Question about Kenmore 64672 Electric Dryer
My dryer is not heating , ive changed everything in the heating department and it still wont heat
  • Kenmore Master
  • 7,482 Answers
Check thru this list and maybe the answer lies here.
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
#1 First to do is to check to make sure you are getting full 220 Volt power to the dryer, if you are then:
Check your Wiring
Often the main wiring connection from the house, at the dryer, burns and the connection breaks. If this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Check the Door Switch
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. Check for continuity you should have none with door open, and should have a reading when closed. If not replace the door switch.
Check to make sure you heating problem is not a lint build up in the discharge hose or the dryer,as this condition can cause heater/thermistor problems such as overheating of the heating coil leading to failure of the coil and burnout of the thermostat/thermistor due to overheat.
Remove the back/or front just under the door of the machine and try to locate the air duct going from the blower to the drum. Normally inside/outside the air duct you will find the heating coil and the thermostats/thermistors. Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor one at a time by removing the two wires and taping them together with electrical tape or with an ohm meter to test the thermostat/thermistor. (Should have/show continuity)
If the coil heats up then replace the thermostat/thermistor.
(Thermal fuse.If it overheats the dryer will not operate. It's located on the blower housing. It cannot be reset. A vent clogged with lint can cause it to overheat. You can test it with an Ohm meter or continuity checker, if no continuity, replace it)
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST.
This could cause a FIRE, as you have removed the safety of overheat from the machine.
Right after replacing a dryer element, always run the dryer on 'air fluff' / 'no heat', and go outside to verify there's plenty of air coming out your vent system.
If the vent's clogged, that new element can burn out very quickly.
For video and pictures on how to replace the element go to the following website:
davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm
This is a FREE answer, Please rate me
Posted on Oct 12, 2010
My maytag gas dryer model MGD5600TQO wont heat, changed thermostat already, what next, everything else works.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Jul 11, 2011 | Dryers
Our dryer wont get hot. ive cleaned out totaly for lint inside and vents
heatman101
Jul 02, 2011 | Dryers
.glover@yahoo.comjust bought used maytag dryer
heatman101
May 21, 2011 | Maytag Dryers
Wont heat up. everything elsr works fine
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Nov 16, 2010 | Dryers
KitchenAid Gas Dryer wont heat everything else
Does the dryer heat at all? turn you dryer on for about 1 minute then open the door, any heat? yes= check to be sure you venting is good and clear. if good then you have 2 common issues i would check first. the thermal fuse could be blown or the gas valve coils could be bad. give me you model number and i can give you more suggestions of what to check and how
Mar 22, 2010 | KitchenAid Dryers
Electric dryer doesn't heat.
Probably a bad heating element. There are a few different styles, you'll just need to lookup your model number on an appliance parts website, find the right part, and then do a quick search on replacement. There are probably ten or fifteen websites that have instructions to replace heating elements.
Here's one where you can buy the part, the element is part number 17.
http://www.appliance-parts-warehouse.com/whirlpool-parts/Whirlpool-Dryer-Parts/Whirlpool-Parts-LER3624EQ1/Whirlpool-Parts-81777.cfm
Jan 15, 2010 | Dryers
Heating element dosent go off
sounds like yo have a wire shorting to the unit itself or a contact closed onthe dryer timer, always allowingheat.. I would point to a shorted wire somewhere. might be a ***** to find sorry!
Jan 24, 2009 | Whirlpool LER5636P Electric Dryer
Kenmore 64672 Electric Dryer Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
