Question about Pride Mobility Products Victory 9 Scooter 4 Wheel
From willaston auto electrics adelaide , customer brouht in a pride pathfinder 4 wheeler no forward or reverse movement, has power to volt gauge, horn works, any suggestions appreciated
  • Scott Frye
    Scott Frye Oct 12, 2010
    HOw old are the batteries?
    Is the drive lever engaged?
  • 692 Answers
Neville the problem could be numerous things but lets try the simple ones first. a bad throttle pot or speed control pot can cause that problem. Both of those are located in the tiller console and that has to be removed to test them. You can ohms check both with power off and you can voltage check them with power on. You should get a smoth change in resistance as you turn th speed pot and as you move the throttle forward and reverse with power off. alsdo chech the connections in the tiller and remove the seat and battery cover and check the connections at the rear of the scooter sometimes just moving the wires can get it moving again but that won't help you locate the problem if you can't isolate the bad connection or bad wire. Scooters are tough to repair because of the many connectors that they have and the cables runnig front to rear that can cause problems especially with Pride scooters Good Luck I know I didn't give you much but I'm not fond of working on scooters Hope this Helps
Posted on Oct 12, 2010
I have a celebrity pride 3 wheel scooter and when i move lever to forward or reverse all it does is click but no movement
Have you checked the speed pot is not turned down too low?
No flash / beep codes.
I would check motor connector on drive unit, motor brushes.
May 24, 2014 | Pride Mobility Products Pride Celebrity XL...
Honda 4 wheeler problems
I have a Honda 350 4 wheeler model trx350 4x4 ex I was riding put away the next morning I went out I could not get the auto reverse to shift. I can use the manual shift. All the forward shifts work any ideas
May 12, 2012 | Motorcycles
2000 pride celebrity sc440. has had pc board replaced 2 times. intermitten times it just dies. i clean all connections, and then it works for a while. it just died again. i found a broken resister,...
Hi donmorrill
Dosen't sound like the board at all. Sounds like you have a connection problem front to rear harness. I have worked on many celebrity 2000's and have found a bad connection with symtoms like yours. In the rear you will find where all the connections are plugged in. Check each one for continuity. Clean all connections, also make sure the little metal connectors are intact in the anderson connectors. But you do have a harness problem.
Good Luck
mimobility wizard_s.gif Wiz
May 02, 2011 | Pride Celebrity X 4-Wheel Electric Scooter...
I have a pride mobility a scooter, maxima, when attempting to move forward just a clicking soound occurs no movement
When mine does this it means she is not fully in gear. Try manually moving it back and forth a few inches and see if it clicks in.(Like moving the seat back in the car and it doesn't quite click in.) If it doesn't work take it fully back out of gear and try again. Mine is a pride victory 3 wheeler, to check the exact specs on yours follow the link below for a pdf of your user manual. See the bottom of page 34, (Troubleshooting)
http://www.rentascooter.com/downloads/_manuals/pridemobility/Pride%20Maxima%20Owner%27s%20Manual.pdf
Hope this helps:).
May 01, 2010 | Pride New Mobility Legend 4 Wheel Scooter
I have a 2002 Nissan Pathfinder that has 4 wheel drive. The truck will go in reverse but it won't go forward and there is a rattling noise coming from the transmission. What cold that be?
If you have reverse, and no forward movement, and noise coming from the trans, you have some type of internal trans failure. Fluid condition, and level should be checked. Also you can remove the pan on the transmission, and inspect it for signs of failure. But at this point, I would definitely say you have something gone wrong with the trans.
Nov 17, 2009 | 2002 Nissan Pathfinder
Goes in reverse but not forward
hi, that sounds like the scooter
a. the speed pot is faulty (Wig wam) thumb throttle , check just in case there a reverse switch,
b. been taking apart and reassembled incorrectly.
Regards
GeWiz.
Jul 03, 2009 | Pride Mobility Victory 3 Wheel Electric...
When turning the scooter on the system goes by it's self without pushing the handle to go forward
Sounds like the throttle mech has come loose, the lever is normally fixed to a pot with a long stem now if that's moved round it will power it self without any movement?
Apr 30, 2009 | Pride Mobility Legend 4 Wheel Electric...
PRIDE GOGO 3 WHEEL MOBILITY SCOOTER NOT USED FOR 3 WEEKS BUT KEPT CHARGED-NOW WONT GO -IT CHUG CHUGS AND THEN STOPS AS THOUGH THE BRAKE IS JAMMED ON. THE OTHER DAY IT DECIDED TO GO 200 YARDS USING FWD AND...
sounds to me like the power controller pot located on the handlebar lever that you use to go forward and reverse ? , is there any up and down movement with this lever , if so that will be causing intermittant power delivery.
Apr 25, 2009 | Pride Sonic 3 Wheel Portable Scooter
No movement, forward or reverse
sounds like it is in neutral, look for a lever on the bottom, rear of the scooter to pull up
Apr 24, 2009 | Health & Beauty
Power problem
throttle pot or loose hex nut that holds the actual forward and reverse paddle, may be slipping
Dec 20, 2008 | Pride New Mobility Rally 4 Wheel Scooter
Pride Mobility Products Victory 9 Scooter 4 Wheel Logo
189 people viewed this question
Top Pride Mobility Products Health & Beauty Experts
wcdoc1953
wcdoc1953
Colin Taylor
Robin Hill
Robin Hill
Are you a Pride Mobility Products Health and Beauty Expert? Answer questions, earn points and help others
