Question about Toshiba Regza 32LV67U 32 in. LCD HDTV
My tv will come on if I turn it on and off several times. Until it comes on all it does is try to come on and then the screen goes blank. I can hear the volume always, just picture turns off
  • 11,361 Answers
First, look at the screen in darkened room to see if you can see any slight glow from the screen, if it does, then the problem can be the T-CON (not getting the 12vdc) or the main logic board not feeding the signals to the T-CON board.
if not, next place to check will be the power supply module, make sure it has 24vdc which is required by the backlight inverter to work, the reason for not having 24vdc can be from bad DC filter caps (leaking/bulging top, high ESR) or short circuits in the inverter board which will cause the 24vdc supply to go into shutdown mode, so you may have to disconnect the power cable that feed the inverter board to see if the 24vdc will work without the inverter board hookup, you will need to apply about 3~4 amp of load to the 24vdc to make sure it can handle that. There are fuses on the backlight inverter boards also. So there is some troubleshooting you will have to do to find out the causes of the problem you are having.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Please post back what you find.
Posted on Oct 12, 2010
I have a 50" Samsung tv. The tv turns on and the screen comes on, then within 1 minute the screen goes black. I can still hear sound.
Samsung HL-R5087W TV screen goes blank -tv/sound on - Forums ...
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - About a month ago, the at various times the tv screen would go blankeven though the tv ... Try turning off the cable/sat box when the happens. ... In reply to: Samsung SP50L7HX DLP TV linked to Sky HD box - same problem .... on it comesback to normal. however, once it went off again (Black Screen) after only 2-3 minutes. ln-t4069f picture problem lcd warmup - Forums - CNET
Jun 11, 2015
Samsung LCD TV LN-T5265F Black Screen Diagnosis Help ...
Jun 11, 2015
More results from www.cnet.com
TV with Black Blank Screen Repair How to Troubleshoot ...
? 3:16
https://www.youtube.com/watch?v=kFdVi2ejfzA
May 8, 2014 - Uploaded by ShopJimmy.com
TV Repair Help for a TV With a Black No Image on the Screen ...Sign in to add this video to a playlist. ... LCD & LED TV Repair - No Image & Blank Black Screen Flashlight ... Easiest TV repair - How to Fix Power [TV turns off, freezes, or won't ... 1:26.Samsung LED TV Blank Screen & No Backlights Basic ...
Samsung TV screen goes black w/ audio still playing ...
? 1:49
https://www.youtube.com/watch?v=L9cjcsysdW4
Sep 11, 2012 - Uploaded by Roberto Ramos
TV screen begins to flicker then screen turns black while the audio continues to heard. I'm unable to see the TV Menu options when screen turns off. ... After turning the TV OFF then back ON again, the screen will flicker and then ... 1:26. Samsung LEDTV Repair - T-Con Board Replacement - No Picture on ...
Jan 28, 2016 | Samsung Televison & Video
Lexsor 32" widescreen LCD TV
sounds like av panel needs replacing................
cheers
Mar 26, 2011 | Televison & Video
Our TV whiel watching has a blank screen the comes
needs screen adjustment. knob located on flyback transformer
Nov 15, 2009 | Sony FD Trinitron WEGA KD-36FS130 36" TV
SONY KV32XBR400 (year 2000) screen is blank when power turned on
The clicking you are hearing was probably always there, it's just that when something goes awry, one pays closer attention. What you hear is probably a relay that connects power to the rest of the set. Since our sets can respond to a remote, they always have a little bit of life to supply power to the infra-red receiver so it can respond when 'off.'
I see two possibilities; the relay itself has burned contacts and not always 'closing' as it should, or, the high voltage circuit is failing to turn on as it should causing an excessive current to flow for a moment and a protective circuit to trip and disconnect the power from the main supply.
It probably will get worse if the problem is not found and could damage other circuitry as well.
Good luck finding a TV repair man who isn't deceased or out of business but I do recommend you try to have it repaired. Once repaired, it will outlast most any panel/flat screen-type TV as it appears nearly all of them are failing much too early in life.
You can check by entering just "LCD," "plasma" or "projection" plus TV in the search window here.
Oct 21, 2009 | Sony FD Trinitron WEGA KV-32XBR400 32" TV
When turned on, no picture, sound or response. LED is OK
I had a similar problem with my HANNSLounge 32", the screen switched on with green light but none of the front panel buttons worked (screen is black apart from showing the input source in the top left).
After powering off numerous times I tried starting up with a blank SD card in the reader and the tv cycled between red green and blue screens and then reset itself. (Some sort of firmware restore?) After which point I had a working screen again! (Will have to see how long it lasts for!)
Feb 12, 2009 | Hannspree HANNslounge 32 in. LCD HDTV 32
Screen goes blank.
PETTY SOON YOU WILL NEED A NEW MONITOR, IT PROBLY IS NOT WORTH FIXING,
TAKE IT TO A TV SHOP AND LET THEM LOOK AT IT, THEY CAN TELL YOU IF IT IS WORTH FIXING
CANDYMANGANDY
Jan 29, 2009 | ViewSonic VA720 17" LCD Flat Panel Monitor
Sony KF-60WE610 Screen and Sound On/Off
All symptoms in your TV shows that you need to replace its Lamp as it has been consumed its life hours and TV requires new lamp. Lamp can be obtained from Sony Website. Price is $200, Hope this info will help you to enjoy your Sony TV in coming days.
Aug 17, 2008 | Sony Grand WEGA KF60WE610 60" Rear...
MITSUBISHI CRT TV MODEL CT-33AC2SL
check for dry joints in power supply
Oct 09, 2007 | Televison & Video
Toshiba Regza 32LV67U 32 in. LCD HDTV Logo
180 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
