Question about Jet JWS - 22CS / 708320 1 - 1/2 HP Woodworking Shaper
Sounds like the spindle bearings may be going bad. Sounds a little rough when turning spindle by hand. How do you take off the spindle?
  • 7,733 Answers
Try here --------->link..
Posted on Oct 12, 2010
I have an O2 Dodge ram 15102 Wheel Dr., how can I tell if a bearing is going bad in one of my wheels?
You have to jack the vehicle off the ground, then grab each tire at the 12:00 and 6:00 positions. Then as hard as you can try to wiggle the tire up and down. If there is any movement then that wheel bearing needs to be replaced.
Mar 10, 2016 | Dodge Cars & Trucks
I replaced my PTO drive belt (engine to blades, part #754-0497) without any trouble.
Check all idler pulley bearings, double pulley bearings and the spindles bearings. If any feel rough hand turning replace them. Also make the spindle belt is correctly routed. Edited adding the word "belt"
The 60.5" belt is the correct for the G deck that uses the 66.5" spindle deck belt.
Apr 05, 2015 | Garden
Bad oil pump ?
Turn your A/C off, the compressor can make noise if bearings are dry or system is low on compressor oil.
Remove your serpentine belt. Turn pulleys by hand to check for roughness. Bearings in those pulleys routinely go bad.
You may get computer warnings with the following test, but with serpentine belt removed, run engine for 2 or 3 minutes. Do this on a warm engine after serpentine belt is removed. The warm oil will not mask the problem like cold thick oil can. Noise generated means problem is internal.
If this is a stick shift transmission sometimes the clutch bearing can make noise and is a sign that bearing is bad.
May 13, 2013 | Ford Focus Cars & Trucks
My right front wheel makes a rattlen sound while i drive, jacked it and when i shack my wheel it moves a little in and out. what could this be? Thanks!!!! 1989 cadillac deville
Please replace your wheel bearings before you drive it anymore. It could possibly cause the wheel to come off and go into your wheel well. Your wheel bearings are bad..Depending on how much you drove it after hearing it, you may need a new spindle also.
Feb 22, 2011 | Cadillac DeVille Cars & Trucks
Mower blades froze up
Have you greased the bearings on the mower deck recently? Is there something jamming the blades?
Remove the deck and see if you can move the blades by hand. If you insist on not removing the deck to do this ... make sure the belt that drives the deck is not on the drive shaft of the motor to prevent accidental starting of the motor and instant mangling of your hand. If you can move all the blades, look for a faulty or worn out pulley on the deck. If the blades are frozen in their bearings, get replacement towers at your John Deere dealer or from a FixYa.com advertiser. If one is faulty or rusted ... replace them all ... as they are probably at or near the same condition. Do this job one time and do it correctly.
Thanks for your support.
Thanks for your interest in FixYa.com
Please evaluate this response.
Thanks
Good luck with your repair.
Jul 05, 2010 | John Deere 24HP VTwin Hydrostatic 48"...
The car makes a howling noise while driving it
well did the noise start after the tires were rotated?could be choppy tires,,,if not ,i strongly think it sounds like a bad wheel bearing,,,,if you drive and while its making the noise turn left and right quick and see if the noise gets louder and which way turning makes it louder,,if you turn leftand it gets louder its usually the right wheels bearing as you are putting load on it, if it makes the noise louder while turning right its the left wheel bearing,,,got it
Oct 08, 2009 | 2000 Pontiac Grand Prix
Have humming in front end area of my 2005 dodge dakota...increases with accelleration
SOUNDS LIKE YOU HAVE FRONT HUB/BEARING GETTING BAD..JACK UP FRONT OF VEHICLE,SUPPORT SAFELY..CHECK FOR ANY PLAY IN WHEEL BEARINGS..THEN TURN EACH FRONT WHEEL WHILE YOU HAVE 1 HAND ON COIL SPRING..YOU SHOULD FEEL ROUGHNESS IN COIL SPRING ON SIDE WITH BAD BEARING..THESE BEARINGS CAN BE HARD TO REPLACE..USUALLY SEIZED INTO STEERING KNUCKLE..I HOPE THIS HELPS
Sep 11, 2009 | 2005 Dodge Dakota
Engage blades makes noises
Sounds like the bearings are going out in one or both of your blade spindles. With the belt off,(and engine, of course) engage the lever on the dash. That will release the blade brake so the blades will be free to turn. Spin each one by hand. It will be easy to tell if the bearings are bad.
Jun 06, 2009 | Poulan 38-Inch Steel Deck 15.5 HP Briggs &...
Kenmore Dryer Model 970-C82062-10
The bearing or spindle the drum rotates on is probably bad or worn out. You can get to the back and turn it by hand and feel it when you turn it. You can tell if it is metal rubbing. If so, you can replace it.
Jan 25, 2009 | Kenmore Dryers
My zanussi aquacycle 1100 is making a very heavy clonking noise on spin cycle.Have you any suggestions? Thanks Craig
Sounds like the main drum bearings have gone.
Turn the drum by hand and if it feels rough or noisy , the bearings have gone.
There should be little or no noise when you turn the drum by hand.
It is quite an involved repair , as it entails a complete strip down.
Plz rate my comments.
Tanks, and merry xmas.
Dec 20, 2008 | Washing Machines
Jet JWS - 22CS / 708320 1 - 1/2 HP Woodworking Shaper Logo
163 people viewed this question
Top Jet Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Jet Tool and Hardware - Other Expert? Answer questions, earn points and help others
