Question about Rainbow E series Canister Wet/Dry Vacuum
Work well but smell like a burning belt - Rainbow E series Canister Wet/Dry Vacuum
    President:
  • 1,140 Answers
If it smells like burning rubber, the belt is probably worn and slipping. If it's another burning smell, your motor windings are probably shorting and will burn out soon
Posted on Oct 12, 2010
Vax troubleshooting
Burning smell from a vacuum usually comes from the belt....check
for any objects caught between the belt and the brush roll. Is the
surface selector at the correct setting?
Aug 16, 2014 | Vacuums
Burning smell Kenmore 50558
If the burning smell is an electrical smell it could be motor or wiring problems which are best handled by a professional. If it smells like burning rubber it is probably the belt. If it smells like burnt wood it could be the belt slipping on the brush roll, if the brush roll is made of wood. Dust and debris can also accumulate behind the end caps of the brush roll causing friction which can cause a burning wood smell.
Mar 30, 2014 | Kenmore 5055, 50557 and 50558...
I have a steam vac spinscrub carpet cleaner works good but it just started smelling like it was burning and started to smoke
Anytime someone says they smell something burning on any type of vacuum cleaner of carpet cleaner etc. All I can think of is the belt is rubbing on plastic which would cause the sense of something burning because you possibly are smelling the belt........
Mar 12, 2014 | Hoover SteamVac F5914-900 SpinScrub...
Our vacuum smells like burning rubber. Does it
Burning rubber smell means the brush belt need attention. Make sure the brush is turning freely and replace the belt
Jul 05, 2009 | Eureka Vacuums
Burning rubber smell when the vacuum is on.
it sounds like the belt may be burning like the roller bar is stuck maybe or the belt is stretched and is burning itself off
Jan 11, 2009 | Kirby Ultimate G Bagged Upright Vacuum
Hoover mach 4 burning smell
There are two reason you could be smelling a burning smell-
1. The belt is too stretched out and needs to be replaced. This causes it to slip when the vacuum is on and will create that type smell. You can avoid stretching and having to replace the belt to often by releasing the belt after each vacuum.
2. There may be hair or other debris stuck around the rod that the belt is attached to. Can be avoided by checking after vacuuming.
Hope this helps
Nov 12, 2008 | Hoover Vacuums
Sebo x1.1 - burning smell
Try replacing the belt. My vacuum cleaner had the same problem and once the belt was changed the burning smell was gone.
Jun 10, 2008 | Sebo Automatic X1 Bagged Upright Vacuum
Burning smell and smoke
When you turn it on....is the belt turning the brushes? Something may be caught causing the brushes to stick and the belt to just grind the brush assembly.
Jan 03, 2008 | Eureka Altima Upright Vacuum Model 2996AVS...
Burning smell
Hi. What does the burning smell of? Is it 'rubbery', or is it acrid and 'chemically'?! The most common item to 'burn' is the belt which drives the rotating brush at the front. Does your cleaner have a belt? This would give a burning rubber smell. The instructions should explain how to change the belt - have a close look and see if the belt has been slipping on the motor spindle. If it has, then it'll probably be worn at this point and should be replaced. A common cause of this happening is the brush bar getting caught in something - edge or rug, etc - and being forced to a standstill. If the smell is more 'acrid', it could be a problem with the motor. This is a repair service job.
Sep 22, 2007 | Eureka 2996AVZ Bagless Upright Vacuum
Rainbow E series Canister Wet/Dry Vacuum Logo
1,739 people viewed this question
Top Rainbow Vacuums Experts
Joseph Hoffmann
Jax Planet
Jax Planet
Are you a Rainbow Vacuum Expert? Answer questions, earn points and help others
