Question about Imation SpongeBob SquarePants Npower 15 in. LCD TV
After getting cable installed, I am not able to switch the input to use our dvd player and watch DVDs. The channel stays on 3 - and will not change. The outputs are connected directly to the tv and still will not change. Please help.
  • 4 more comments
  • sonoraatha Oct 13, 2010
    this did not work...i tried this already. i tried it by connecting the dvd directly to the tv without the cable hooked up and with the cable hooked up ...doesnt work....the tv stays on channel 3 - 0 and when the dvd is turned on and playing there is just a blank black screen on the tv. please help...
    I have an Npower Spongebob TV and I have just recently had cable installed. Since installation, I have not been able to switch the input to use the dvd player that is connected to the TV. With the dvd player connected directly to the TV, cable disconnected, and dvd playing, there is only a blank black screen. I also tried scanning the channels...didnt change. Please help ...
    tried this...i love how u say telly!!!....doesnt work...stays on channel three when i try to switch source..
    i checked the dvd player on another telly and it worked just fine....i tried connecting the dvd player via 3 wires yellow red and white directly to the telly with the cable box on standby..still black screen...i tried source button , switched to AV, still black screen???
    oh boy...i thought the cable guy just did something to it..becuse it worked fine just before the cable was connected
    Ha! ur so optimistic!!! u can tell ur not from the states!!! the first thing i did was reach out to the cable company..and they said it wasnt their problem....no one is as nice as you!!!! thanks for your help...i have insurance on the tv and hopefully with a new one it will work...thanks for your time...cheers!!!
  • Imation Master
  • 12,061 Answers
You DO NOT use "Channels" you must select EXTERNAL INPUT, to be able to process, the DVD signal.
You need to look in your TV manual for instructions to select an EXTERNAL INPUT, usually via the remote or the set's buttons, using the onscreen menu.
Posted on Oct 14, 2010
  • 4,102 Answers
Hi, is the dvd player plugged directly into the back of the telly if it is then it may not come on until you put the cable into standby.
also switch the dvd player on and look on the telly remote for one of the following buttons
av
source
input
ext
or a picture of a square or rectangle with arrow pointing to the right.
once you have found one of these buttons make sure the dvd player is on then press the button you may need to press it more than once depending on how many inputs the telly has, if pressing the buttons dont bring the dvd player on the telly then check the connections in back of telly pull the dvd lead out of the telly and refit it as it may just be slightly come loose when cable was installed also do the same the dvd player end just in case its worked loose.
let me know if it dont make any difference or if you need further assistance ok
Posted on Oct 13, 2010
  • 1 more comment
  • paul proctor Oct 13, 2010
    im in UK thats what we call them, when you press the button on the remote does it even look like its working do any red lights flash on the TELLY, also have you tried plugging the dvd player into a different input on the telly to see if that makes any difference.
    also have you got anything else you could plug into the back of the telly to make sure its not the dvd player at fault, if you have another dvd player or anything else with the same connector as the dvd you trying to use plug this into the input your dvd is plugged into just so we can rule out it being the dvd player at fault.
    if you plug something else in that you know works then we know its the telly if it still dont pick it up but if it then picks the other device up you will know if its the dvd player at fault.
    what input are you using is it scart lead fitting or the 3 colour wires red,white,yellow.
    let me know ok
    it sounds like you have got a fault inside the telly itself if the dvd player works and the lead you are using works then this would rule out them being the fault, the chances are the solder has cracked on the actual video input board inside the telly its either that or it could even be a blown resistor, this would need testing to find out if its blown chip or cracked or cold solder joint that needs resoldering
    it could well be the cable guys fault but proving it would be near impossible the chances are it could be that moving the wires put pressure on the connectors inside the telly and caused solder to crack or come loose, it could also be static caused by installing the cable that caused it to go wrong as static is usually built up in the wires until its earthed out inside your telly.
    proving it was the cable guy is a different thing all together.
    put it all back as it was when he installed it and give them a call say the bloke just installed your cable and you was watching a dvd just before he came then after he installed it you wanted to watch the dvd again but it wont come back on and you never had a problem with it before.
    your cable company will have insurance for problems due to installation so give them a call and explain what happened and hopefully they should come out and have a look at it for you.
    cant hurt to give them a call can it
    let me know what happens ok
  • 11,896 Answers
With devices connected and turned on go to menu settings, then find tuner or channel options and find a setting for autoprogram. Select it and let it run competely through. It will add all available channels and add them to it's memory
Posted on Oct 12, 2010
I just purchased this DVD LG I'm trying to find out what channel to put it on to watch my DVDs on and I'm on DirecTV
There is usually a switch on the back of the DVD player to choose either channel 3 or 4. You will need to use the TV's remote not the direct TV remote. To change the source or input to the correct inpit mode on the remote select input then select the input mode that you plugged your DVD into ( tie. HDMI 1 or 2 ) then turn on DVD that should do it
Jul 26, 2015 | LG Televison & Video
I dont have cable.i was using this tv just to play dvds and i accidentally hit channel search. now i get a blue screen that says" plerase connect cable system or an antenna to the terminal on the back...
Hi:
Using remote locate a button called tv/video or Input, turn on the DVD player and hit this button until you see your DVD player Logo. Most dvd players use either video 1 or 2, or componet or HDMI outputs. Seems you have changed the TV's input back to TV mode and you need to change it to a video mode input.
May 17, 2011 | Televison & Video
How do i hook up a dvd player to my tv if i have cox cable? I dont know what channel to put my tv on. I know there has to be a way to watch a dvd without unhiiking the cable
Most DVD players have a coax input and output on them. But some newer ones don't. Assuming your does then you can run your DVD player to your TV with a coax cable you bet. Either on the back of the DVD player there will be a little switch or in the menu settings it will give you an option for channel 3 or channel 4. The same channel you select on the DVD player will be the same channel you will want to put your TV on. For the coax install run it from the output on your DVD player to the coax input on your TV. If you use a coax for cable too then just run you coax from the output on your cable box to the input on your DVD player.
Mar 20, 2011 | Samsung Televison & Video
Hi i have an alba tv , im trying to connect a dvd player. I have connected the scart leads etc.I can not get onto the av channel so i can watch a dvd. Please help
Firstly, please make sure you have connected the SCART cable correctly. This should be connected to a SCART OUT socket on the DVD player to one of the SCART IN or EXT sockets on the rear of the TV.
If you have correctly connected the SCART cable the TV should automatically switch to the AV channel when you switch the DVD player power on or insert a disc.
Switch your TV on, then switch the DVD player off and then on again. If the TV does not change to the AV channel you may have the SCART cable connected incorrectly.
Not all TVs automatically switch to the AV channel when the AV device is switched on. On some TVs the AV input is on channel 0 or 99. On other TVs the AV input is not assigned to a specific channel. On these TVs you need to look for a button marked "AV", "INPUT" or "SOURCE" - either on the TV remote or on the buttons on the front of the TV. The easiest way to do this is to insert a disk into the DVD player and start it playing. Then press the "AV" "INPUT" or "SOURCE" button (whichever one you have) repeatedly until you find the signal from the DVD player.
Please check your connections and try using the "AV" "INPUT" or "SOURCE" buttons. If you are still unable to watch your DVD player, please post back with the following information:
1. Model number of the Bush TV
2. Brand and model number of the DVD player
3. If you are using any remote other than the ones supplied with the TV or DVD player, the brand and model number of the remote.
I will then be able to tell you exactly how it should be connected and which buttons (if any) you need to press to access the AV channel.
Hope this helps. Happy New Year!
Regards,
BElectric
Jan 01, 2011 | Televison & Video
Coby DVD765 Theater System and can't control the TV volume through it...I saw the previous post...We have it in our bedroom and rarely watch DVDs in there. Could I plug my RCA audio cables into some of...
The connections will have to go directly into your tv set. On your tv, you should have 3 connnecting points. Red, White and Yellow. On your Theatre system amplifier you should have audio outputs like CD, AUX, etc. Pick one of these outputs and connect to your Red and White RCA on the tv set. Next, connect the DVD player's audio to dvd on your amplifier under the DVD connection. Your VIDEO (yellow) Cable should still go to your tv directly from the DVD player. Now, if you want to listen to the TV channels throug the system, simply select the channel that you pluged the TV audio into. Hope this helps.
Jun 11, 2010 | Coby DVD765 Theater System
Record a digital channel while watching and analog channel
Take a red, white, and yellow AV cable and plug it from the AV out of the cable box to the red, white, and yellow In of the dvd recorder (change cable box to the channel you want to record). Then change your TV to the channel you want to view.
Have fun!
-Tha Mp3 Doctor
Nov 23, 2008 | Panasonic DMR-ES30VS DVD Recorder/VCR
Connect tv vcr and dvd player to digital converter box
Yes you can first connect the converter box to the antenna first. Next hook the tv out on converter box to vcr in on vcr. Next hook the vcr out to the tv in and watch vcr and converter box on channel 3 sometimes channel 4.on the actual tv and of course change channels with converter box remote. For dvd player hook it straight to tv with red,white,and yellow cables that come with your dvd player. Then to watch dvd player if it's hooked up that way you have to put your tv on a input like video 1 or input 1. This can be done by using the tv remote and looking for a button that says tv/video or input or source button. This is some common names for that button on tv remotes.
Nov 02, 2008 | Insignia Digital-to-Analog Converter for...
I have a Panasonic SA-PT750 and a new LCD HDTV (Sharp Aquos, 46"). The DVD quality is terrible. I changed the setting to 1080p on the DVD player but still not good. I am using an HDMI cable. Also,...
On tose new hdtvs youve gotta set screen format in the menu to manual,youve gotta do it when you watch dvds,, or else itll stay on full ,,and also under setup in the menu check to see if u have convirgence, most hdtvs have this. it realigns the colors. u have to set it for every input channel
Oct 05, 2008 | Panasonic Televison & Video
I have a magnavox dvd player and just had directv installed and I cannot get the dvd to recognize the directv channels. I can only record two digit numbers.
your best bet for this problem is to rearrange the way you have your direct tv and dvd hooked up to your television. a lot of the time you can plug the dvd player into the input/antenna in jack on the back of the receiver. that way you can watch all the channels you want AND be able to watch dvds without having to unplug and replug stuff in. more than likely you'll have to push an input or tv/vcr button in order to switch between watching direct tv and dvds, but it's a lot simpler than switching chords around.
Jul 28, 2008 | Televison & Video
I have a 30 year old tv w/cable. I want to install a dvd/vcr combo player. What kind do I need? I've tried one and it didn't have the right connection.
If the original TV doesn't have audio/video inputs, you'll need a DVD/VCR player that has a built-in RF modulator. A RF modulator takes the audio & video and modulates a RF carrier to one of the channels that your TV can receive. In the U.S., this is usually channel 3 or 4. If the DVD/VCR player has a built-in tuner, connect your cable to the RF input of the DVD/VCR player and the RF Output of the DVD/VCR player to the cable input of the TV. This way, you can receive your cable channels through the DVD/VCR player and watch movies as well. If your DVD/VCR player does not have a built-in tuner, you can put a RF switch inline that will allow your TV to either receive the cable signal or signal from the DVD/VCR player.
- Jim
Jul 03, 2008 | Televison & Video
Imation SpongeBob SquarePants Npower 15 in. LCD TV Logo
50 people viewed this question
Top Imation Televison & Video Experts
Are you an Imation Televison and Video Expert? Answer questions, earn points and help others
