Question about LG Washing Machines
I have a leak in the cold water value of my LG WM2016cw washing machine. I am in need of a part number to order same.
  • LG Master
  • 4,654 Answers
That should not be too hard to find Click here=>Your part number is 5221ER1003A You can find your part here=> 5221ER1003A Water Control Valve
If you need additional help feel free to ask me, Thanks Sea Breeze
Posted on Oct 12, 2010
  • John Tripp
    John Tripp Oct 28, 2010
    Thank You For The Rate! Sea Breeze
Washer from flashing 1E & leaking
LG Washing Machine Displaying Fault Code IE or 1E WM2016CW WATER INLET ERROR // Water not entering washing machine correctly
The manufacturer has assigned this error or fault code to indicate that the washer is not filling with water. Check to be sure the water supply valves are open. Also, check to be sure the water supply hoses aren't kinked or clogged. Next, remove the hoses from the washing machine and run water into a bucket to test the pressure and flow of the water. If all of these check out and you have good water pressure and flow to the machine, you should replace the water inlet valve.
Aug 02, 2015 | LG WM2016CW Front Load Washer
What are the most major issues with lg wm2016cw washers?
all washing machines suffer from same things.overloading throws balance off stuff in pockets finds its way to the pump too much powder is used causing blockages and soft water areas cause elements to fir up with limescale.eventally motor brushes wear.but theyre cheap to replace
Aug 05, 2014 | LG WM2010C Front Load Stacked Washer /...
WHY IS WATER IS LEAKING FROM WASHER?
you just have to pull it out and take back panel off start filling with water and watch and see where it coming from a few rubber hoses under there or water pump.
Jul 30, 2014 | LG WM2016CW Front Load Washer
Moisture on the door of my LG WM2016cw
washing machines do do this its all depends on the atmosphere, if it's excessive clean out the tray were you put the powder in as this is where the washer gets it air flow from, if it stays damp in there it will show on the door glass.
Jul 14, 2017 | LG WM2016C
I cant find a part number or part for the water inlet filter on a LG WM2016CW washing machine
The part numbers are
COLD WATER VALVE 5221ER1003C
HOT WATER VALVE 5220FR2006L
Your local appliance parts store may have them available or they are defeiently availavle at;
searspartsdirect.com
repairclinic.com
apdepot.com
partselect.com
apwagner.com
GENE
Sep 17, 2011 | LG WM2016C
Can't find part number for water inlet filter for LG, WM2016CW
Spares Suppliers
You will need to type into your search engine/web browser '(make model number) washer spares' and you should be presented with a number of sources from which you can order. Alternately you could try telephone directories for spares suppliers but I would think the former would be more successful.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
Jun 04, 2011 | LG WM2016C
I have an LG front loader washing maching, model# WM2277H* I have changed both the hot/cold water value and the washer is still leaking.
if leaking on front unit : check rubber seal front glass door. if it ripped you should change it.
If leaking behind unit : check water hose , is it placed properly ?
If leaking under unit : call technician to repair it.
good luck.
Mar 25, 2011 | LG WM-2277HW Front Load Washer
LG Washer leaking water underneath
Some times a water valve can have a leak inside the machine coming out the bottom.
Also make sure the filter in the front lower left corner is tight in the housing.
Tub inside could be damaged from shipping.
Sears should be able to fix you up.
Jan 20, 2010 | LG WM2016C
IE error code
IE. is inlet water valve error.
Make sure someone did not turn off the water to the washer!!!!
Remove fill hoses and check filter screens on washer and fill hoses and clean if needed.
If problem continues water valve may need to be replaced.
Jan 16, 2010 | LG Washing Machines
Serial Number location on LG WM2016CW
just open the door on your lg and the serial number is on a tag.
May 05, 2009 | LG WM2455 Front Load Washer
Washing Machines Logo
346 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
