Question about John Deere Garden
The lawnmower wont start it made a loud poping noise and now it wont start it turns so its not locked up i tried checking the fuel system that is working fine i also changed the spark plug
    Brigadier General:
  • 3,911 Answers
I suggest taking off the little valve covers next to the spark plugs and see if you have bent valve push rods, not uncommon with today's gas. This means that though your crank turns and your pistons move up and down, there is no opening/closing going on to let mixture in or exhaust out. If that is your problem they are easy to replace, but I would get an expert to adjust the new ones once they are in.
Posted on Oct 14, 2010
Ke tx3 has spark and fuel but wont start and makes weirted noises from air flow meter when cranking
Unplug AFM and see if it will start. Check for obstruction in AFM, such as dead mouse!
Sep 27, 2016 | Ford Laser Cars & Trucks
My 1995 Dodge Caravan started making a VERY LOUD lawnmower sound. I looked under the hood and noticed a frayed cord behind the engine. Not sure what is going on.
Wheel Bearings sometimes make this noise when on there way out..
change quickly or they could disintegrate ,and collapse..
Mar 05, 2014 | 1995 Dodge Caravan
Rear HVAC unit in 2002 trailblazer making loud poping noise and then quits after a couple of minutes
The only thing i can think this would be is a blower motor noise, have shop take a listen is my best advice.
Oct 25, 2012 | 2002 Chevrolet TrailBlazer
Vizio model vx322 hdtv10a is losing sound and makes a loud humming noise and a poping sound every few minutes
Good day!!!!
That problem is usually cause of faulty capacitors on the power supply board..
Just follow this instruction to fix your TV..
1. Open the back cover of your TV.
2. Look at the power supply board..Its normally connected to the power cord..
3. After that,,try to look at the actual image of capacitors if it is bulged on the top so that you can easily determine the bad capacitors..
4. After that,,try to replaced the bad capacitors using soldering iron and soldering lead..replaced the capacitors only with the same type ratings and value..
5. Some of the capacitors not bulged so its better if have a capacitance meter
Jul 10, 2012 | Televison & Video
Steering making noise when turning steering wheel on ford focus
what kind of noise a loud squel noise or a poping noise
is sqeal check your fluid if fluid ok then the **** needs replaced
Aug 10, 2011 | Ford Focus Cars & Trucks
My car wont accelerate and there is a loud popping noise on the passenger side when it tries to go
Dodge stratus V6 ?
You should have a check engine light on in your dash.
You will need to have someone plug in a OBD II reader to retrieve the code.
I believe the loud poping noise you hear is the engine backfiring, from either a fuel or electrical problem.
Please let me know what you find.
Feb 07, 2010 | 2001 Dodge Stratus
My 1995 Nissan Maxima wont start. I smell gas.
Sounds like a bad fuel pump, check if the smell comes under the rear wheels and also check for a loud humming noise when the key is turned to on. Those are signs of a bad fuel pump.
Nov 22, 2009 | 1995 Nissan Maxima
4 wheel drive wont disengage
shift motors are stuck.or check to make sure shift motors getting vacuum.
Apr 17, 2009 | 1991 Ford Bronco
1986 yamaha fz750 wont start
Hi Johnsong,
You will have to clean the carburators!
The float chamber has more fuel thn required could be a siezed or dirt in the float pin.
Clean and readjust to its correct level.
Try this site for more info www.xjbikes.com
Cheers!.
Knight (YAMAHA SECA XJ750A 1981)
Feb 09, 2009 | 1986 Yamaha FZ 750 TV (Europe)
Garden Logo
895 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
