Question about LG WM-2277HW Front Load Washer
Has OE flashing and will not run - LG WM-2277HW Front Load Washer
  • LG Master
  • 3,051 Answers
Hello there:
"OE" Drain error. Cause: not fully drained within 10 minutes Check there isn't a kink in your drain hose, ensure the filter is clean, the drain hose can become clogged with sludge, sometimes a hot wash with 1/2 a cup of vinegar will remove this sludge
Posted on Oct 12, 2010
  • 2 more comments
  • freddyOz Nov 11, 2010
    Check that the pump isn't faulty (a common problem if the water will not drain).
  • sawilliamson Nov 21, 2010
    How do you check if the pump is faulty or not.
  • terrybeck Nov 24, 2010
    My LG front loader is coming up with the exact same error message, it's only 4 years old, I'm ready the throw the washing machine away, I will never by an LG washer again. My husband is going to attempt to pull it apart over the weekend and see if he can find out why it keeps constantly coming up with that error message.
    The drain pipe isn't blocked and the filter is clean, so what is it's problem????
    I'm confused as to why sometimes it washes fine, other times the error message can display up to 4 times or more during one load, as soon as I hear the warning beeps, I pause the machine, then unpause it, then take the end off the drain hose, and start to drain most of the water out, then I replace the end and it sometimes finishes the rest of the wash ok, but lately I've had to do this up to 4 times nearly every wash, I'm so over it!!!!!
  • freddyOz Nov 24, 2010
    Do check out the pump. The pump on my Westinghouse washer behaved in the same way (sometimes working and sometimes not with OE flashing) until it failed to work - the machine would work till it came to the pump out water cycle.
  • 3 Answers
To check if the pump is faulty, remove the pump from the machine, and check the voltage required for the pump motor. In Australia this is 240V AC. You will need to make up a lead and put the required voltage across the terminals - if the pump impellor fails to spin or makes a lot of noise, the pump is obviously faulty and needs to be replaced. Note that the voltages required for the pump are very dangerous, and can be lethal. If you are not qualified to handle the voltage, you should get a qualified technician or electrician to simply test the motor for you. If you have removed the pump from the machine (which you will need to do to test the pump), the actual testing of the pump should only take a minute.
Posted on Nov 22, 2010
OE flashing and not draining
Here is a tip that I wrote that gives more detail about how to fix the OE codeon LG washers....
LG Washing Machine OE Error Code
heatman101
Aug 16, 2011 | Washing Machines
My washer wont unlock so I can get my clothes out, and at the end of its cycle it flashes OE...how can i fix it?
heatman101
Aug 11, 2011 | Washing Machines
My tromm LG front load washer is flashing OE, what is it.
heatman101
Jul 19, 2011 | LG Washing Machines
I have a Westinghouse Mastermind 711 Front Loader Washing Machine which is flashing OE and the clothes inside are very wet. Can you please let me know what this flashing OE means....Many Thanks, ELena
Hello & Welcome to FixYa
OE is a drain error and is displayed when the washer is unable to drain water. Please check the drain hose and drain pump filter for any clogs to clean the error. Please get back to me if you have any other questions.
Kevin
May 27, 2011 | Westinghouse Washing Machines
My lg washer will not spin out it keeps flashing OE no matter what i do
Here is a tip that I wrote that gives more detail about how to fix the OE code on LG washers....
heatman101
Sep 02, 2010 | LG WM-1832C Front Load Washer
What does oe mean on the front loader lg tromm and how do I fix it?
Not sure what the OE is, but I;ve been having the same letters flashing on my washer this week. I checked the filter at the bottom and it was totally plugged up ! I would check your filter.
Jun 10, 2010 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Lg washer oe error
On LG washing machines, the OE flashing code means there is a drainage problem. hope that helped.
Please Rate Me
George
Apr 28, 2009 | LG WM-2277HW Front Load Washer
OE what does this stand for
oe stands for outlet error possible solutions are : drain hose kinked , filter blocked or the pump impellor is blocked.
Jan 02, 2009 | LG WM-2277HW Front Load Washer
My front load Tromm LG washer flashes OE message, won't drain or finish wash. Door does open
oe is an error code for pump problem disconnect power cord open small door on lower front of cabinet pull little tube out and plug from tube and drain water in to bucket after water is drained unscrew cap of pump to clear out any obstructions reinstall the cap and plug and give a test run
Dec 20, 2008 | LG WM-2277HW Front Load Washer
LG WM-2277HW Front Load Washer Logo
730 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
