Question about General Hand Tools
I have two Japanese Z saws and I am about to remove the old blades. The new ones are in the post. How do I remove the old blades. One has a short back support and the other is long. Both have a circular depression near the handle, The short backed one also has a notch just above the circular bit with a curved arrow stamped in it.
  • 1 more comment
  • darcy691 Oct 12, 2010
    Many thanks Silverdragon, I will give that a go. One blade has a split just where the short spine ends so not sure what is going to happen there. Many thanks. Darcy961
    Wow, so simple when you know what to do. Worked with both perfectly. Very grateful. cheers Darcy691
  • darcy691 Oct 21, 2010
    Thanks for asking but the first advice worked fine. cheers
  • 8,197 Answers
Would like to know if you still need help with your item
Posted on Oct 18, 2010
  • 12,061 Answers
The blades have a hook on the tang end which fits around the rivet in the the metal support and the support pinches the back edge of the blade when its correctly inserted. To remove this type of blade, you strike the back edge of the blade on a flat piece of wood (cutting edge up aiming to make contact with the last third or so of blade for most leverage). Strike so the blade hits flat along the back and not just at the very end or one point along its length, if you follow what I mean.
The force you are applying will move the blade in the direction of the arrow (which shows a rotation toward the cutting edge around the rivet) which will unseat it from the pinch of the metal support. Once free, it will rotate until the hook is free of the rivet and it will detach.
To install a new blade, you pretty well reverse the operation except strike the back of the metal support on a piece of wood so the force drives the blade into the pinch of the support.
Or, just give the end away from the rivet a yank and out it comes, you could also put it in a vice and just pivot the handle too.
Posted on Oct 12, 2010
How to change scroll saw blade
MAKE unknown to us we have no idea where to look or send you
Jun 25, 2016 | Saws
How do you install new blades on a DW7332?
unplug the saw/remove battery
press the button on the side near the blade
pull old blade out. push new blade in, release button to lock new blade in place.
Jun 06, 2014 | Saws
How to change a blade on dw305 dewalt recirocating saw
On the DW305 you need an allen wrench to remove the blade. Some tools have one somewhere on the handle, if not find one to fit in the blade clamp hex-head bolt. Loosen the bolt and the old blade should come out easily. When you put the new blade in make sure the pin inside catches the hole in the blade.
Mar 07, 2012 | Dewalt Saws
Husky thd750 wet saw changing blade
If this is the K750 cut off saw, then to change the blade you need to remove the 13mm fixing screw ( anti clockwise )if you cannot hold the old blade to remove the screw, insert a 6mm pin into the right hand belt cover, there is a hole to tale this, this will engage into the pulley and lock it, then remove the outer flange, the old disc will now come away, make sure the new disc has the same size centre as the old one, the size will be on the rating plate on the cutter guard.
Oct 29, 2011 | Garden
How do I change the blade on a jig saw
on most newer jigsaws there should be a collar that you just slide back to remove old blade and insert new one
Oct 08, 2010 | Black & Decker Scroll Jig Saw Blade
How do i get guard out of way to replace blade..DW718
Make sure the saw is unplugged, manually move the blade guard up to it's fullest extension, push the arbor lock to make sure the arbor and blade do not spin (on front of saw motor housing), then wrench the nut holding the blade to remove. Remove the old blade, install new one and reassemble in reverse order. You can take the guard off completely if you choose, but it is not necessary. I hope this helps and good luck!
PLEASE REMEMBER TO VOTE AND LEAVE A TESTIMONIAL. THANK YOU
Mar 30, 2010 | Dewalt 12" Beveling Sliding Compound Miter...
Can not remove the old blade
1. Unplug the saw.
2. Locate the blade lock button used to lock the motor shaft when changing a blade. For your saw, this button is usually located on the left side of the blade guard somewhere around the motor housing.
3. Push the button while rotating the blade until the button engages and the blade will no longer turn.
4. Use the wrench that came with the saw (or another wrench) to loosen and remove the blade bolt. For your saw the bolt should have standard right hand threads which means you loosen the bolt by turning it counter clock-wise.
5. Remove the old blade and replace it with a new blade of the same mounting type. Some blades have a round through hole and some blades have a diamond through hole.
6. Re-install the blade bolt and tighten clock-wise while holding the blade lock button down.
Oct 03, 2009 | Sears Craftsman 7-1/4 in. Circular Saw...
How do I change the blade on my Ryobi 10" table saw?
The manual is posted on line. Changing the blade does not require turning the saw over, blocks of wood or vice grips. The advice listed above is potentially damaging to your equipment.
http://www.raygirling.com/ryobi/ryobi.htm#settadj
Mar 28, 2009 | Saws
How to change blade
remove the blade guard, should be a big nut holding on blade remove that nut install new blade, make sure the rotation arrow on your new blade is going same direction as old blade reinstall the big nut and washer , put guard back on you should be set! good luck
Mar 24, 2009 | Dewalt D24000S Wet Saw With Stand
How do you re-install the Skillsaw 5150 blade?
I,ve personally never heard of a problem quite like yours. I use skill saw brand saws every day and the arbor and washer will only make the blade wobble if installed incorrectly. Blades can be turned around to cut different types of material as well. Check to make sure the hole or diamond is the same on the new blade(you might have to punch it out) if its not seeding properly on the saw, you could also check under the guard to make sure nothing is binding the saw. The only other thing I could suggest would be to check the lock button (the one you hold to change blades, that stops the saw motor from turning) if that is stuck, your saw won't run. Good Luck!!
Oct 28, 2008 | Saws
Hand Tools Logo
21 people viewed this question
Top General Hand Tools Experts
Don Numinen
Don Numinen
Ivan
Ivan
Level 1 Expert
Bill Boyd
Are you a General Hand Tool Expert? Answer questions, earn points and help others
