Question about Beverage-Air Beverage Air 72'' 3 Door - 18 Pan Sandwich Prep Table
Cooler leaks water inside. - Beverage-Air Beverage Air 72'' 3 Door - 18 Pan Sandwich Prep Table
Why is there moisture leakage from inside my cooler?
The drainage pipe is blocked or dirty. You will have to find it to unclog. Or find the water drainage container at bottom the in the drain pipe ther blow throw to unclog.
Aug 03, 2015 | Refrigerators
POOL OF LIQUID FROM VESTFROST WINE COOLER ON FLOOR
it's not the refrigerant - that is a gas. It may be water from inside, or oil from a leaking pipe. If it's oil it's not a diy job
Apr 15, 2014 | Breezaire WKL 4000 Wine Cooler
Getting oil in the water
if you are getting oil in the water but no water in the oil the cooler inside the radiator is leaking. If the oil has redish to brown color it is the trans oil cooler leaking
Mar 27, 2014 | 1997 Dodge Ram 1500 Club Cab
Water dripping from inside top to bottom of cooler what is causing this and how can i fix it?
Coolers like yours create a lot of condensate. Every time the door is opened warm moist air enters and changes back to a liquid state on the evaporator coils behind the fan and area you see moisture dripping down from top and back wall should be going down a drain pipe to the bottom of cooler and into a pan where a fan blows warm air over the condensate/water returning it back into the store or business that the cooler is located. Looking inside there shoud be a tray or pan that is at the base of the evaporator. True uses different parts but you need to see why the water is leaking from. If cracked tray or line blockage causing overflow into the cooler. Click Here=> Leaking Refrigerators and then again here=> Leaking Refrigerators! This will help you get a better idea of what I am talking about, if helpful please rate. True MFG. does not share their information to me. I would need to be their registered customer to get answers. Click Here=> E-mail True Technicians I also think if you have questions for them they ask for your model number as a reference. They Will answer you just need that number along with GDM-72-RC I will be here if you have questions, Thank You, Sea Breeze
Oct 13, 2011 | True GDM-72-RC Refrigerator
Marvel wine cooler leaks water
All coolers produce water as a result of condensation which occurs when air is cooled. The water appears upon the radiator (technically called the evaporator) inside the cold area of the cooler. When the water drips off of the radiator, it is caught by a pan which may or may not be a removable piece. The pan should lean toward the rear of the cooler and the water should pour into a drain tube. The drain tube should lead down into the compressor area of the cooler and deposit the water into another pain which is outside of the cooler where it should evaporate back into the air. Sometimes "cardboard" fins are used to help the water evaporate. Sometimes a pan with a huge surface area is used to help the water evaporate. Other times the pan is literally on top of the compressor. Make sure the cooler itself is level. Make sure room air is able to move over the pan where the water is supposed to evaporate. Make sure the drain hose is not clogged. Make sure pans are not leaking.
Jun 11, 2011 | Marvel (6SBARBSG) Wine Cooler
It leaks water from underneath
It is not really leaking water (did you put water inside?) ... that is probably condensate ... a by product of the cooling process. Are you in a high humidity area? If yes ... that is the primary reason for this water.
Here in North America, we think that only white wine should be chilled and then only to 'celler' temp (or about 55 degrees F.
You may be able to reduce the water problem if
(1) up the temp in the cooler (it isn't a refrigerator - don't use it as one)
(2) don't put 'hot' wine inside
(3) put a small fan blowing on the cooler to help evaporate the condensate.
If the water is a big problem, sit your frig on a big tray, similar to the one you might put under your car in the garge to catch dripping oil.
I hope you find these suggestions helpful.
Thanks for visiting and please come again.
Feb 05, 2011 | Haier BC112G Wine Cooler
Transmission fluid level need regular top up and there is no external leak.Fluid color looks white.
If no external leak and the transmission fluid colour looks white, the problem belongs to the automatic gearbox oil cooler. The oil cooler has broke mixing the gearbox oil and coolant causing this milkshake. It's a small radiator core type oil / water heat exchanger. It is cracked inside and transmission oil is mixed with engine coolant. Because the transmission oil pressure is greater than engine coolant pressure, the transmission fluid level drops. See also the coolant colour inside recovery coolant reservoir inder bonnet! It could be like this:
The automatic gearbox oil cooler type oil / water heat exchanger (oil cooler):
(In the picture above the transmission oil pan was removed for oil filter replacement).
Oct 29, 2010 | 2005 Audi A4
Advise
you need to purge the air out of the "hot" side after placing the bottle on top. If not enough water is inside the chamber the water will boil.
Jul 07, 2008 | Hamilton Beach Water Cooler with Storage...
Water Dispenser hamilton Beach Water Cooler
my water cooler worked yesterday,today I get nothing from either the hot or cold water? Is this a simple fix or di I start with a new one?
Jun 02, 2008 | Hamilton Beach Water Cooler with Storage...
Refrigerators Logo
Top Beverage-Air Refrigerators Experts
Dennis Boxerman
John Tripp
John Tripp
Are you a Beverage-Air Refrigerator Expert? Answer questions, earn points and help others
