Question about Black & Decker BR300 3''x18'' Belt Sander
It was working fine, then it all of a sudden the sanding rolls stopped spinning. The motor still runs loud, but no action.
The drive from the motor to the rollers is broken. You will have to replace that belt if available.
Posted on Apr 15, 2011
Doesn't spin
ok have you watched the machine go through the cycle you may find that it fills heats empties ok but you get no motor action ie the drum does not turn at all this is a common problem but only noticed when then clothes are wet after spin cycle If this is the case probably carbon brushes on motor and generally you will need to remove the motor to check or replace
Mar 04, 2014 | Bosch Washing Machines
Hi. My washer suddenly stopped running the high speed spin. The drum will roll for the cycle and rinse but it will not spin at the end so the clothes are coming out soaking wet. Any suggestions? ...
HI there,
Well first of all you can check the motor coupler-
To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning:
If it's spinning when you lift the lid, the coupler is fine.
If it isn't spinning then you may have a broken coupler. many washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it. Please post comments for more help or information.......
Good Luck!!
Thanks
Jan 24, 2010 | Frigidaire FTF2140E King-Size ENERGY STAR
Power window on 1990 Ford F150 stops working
the motor has an armature inside that rotates.if it stops on the bad spot,it will draw alot of current.the armature has copper plates with a very fine separation between them.after a while the brushes wear the copper down and it can bridge 2 together.the motor will still run,until one brush stops right where the 2 plates meet.if you bang on it it will work too sometimes.
Jun 12, 2009 | 1991 Ford F150
Kenmore 80 series. RUNS LOUD, THEN TURNS OFF AND RESETS...
you have something gotten into your pump ,,, it trys to drain and spin but overloads the motor and shuts down till the motor switch resets .... remove the pump and take out whatever gotten in it and if that not possable replace the pump.
Nov 24, 2008 | Kenmore 24032\24036 Top Load Washer
Picture rolls
Same as sherpi here, player was fine, and all of sudden started rolling and never stops. Rolls with or without a disc in it...seems to play the discs fine, but never quits rolling.
Mar 08, 2008 | Spectroniq PD-1100 DVD Player
Maytag Performa Washer spins fine but stops instantly
Check the unit next time it is in the spin open the lid up does it do the same thing?? if so it is working ok that is the Brake in the unit doing it Job but if it is really loud it maybe going out??
Jan 26, 2008 | Kenmore 22422 Top Load Washer
Black & Decker BR300 3''x18'' Belt Sander Logo
239 people viewed this question
Top Black & Decker Tools & Hardware - Others Experts
Jim Goldsmith
Jim Goldsmith
Rabbit Brains
Rabbit Brains
Are you a Black & Decker Tool and Hardware - Other Expert? Answer questions, earn points and help others
