Question about Bose Lifestyle 38 DVD Home Entertainment System System
How do I connect the HDMI cable from my apple tv to my Bose lifestyle 38?
5 Suggested Answers
SOURCE: Lifestyle 38 and HD
I have also have this problem with a lifestyle 28 system. Bose sent me a new cable then a software update. The problem remained, after contacting Bose and unplugging cables and powering down the system this solved the problem. However 2 days after and the problem has re-appeared. Back to square one. I should add that this is the second unit I have had the retailer exchanged the last one because of the same problem.
Posted on Apr 09, 2008
  • 34 Answers
SOURCE: Apple TV and Bose Home Theater
You should be able to connect hdmi from apple tv to bose v30 for picture and sound. You can also run component video to bose and a hdmi out of bose to tv. Just make sure your running hdmi out of bose system to tv if your tv supports hdmi if not use component video cable. Another way which isn't as good of quality is to run fiber optic from apple tv to bose v30 and hdmi straight to tv.
I’m happy to help further over the phone at https://www.6ya.com/expert/brandon_60dfebff379d64bd
Posted on Nov 07, 2008
  • 10865 Answers
SOURCE: Bose Lifestyle 38 connection to TV doesn't work.
Is your tv hooked up to your cable box or satellite with an HDMI cable? There are several ways to input to the TV.
Posted on Aug 30, 2009
MarineTech1
  • 76 Answers
SOURCE: Connect lifestyle 48 to plasma and dvr
Unfortunately, BOSE does not do HD yet so the only way to get around it, is to run all of your inputs (DVR etc) throught the TV and use an audio out from the TV to the BOSE in order to get your surround sound. If you still wish to use the BOSE to play DVD's, you will have to settle for either composite output (yellow/white/red) or component output (green,blue,red + white red).
Posted on Sep 13, 2009
Testimonial: "Thank you for the straight information! Very easy to understand and (soon) to implement. I appreciate it!"
Black and white
The Lifestyle 38 has no HDMI output. It all depends on what inputs your TV has, which cable set up would be the best for you. Assuming that your TV has an SVideo input, you indeed can use the SVideo output of the Bose system, to get the DVD picture on your TV. However you will need to connect the audio output of the TV to the TV input of the LS 38 to get the TV sound to play over your LS 38. In case you don't have an SVideo connection on your TV, you can use the composite output of the Bose system and connect it to the video input of your TV (yellow in and outputs)
Dec 10, 2013 | Bose Lifestyle 38 DVD Home Entertainment...
My Home theater system was on with my TV. The video just went out audio is still on. I checked all my connections changed out a HDMI cable to the TV still no video only sound. Ran a HDMI straight from...
I appreciate that you did an isolation steps where the fault maybe by running a HDMI straight from your your Direct TV box.We could further steps by following mentioned below
1. Please make sure your connecting the HDMI cable on the right port
2.Please make sure you are using the HDMI cable compatible to the system.also try the supplied
cable from Bose.
3. If still does not work,please contact the manufacturer or contact the store where the item was purchased
Sep 04, 2011 | Bose Lifestyle 38 System
I try to plug apple TV to my Bose sytem lifestyle 20. The apple TV is plugged by hdmi on my TV (hdmi2). The apple tv image is good but the sound is coming from my tv not from my bose system. i decided to...
You might want to try connecting the Apple TV to your TV using HDMI, then using the optical cable from your TV to your Bose system. In your TV's settings, there should be an Audio Output option. You'll want to turn off the TV speakers. Optical audio can be a little strange compared to traditional analog. If your cord is going bad, it could result in behavior like you described.
Jan 24, 2011 | Bose Lifestyle 30 System
We want to hook up an HDMI dvd player to the tv and have the sound come thru the Bose Lifestyle 38 (older model, did not come w/the HDMI converter that the 48 has or newer systems come with). We are not...
The best way to do this is to take your OPTICAL AUDIO OUT from your TV - (if it's a newer TV) - plug it in to the OPTICAL AUDIO IN on your BOSE system, then use the 'TV' source on your Lifestyle 38 to get the sound from. I have sound for X-Box, DVD player, Blue-Ray Player and Wii being pushed through the TV back to the BOSE and it sounds great. I don't have to change the source on the BOSE very much either - except when I listen to stored music!
Sep 27, 2009 | Bose Lifestyle 38 System
You need to buy a Bose VS 2, video enhancer. Your cable/sattelite, vcr and aux connect to the VS 2 and the VS2 connects one HDMI cable to the TV. The VS2 then upconverts DVDs played on the lifestyle through the VS2/HDMI.
Sep 10, 2009 | Bose Lifestyle 48 System
Aug 30, 2009 | Bose Lifestyle 38 Series IV DVD Home...
I am attempting to connect a computer monitor to my bose lifestyle 38 system. The monitor has an HMDI input
I think that will be hard to do as I own an AV38 and there is no HDMI feature on my BOSE SYSTEM. I had to use the AV inlet. The AV48 DOES have the HDMI feature.( Unless you have a much later model AV38 that has the HDMI feature.
Jul 03, 2009 | Bose Lifestyle 38 System
Connecting lifestyle 27/38 to psp3
Your Bose system doesn't lead sound trough hdmi.
You must connect the optical cable with your lifestyle.
Change the sound connectionsettings in the menu of your ps3.
You also need to assgn the optical connection in the setup menu of the lifesyle. e.g. optical=aux.
Dec 28, 2008 | Bose Lifestyle 28 System
Nov 02, 2008 | Bose Lifestyle 30 System
Lifestyle 38 and HD
Apr 08, 2008 | Bose Lifestyle 28 System
Bose Lifestyle 38 DVD Home Entertainment System System Logo
157 people viewed this question
Top Bose Audio Players & Recorders Experts
Invebo
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
