Question about Magellan Maestro 4040 GPS Receiver
I WOULD LIKE TO DOWN LOAD A MANUAL FOR MAGELLAN/MAESTRO GPS NAVIGATION UNIT.
  • 696 Answers
No problem!
The owners manual for your Maestro can be downloaded here:
http://www.magellangps.com/support/product.asp?prodid=1873
Hope this helps!
Posted on Oct 12, 2010
Tip
How To Reset Your Magellan Maestro/Roadmate GPS Units
Factory Reset
Do not attempt to perform a factory reset on the Roadmate or Maestro GPS units by holding down both the "Reset" and "Power" buttons. This will cause the GPS unit to format its own hard drive. Doing so will erase all data, including the GPS software, from the unit.
  1. Locate the button marked "Reset" on the left, right or bottom of the unit.
  2. Using a thin object, such as a paper clip, depress the button for two to three seconds. The unit should reset.
  3. If the unit does not reset, immediately press the button again and hold it for up to 10 seconds.
If your Maestro GPS Touch Screen Doesn't work, try performing a Hardware Reset
  1. Remove the Magellan Maestro from the holding cradle.
  2. Hold down the "Power" button on the right side of the device, until the unit powers on.
  3. Straighten the end of a paper clip. Place the paper clip in the reset hole, located on the left side of the GPS unit. Hold down the "Reset" button for 10 seconds. Remove the paper clip.
  4. Turn the Magellan Maestro unit off by holding down the "Power" button. Turn the unit back on again. The device is now reset.
If your Roadmate GPS is locked up, try performing a Hardware Reset
  1. On the RoadMate, press + + - - + -
  2. The "hidden menu" will appear.
  3. From there, you can access the shell and perform a hard reset.
on Feb 15, 2011 | GPS
I need a free magellan maestro 3200 manual.
Hello therre:
Please follow this link to the manual and you can download it free it is in pdf format ok
Magellan Maestro 3200 Manuals, Support and Troubleshooting - GPS Free download of Magellan Maestro 3200 User Manual. Troubleshooting help from experts and users. Ask our large community for support.
www.retrevo.com/support/Magellan-3200-GPS-manual/.../2/ - Cached - Similar
Jan 16, 2010 | Magellan Maestro 3200 GPS
Magellan Maestro 3225 signal is no longer working. No satellite for navigation.
Look in the back. There is a small rubber cap on top of the external antenna hookup. Remove the rubber cap with a pin and hookup a long wire on the middle. That should amplify the signal.
Sep 13, 2009 | Magellan Maestro 3225 Car GPS Receiver
Touch Screen
You probably just need to reset it.
Magellan Maestro models- the location of reset button is on the left, right, or bottom side inside a small hole. Use an object to apply pressure to depress the reset button. Also try holding the power button down for up to 10 seconds to power the unit off and again holding the power button down for up to 10 seconds to power the unit on.
You may need to update your firmware. Go to this site
select your product family, model, and then press the submit button. Firmware updates are located in the updates/upgrade section.
This should solve the problem. Good luck. If this helps, plz rate it fixa. Thank you kindly.
Feb 07, 2009 | Magellan MAESTRO 3100 98083401 GPS Device
International Maps for Magellan Maestro 4250 GPS
If I am correct you can put it on the sd card
There should be a slot for the card on the unit .
also you can check on their web page .
Jan 28, 2009 | Magellan Maestro 4250 GPS
Its asking me to upgrade
You get a free update within 30 days of purchase. Call customer service @ 800-707-9971, $10 for FedEx delivery of CD
Nov 02, 2008 | Magellan Maestro 3200 GPS
Magellan Maestro 4040 GPS Receiver Logo
78 people viewed this question
Top Magellan GPS Experts
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
