Question about Frigidaire Washing Machines
Washer not going into spin cycle everthing else is working
  • Frigidaire Master
  • 43,501 Answers
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Posted on Oct 12, 2010
Whirlpool front load washer (W-WFC7500VW1) was ran through the clean cycle. After this was preformed, the washer will not spin the clothes the dry. The washer will spin but never reaches the 'higher' spin...
I suggest going on the Whirlpool manufacturers website and check their forums for a similar problem. It could very well be something very easy to fix.
Jan 08, 2015 | Whirlpool Washing Machines
GE Washer works fine with 1 fault,,,it wont spin???Why?
If the other functions are in tune with the program without any faults then the control panel memory could be faulty or the processor sequential cycle is faulty due to a faulty IC.
Check with another program , remove power from panel and try if the panel resets. If not the control panel is a suspect
Jul 05, 2012 | Whirlpool Washing Machines
Spinning cycle sounds like it is rubbing against something
I take it there is a loud noise while in the spin mode.
That normally means your bearings x2 and seal need to be replaced. Truthfully it needs to be done by an appliance tech.
May 17, 2010 | Bosch Nexxt Premium WFMC6400UC Front Load...
Our Kenmore 417 48102701 goes through the drain and spin cycle however the spin cycle does not go fast enough to spin all the water out. Any suggestions?
After I move to a new home I have same problem, spin cycle was slow, I remove back panel, clean up the pump (found a quarter) also remove the top cover, I found due to the movement one pipe get disconnected, after reconnecting, everthing is fine.. also take a look inside there is a manual with service code....need a liitle bit of logic to decode it.. thanks..
Jan 01, 2010 | Kenmore 44102 Front Load Washer
Clicking sound durring sluggesh spin cycle.
i bet the tub block is going bad, visit my site and call me this is a repair that i would have to describe via phone.. whirlpoolpartssurplus.com
Jun 25, 2009 | Kenmore 24032\24036 Top Load Washer
Loud grinding noise only during the spin cycle.
Try looking at the solution for loud noise during spin with gray water in drain. This also sounds like the bearings on the shaft supporting the stainless steel drum, in the aft half of the outer drum.
Apr 05, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washer will fill fill with water but doesn't start wash cycle
it will fill but won,t spin, will throw out water as if it washed, then it take water to rinse but won,t spin ,then will throw out water as if it did , but clothes are soaked
Feb 21, 2009 | Roper RAS8445KQ Top Load Washer
Kenmore series 80 washer top load
Sounds like the clutch/brake assembly is slipping.
Feb 17, 2009 | Kenmore 15864/15862 Top Load Washer
Walking during the spin cycle
Try placing it on a rubber mat or carpet that has a rubber backing. The floor may be too smooth and allows it to walk.
Oct 12, 2007 | GE WSXH208A Front Load Washer
Agitator Not Working
check your motor coupler, lid switch
Nov 08, 2006 | Hotpoint VBXR1090D Top Load Washer
Washing Machines Logo
42 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
