Question about Dishwashers
Hi, in my Whirlpool dishwasher series 280-0, the dish-washing powder is not used, as it fully remains in the dish-washing box inside the door of the washer.
  • 65 Answers
SOURCE: Whirlpool gold dishwasher leaves film on dishes
are you in a hard water area such as florida ? do you have a water softener? if so take a can of frozen concentrate orange juice and put the frozen hunk in the bottom of dishwasher and run for one cycle. the citric acid will dissolve undisolved soap . this works much better. than vinegar which will only remain through the first cycle and then drain out as for the already grey glasses wash them in a solution of equal amounts red wine vinegar and water with just a touch of dish soap using a sponge.
Posted on Feb 16, 2008
  • 6 Answers
SOURCE: dishwasher powder/tablet not being used
Yes
The problem is not enough water presure is hitting the soap dispenser. Probably the top rack of dishes is not getting clean either! look for my post about fixing with CLR and use that see what happens then
Thanks
Kashif.A
Posted on Mar 07, 2008
MNfisherman
  • 11896 Answers
SOURCE: Maytag Quiet Series 300 dishwasher, dishes come out dirty
A water softner will not make the dishes any cleaner, it just makes it so they don't have water spots on them.
If the dishes are dirty, it is most likely that the nozzles (holes) in arms may be plugged.
Also check to make sure you are getting plenty of water to dishwasher. Make sure all water valves are full turned open.
If the control panel does not work all the time, it is very likely you have either a shorted wire, or a fualty main board which is very common in newer machines.
Posted on Jun 01, 2009
  • 677 Answers
SOURCE: White film inside the dishwasher and on dishes
Hard water is the reason for the spots. There is a new product out at www.dishwasherfilter.com that is made specifically to fix this problem. It filters the water going only into your dishwasher leaving your dishes spot free with every load. It is very affordable and guaranteed to work or your money back. You will love the way your dishes look after the very first load.
Posted on Jul 30, 2009
SOURCE: new dishwasher leaving powder residue on dishes.
Quit using the new Cascade. The formula change is what is causing the problem. No research from Cascade before releasing the product
Posted on Aug 29, 2010
My dishwasher model FFD612EMBGS keeping half of the detergent in its location it dose not take it fully and some detergent powder snag on the dishs
Check to make sure you are not blocking the soap dispenser door with a large platter or pan in front of it. The water will not be able to wash out of it.....
Jan 29, 2014 | Frigidaire FFD612EMBGS DISHWASHERS FOR...
I have a built in whirlpool dishwasher. My problem is that dishes aren't being washed properly, there was water in the bottom of the washer, I removed and cleaned the filters ran the machine and the water...
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher
Spray Arms not Spinning
How to Buy
Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Heating Element not Working
Dishwasher Maintenance
Dishwasher Residue and Film on Dishes
heatman101
Jan 25, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
White powder residue left on dishes after washing. I run hot water before running dishwasher, use Cascade powder (fill dispenser less than 1/2 full per installer and do not use prewash detergent...
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
heatman101
Nov 10, 2010 | Whirlpool DU805DWG Dishwasher
After the dishwasher runs there is a lot of soap left in the soap dispenser. I've tried powder and liquid. Liquid is a bit better. I've tried using less soap but there still is a lot left. Also my glasses...
With the LG LDF6810 model, this is not a common problem. Please try the following test, With and empty dishwasher, add a small to normal amount of dry dishwasher powder and run an (empty) load.
Check to see if any soap remains in the dispenser cup.
If any remains, here are three things to do: 1.) Upgrade your dishwasher detergent to a name brand powder (e.g.: Electrosol or Cascade)
2.) When you load the dishwasher, do not place large items in the front, near the door/soap dispenser.
3.) Before you load the dirty dishes for the next several loads, with your hand, turn both the upper and lower wash arms so they point at the door. Load as you normally do and push the racks fully in. Before you close the door, spin both the upper and lower arms and confirm that they spin freely and neither hits anything. if either does not spin freely, pull out the rack and arrange so the arms can spin freely.
I find that the only time I have left over detergent powder is when the wash arms do not spin freely.
This is a common problem on most every energy star/water conserving dishwashers.
Please report back what you find, OK?
May 21, 2010 | LG LDF6810ST Stainless Steel Built-in...
My whirlpool dishwasher soap dispenser is apparently not opening during cleaning. I find dirty dishes and clumps of soap in the hopper. Whirlpool quiet partner II
I bet your clumps of soap began with the beginning of the use of a different DW detergent powder.
Try this (trust me) Go buy a box of brand name Dishwasher powder (e.g. Electrosol or Cascade) Use it for two loads of dishes and report your results back here. OK?
Apr 17, 2009 | Dishwashers
Does this model fully drain?
Switch immediately to a Brand Name Dishwasher powder (like Electrosol or Cascade.)  Avoid gels, tablets and never use a dish soap that is meant for washing dishes in a sink.  This will solve the "bubbles" problem.
Yes, dishwashers do maintain some level of water inside to keep the pump seals/gaskets from drying out or seizing. As long as the water down there is clear and has no odor, you and your apartment's dishwasher is fine.
OK?  Post back with any more questions.
Apr 14, 2009 | Dishwashers
Dishwasher problem
Symptoms:
Dispenser lid is open. Caked powder at (what would be during normal operation) bottom edge of soap dispenser or caked powder fallen onto dishes or dishwasher bottom. There may be loose powder in rest of dispenser or spilled down inside door or onto dishes underneath dispenser.
Solution:
Keep the area around the soap dispenser lid clear when loading the top tray.
Explanation:
The soap dispenser needs to swing open during the wash cycle. In many dishwashers the top tray has an indentation as wide as the lid of the dispenser. This allows the top tray to be as large deep as possible while still allowing space for the dispenser lid to open. People often pack their dishwasher with things overhanging this gap.
During the wash cycle the catch will release but the overhanging cutlery or crockery prevents the lid from opening all but a few degrees. Some water will splash in but not enough to wash out the soap powder. The soap powder at the bottom of the dispenser will then cake.
When the front door is opened the spring loaded lid, which is partly open, will of course swing fully open and you'll be convinced that the lid opened normally during operation. If this is the problem then if you're very careful and open the door very slowly you can actually hear the lid flip open. Also, depending on when the lid opens, how far it opened during operation and how fast you open the door you may find soap powder spilled down to cover the dishes at the front or down the inside of the door. This happens when you first open the door and obviously there couldn't be loose powder there if the powder had emerged while there was water washing around. Seeing the lid open as you open the door is a lot harder but can be done on some machines.
Oct 24, 2008 | Whirlpool 24 in. DU1100XTP Built-in...
Silverware becomes cloudy and is difficult to polish
The new water-conserving dishwashers, including the LG LDF 7811 are very sensitive to the dishwasher soap that is used.
If you notice white staining beneath the soap dispenser at the end of each full wash and possibly undissolved powder remaining in the dispenser, I recommend you stop using that powder and buy a box of Electrosol or Cascade powder and use it in place of what you currently use. Avoid using gel or tablets in all dishwashers.
I experienced very similar problems with the LDF8812 that I personally own. First step to fix was pulling the filter (10 phillips screws) rinsing the filter as best possible, remove all debris. Replace filter and spray arm.
Place a bowl filled with white vinegar in a bowl on the rack of the empty dishwasher. Run a quick wash cycle to the end.
Look closely at the RinseAid cap inside the door, remove it and turn the little dial to a lower number. Over time, adjust it up if dishes are not drying properly.
Use the dishwasher normally - do not overly pre-rinse the dishes because the food particles are actually used during the wash cycle to help clean the dishes. Also, do not over load the dispenser cup with soap. A Tablespoon will do it. If you run out of the rinse aid, feel free to use white vinegar.
Oct 21, 2008 | LG 24 in. LDF 7811 Stainless Steel...
Dishwasher
If you are you using a liquid soap or packets that will be the main problem.If your unit fills with water circulates the water and drains the water,and also heaters are working then you probally need to change to cascade powder soap.The film on the dishes is soap.The unit has so much build up in it that when it gets to the rinse cycle it is rinsing dishes with soapy water.You need to get 2 medium bowls fill both 2/3 up with white vinager,place one in upper rack and one in lower rack and run unit on longest cycle letting the vinager splash out during wash.do this with no soap and no dishes.Having soft water will allow you to use less soap.
Apr 23, 2008 | Dishwashers
GE Monogram DIshwasher
Before taking anything to bits, check you aren't just loading the machine in such a way that something (for us, it's usually a frying pan) is stopping the soap dispenser from springing open all the way. A.
Apr 21, 2007 | GE 24 in. Monogram ZBD6880KSS Stainless...
Dishwashers Logo
120 people viewed this question
Top Dishwashers Experts
