Question about Maytag Bravos 3.8 Cu. Ft. Washer
I have a 2 y/o Maytag Bravos MVWB700VQ0 top-loading washer that is suddenly making noise like there's either a) a chain loose in the drum of the machine, or b) a coin or other metal object is bouncing around in the drum. It happens intermittently during both the agitation and spin cycles. Any ideas? Thanks!
It is probably money in the pump. I have had my washer for two years now and an on the second pump. I had to call a serviceman to take the pump loose and dump out the change. It had 81 cents the first time and 26 cents the second. I need to call him again but I think I am going to try to do it myself. $85 a service call is just ridiculous when I know what the problem is.
Posted on Oct 15, 2010
How to run diagnostic
Maytag Bravos MTW6600T Top Load Washer Run ... - Fixya
www.fixya.com > ... > Maytag Bravos MTW6600T Top Load Washer
Maytag Bravos MTW6600T Top Load Washer, run diagnostic test cycle related issues. Get free help, solutions & advice from top Maytag experts.
Maytag Bravos MTW6600T Top Load Washer, run diagnostic test ccu related issues. Get free help, solutions & advice from top Maytag experts.
Maytag Bravos MTW6600T Top Load Washer Diagnostic ...
Dec 02, 2015 | Maytag Bravos MTW6600T Top Load Washer
Why is my maytag bravos mvwb750wq washer so loud on spin cycle?
Is it moving around? I am guessing not so guess would be the drum is out of balance.
Jul 21, 2014 | Maytag Bravos Top Load Washer
Mvwb700vq0
You must have some lines shorted, wires interconnected, water in the panel or fault in connectors because there is too much damage due to the electrical/electronic section that UNLESS it is double checked a new board should not blow off again and cause a heavy loss to you. Request for consensus and estimate
Jan 17, 2013 | Maytag Bravos MVWB700V Top Load Washer
Transporting bravos washmachine
You need to lock the drums and make sure that the motor and drum does not move too much during the transit as it can cause alignment issues. Make sure that the drum is also transported in the correct position.
Sep 26, 2012 | Maytag Bravos MTW6600T Top Load Washer
The 2-year old washer leaks from the bottom. At first it was infrequent and now every load. It's in a tray (thankfully) and after two loads the 2" deep tray is full. I've checked the inlet hoses on the...
it sounds like the main water seal has burnt out and all this water is running through the washer drum bearings,,,this will wash the grees out of them so soon the washer will be making a lot of noise as well mostly on the spin speed first,,,
you need to fit new drum bearings and drum water seals,,,
Aug 21, 2010 | Maytag Bravos MTW6600T Top Load Washer
On wash cycle it makes a loud banging noise
Hello, The banging noise is from loose lower front weight mounting bolts or a loose bolt securing the driven pulley. Check the motor adjustment bolt for tightness. The noise could be from a loose wire harness, plastic purse-lock wire harness retainer on upper hose hitting the top cover or a plastic injection mold standoff on the outer tub bearing housing may possibly be interfering with the driven pulley. Also, check the drive belt for a weak spot on the belt. Usually felt on the backside of the belt as a "flat" spot. Check the belt for a weak seam and replace it.
It may also occur due to the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it.
Thanks
Jun 14, 2010 | Maytag Bravos MTW6600T Top Load Washer
Maytag bravos washer that sounds like airplane
u need to replace the tub. includes the bearings
Feb 11, 2010 | Maytag Bravos MTW6600T Top Load Washer
Loud screeching noise on spin cycle
I have the same problem...during SPIN it make a LOUD SCREECHING sound.
Apr 20, 2009 | Maytag PAV2300 Top Load Washer
Maytag Bravos 3.8 Cu. Ft. Washer Logo
965 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
