Question about Sony Video Cameras
Error messGE 32:23 - Sony Video Cameras
  • gordonste288 Oct 14, 2010
    Does not work
    The camera is a Sony Digital Handycam, model DCR-TRV230E
    Does anyone know what error message C:31:23 means?
  • 10,515 Answers
This is a mechanical failure. a mechanical fault. The reel tables and/ or idler are suspect, as well as the mechanics surrounding them. It's also possible that the reel sensor themselves are at fault. Intermediate to major labor. Take the battery off the device, Give the camera a smart "smack" on the tape side of the unit and power it back up.If not, you need to send the unit for repair.
For repair, either you could contact Sony or :-
http://www.sonycamcorder-repair.com/
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Oct 14, 2010
  • jk4bs Feb 06, 2011
    According to the manual a malfunction that you can service has occurred you need to reset the camcorder.. This means remove all power including the coin battery that controls the time clock LCD readout the following might help
    Using a RESET button
    1. Locate the RESET button on the camcorder.
    2. Use a pointed object (like a ballpoint pen) to press and hold the RESET button for 2-3 seconds.
    3. After 2-3 seconds has elapsed, release the RESET button.
    Performing a manual power reset
    1. Turn off the camcorder.
    2. Disconnect AC power adapter.
    3. Remove the battery pack.
    4. Remove the lithium button-cell battery.
    5. Move the POWER switch to the CAMERA position for 15 seconds.
    6. Move the POWER switch to the OFF position.
    7. Reinsert the lithium button-cell battery.
    8. Reconnect the AC power adapter or reinsert the battery pack.
    9. Turn on the camcorder.
    If your camcorder is experiencing an issue and the issue is not resolved by performing the appropriate reset procedure above, then service may be required.
    Producer:
    Uploaded 30 video answers.
    Filmmaker:
    Uploaded 5 video answers.
  • Sony Expert
  • 65 Answers
Here is a video going over the problem you may be having.
Posted on May 08, 2013
    Genius:
  • 1,035 Answers
Hi. this is a common issue for thie camcorder. Might be a glithc from Sony. Here's how to reolved the issue. Remove the battery or power cable and count 10 secs. Connect everything and perform operations from the beginning.
All the best!
Posted on Oct 12, 2010
  • Angelito Rabago
    Angelito Rabago Oct 19, 2010
    Sorry for the late reply. Error C 31:22 is caused due to bad Gear assembly, to resolve this issue with the battery
    According to the manual a malfunction that you can service has occurred you need to reset the camcorder.. This means remove all power including the coin battery that controls the time clock LCD readout the following might help Using a RESET button 1. Locate the RESET button on the camcorder. 2. Use a pointed object (like a ballpoint pen) to press and hold the RESET button for 2-3 seconds. 3. After 2-3 seconds has elapsed, release the RESET button. Performing a manual power reset 1. Turn off the camcorder. 2. Disconnect AC power adapter. 3. Remove the battery pack. 4. Remove the lithium button-cell battery. 5. Move the POWER switch to the CAMERA position for 15 seconds. 6. Move the POWER switch to the OFF position. 7. Reinsert the lithium button-cell battery. 8. Reconnect the AC power adapter or reinsert the battery pack. 9. Turn on the camcorder. If your camcorder is experiencing an issue and the issue is not resolved by performing the appropriate reset procedure above, then service may be required.
Error messg 016-700 Memory Full
Try this, it may be a large print job held in memory.
Press 80-0-1327 to clear the message, cancel the current print job, and conduct the next print job, if any. · Press Cancel to cancel the print job.· Press Menu to open Stored Print and delete the holding job. · To avoid this error in the future, do the following:· Delete unnecessary fonts, macros, and other data in printer memory. · Install additional printer memory.
Oct 01, 2014 | Dell 2135cn All-In-One Laser Printer
Camera failed error message handler.handle message(-1)GALAXY Y GT-S5360
my camera say error message handler.handel messge(-1) ?
Apr 16, 2013 | Cell Phones
Error messge "Check Signal Cable"
Your Lcd monitor i guessed is working. Try to check your system ram or memory and video card. You must discharge your electro static in your hand first before touching any of the computer components because it is sensitive to electro static, you must hold the computer casing for about 1 minute only. Then unplug the video card and memory and clean the pin using eraser to remove the dust and brush (small paintbrush) it also. Dust can cover the video and memory pin which will not be detected by your motherboard.
Please rate me.
Nov 19, 2010 | Samsung SyncMaster P2450H 24" Wide TFT...
Dropped my cano a520 with lense out and now I get
E18 error is common error if the lens is broken already
bring your camera to the nearest repair center
Aug 21, 2009 | Canon Cameras
Sst programing on saitek X52pro , ones install I clik on the place that Im suppost to setup , then got messge error : Problem signature: Problem Event Name: APPCRASH Application Name: ProfileU.exe ...
sst programing on saitek X52pro , ones install I clik on the place that Im suppost to setup , then got messge error : Problem signature: Problem Event Name: APPCRASH Application Name: ProfileU.exe Application Version: 4.3.4.17 Application Timestamp: 44fd31e8 Fault Module Name: ProfileU.exe Fault Module Version: 4.3.4.17 Fault Module Timestamp: 44fd31e8 Exception Code: c0000005 Exception Offset: 00001fda OS Version: 6.0.6002.2.2.0.768.3 Locale ID: 1033 Additional Information 1: 253c Additional Information 2: 287b034b0bef0590cba0ccef4c4b4b77 Additional Information 3: 7de0 Additional Information 4: bfe79fb32a74e3eb99cc45f1169d5e8b
Aug 07, 2009 | Computers & Internet
My ccalculator won't graph anything. I get the error messge Inval
Press the 2nd button, then the plus button, then 7, then 1 and then 2. This will reset your calculator to factory settings
Jul 23, 2009 | Texas Instruments TI-84 Plus Calculator
I NEED TO TALK TO A PERSON
download a latestad java updated it
Feb 27, 2009 | Computers & Internet
Create a backup
No never hear of zonealarm. I was able to boot up in save mode and retrieve some of my documents but not sure what this critical error is i keep getting.
Sep 04, 2008 | Toshiba Satellite A65-S126 Notebook
Error messge on my brother DCP
You have to open the printer. The error means that either the encoderstrip isnt in good position or the encoder strip is stained with ink or the purgecam cant work well.
Read my solution here what to do:
http://www.fixya.com/support/t226406-keep_getting_message_unable_print_see
Oct 31, 2007 | Brother MFC 420CN All-In-One InkJet...
Video Cameras Logo
433 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
