X9G Komodo IV 19" Flat Panel LCD Monitor Logo
404 people viewed this question
Top Sceptre Computers & Internet Experts
Cleverer2
Ricky Ostrom
Ricky Ostrom
Are you a Sceptre Computer and Internet Expert? Answer questions, earn points and help others
