Question about Toshiba 42H81 42" Rear Projection Television
My Toshiba 52" TV stopped working - no picture or sound; similar to what i did 2 years ago when i experienced the same problem, i purchased and replaced the lamp unit (Type: TB25-LMP S/N: 23311083A; Rated: 120W DC50-120V). Still, no picture or sound even though i replaced the lamp unit; instead, it makes clicking noise as if it is going to turn on and shuts off repeatedly. TV Model #52HM84 Serial # 20734664
2 Suggested Answers
milkburp
  • 416 Answers
SOURCE: I have replaced my lamp unit TB25-LMP but the red
Unplug the TV, ensure the lamp door is installed and the screw is snug. Plug the TV in and wait a moment. touch and hold your finger on the power button on the front of the TV. If your TV does not power up, your ballast and power supply should be suspect. Many Toshiba DLP sets use a similar lamp design. They have been known to burst and cause a momentary short. This can knock out the power circuits which feed the lamp. If this is the case, post back for further details if you wish to repair this yourself. I hope this was of some assistance.
Posted on Mar 22, 2010
Toshiba regza 32hl67 losing its' picture and motion is slow
I have a toshiba regza 32hl67 LCD tv which is only 2 1/2 years old. The picture on this unit just started to go the other day (screen darkens but images are still visible and the motion/movement is very slow). I contacted Toshiba and they just said to unplug the tv for 3 minutes to reset the tv. This doesnt work. I am VERY upset with Toshiba, after paying $800 for a tv that only lasted 2 1/2 years. If anyone has had similar issues and know how to fix it, please let me know. Thanks
Apr 26, 2010 | Televison & Video
3 horizontal lines through screen and distortion
Yes this thing start happening to my tv too about 4weeks ago and this goes away in about 15 minutes. TV is only 18 month old and I donot have extende warranty. Please post the solution if someone has got it repaired. Thanks
Dec 28, 2009 | Sony BRAVIA KDL-52W3000 52 in. LCD...
Tv screen picture
it sound like you have a bad dmd bord that is whear the pix come from do it do all the time in video1&2 or hdmi
if so it could be antboard or the dig board to you should take to a repear shop.
Dec 07, 2009 | Toshiba 52HM95 52" HDTV Projection...
Sound went out!
Have the audio signal board replaced. Also make sure ur amplifier is set to the correft output, alth i am sure u have.
May 03, 2009 | Toshiba 52HMX94 52" Rear Projection HDTV
Sony 52" rear projection tc
Hi, thats the code for AKB fault, this requires a tv tech to fix,, not a big bucks repair, video-tek
Feb 09, 2009 | Sony KP-43T90 43" Rear Projection...
Every thing works except the sound
press mute on the remote control
Jan 25, 2009 | Toshiba 32A33 32" TV
Toshiba CE35f15 TV
This is a vertical circuit problem that is either bad connections on the vertical IC or a defective IC. If you can solder, you can fix this yourself. Look for a small flat IC attached to a heatsink with about 9-11 pins. It may be marked LA7837 or something similar. Try resoldering the pins first. If that fails to resolve the problem, replace the IC. There may be defective caps in the circuit as well, but those don't usually cause complete vertical failure. If the picture does not return fully, update this and we'll continue on to the next step.
Dan
Sep 29, 2008 | Toshiba Televison & Video
Toshiba DLP 50HM66
The bulbs for this TV seem to go about every couple years. The price has dropped down a bit. I have found it for 118.00.
Feb 17, 2008 | Toshiba 50HM66 52" Television
Toshiba 52 in tv
Most likely = bad Hyper board....need exact model # off back
of set for more info..................T.
Dec 08, 2007 | Toshiba 61A60 TV
Toshiba 42H81 42" Rear Projection Television Logo
248 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
