Question about Ovens
I own a white westinghouse oven wwef3004kw , I sometime get A F1 code on the diplay. I need a list of these alarm codes.
  • 87 Answers
SOURCE: F1 code on my Oven
You have a bad control module.
Posted on Jun 08, 2007
  • 146 Answers
SOURCE: Jenn Air W131 F1 error code
This means that the Power to element relay energized during time of day display. You have a problem with the wiring harness and it is shorted or you need to change the power relay board (PRB). If it is a double oven, you need to change second oven board.
Posted on Jan 07, 2008
  • 10 Answers
SOURCE: GE Profile Performance Double Oven
I had a similar problem,  try the fix belowhttp://www.fixya.com/howto/h155060-dreaded_f7_error it may work.
Posted on Aug 20, 2008
SOURCE: Oven wont work
when i turn onether oven then a bipping alarm and oven will not come on. light come on but not heated up.
Posted on Aug 31, 2008
SOURCE: F1 CODE ON FRIGIDAIRE STOVE
I have a F1 code on my Frigidaire convection oven and a really cool beeping sound to go with it. I turned the breaker off and turned back on---doing the same thing...????????
Posted on Apr 11, 2010
Frigidaire oven displaying the f1 error code
You are experiencing a runaway temperature, or too hot of a temperature for the control board and sensors within the unit. When the unit gets this error code it shuts down for safety reasons. You would need a professional to diagnose the connections and control wiring to the control board, and the elements for safety.
Dec 30, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
Model 9114803590 Double Wall Oven displaying F1, lost manual.
The F1 error code means that the computer thinks a button on the touchpad is stuck. Sometimes this can be resolved by making sure the touchpad connector fits tight into the control board. The F1 code can be cleared by pushing CANCEL/OFF. If it returns the touchpad needs to be replaced .
The part number for the touchpad incase its needed is For the white color....WB27K5111 for the on thats black....WB27K5112 GENE
Sep 17, 2011 | Kenmore Ovens
My oven..whirlpool model...has F1 in the display window. What does this mean?
F1 error code usually means that either the touch pad or the clock (ERC) is bad. It's simple if your model incorporates both as a single assembly - replace the clock/touch pad, problem's solved. But, when the touch pad is a separate component from the clock, how do you tell which of the two has failed, without having to replace both? Well, we have a simple test that can show you whether it's the clock (ERC) or the touch pad (membrane switch) that needs to be replaced. The test is available on the error code page right below the list of brands.
Solve it with replace electronic oven control (also called EOC or clock).
Hope helps.
May 23, 2011 | Whirlpool 30" Self-Cleaning Freestanding...
We had a power outage and when the electricity was restored the oven is displaying an F1 and F7 code and is beeping the alarm, how do i stop this?
Hello, the F1 error code means internal logic failure (monitoring function) it sounds alarm and inhibit cook mode You can fix it by replacing the electronic range control (ERC)
F7 error code means the function key shorted for over 16 seconds, check for something pressing a key or preventing normal release of the key. You can fix it by replacing the electronic range control (ERC) if other component check normal.
Thanks
Jul 14, 2010 | Thermador CM302U Electric Double Oven
Error on display F1 & E1 Stove will not start
HI. This is a safety flip flop error code, caused by damaged circuitry within the electronic control board. This will require you to have the control replaced asap. This will correct the issue.
Part number (for white control) #3196971
Part Number (for black control) #3196970
Oct 19, 2009 | Ovens
F1 fault code Frigidaire electric range
Hi, you stated that you cooked a meal that produced some humidity inside the oven. this is the cause of the F-1 code. the humid conditions that were present at the time, caused the EOC(electronic Oven Control) to short. you will need to replace this control board at this time. it has failed.
May 20, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
F1 and alarm going off .turned power off and and on .kept flashing f1 and alarm noise
normally the f1 code stands for failed matrix in the control brd behind the panel. by removing the panel, after disconnecting power you should find a tech manual which should show the code and solution
May 19, 2009 | Ovens
F7 error code- what does this mean?
Frigidaire / Westinghouse / Tappan / Gibson
Oven Fault Codes
Display Condition Remedy
F0 & F1 EOC failure Replace EOC
F2 Oven over heat Defective Sensor or EOC
F3 Oven Sensor Open Replace Sensor
F4 Shorted wire or Sensor locate short and correct it
F5 EOC failure Replace EOC
F6 EOC failure Replace EOC
F7 EOC failure Replace EOC
May 17, 2009 | Frigidaire 30 in. Electric Gallery Series...
Ovens Logo
70 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
