Winegard model #RT8000S ,WO6AO2. all hooked up and have signal but dish network requires a SW64 switch to be installed. This switch is not a physical part,but a Dish network receiver setting. How do I change the current setting ________? to this SW64? The Dish receiver is a #222 HD with a coupler between the dish and the receiver that "t"s sat-1 and sat2 into the single coax from the dish. Thanks, Jack in AZ.
    Top Expert:
  • Computers & ... Master
  • 78,010 Answers
You must contact dish network for this information.
Posted on Jul 07, 2017
How to hook up Dish Network Receiver
which Dish Receiver do u have. if it is a Dual Tuner (322,625,622, 722) u run a RG6 Coax from the Dish to the back of the Receiver. on back of the receiver there should be two ports (Dish 1,, and Dish2) u will need two short pieces of coax and a Separator ,(which should have come with the Receiver. u hook the coax from the outside Dish to the single port of the Separator , now u run a coax (or RCA or what ever) to the TV. Turn on TV and Receiver.
on the Dish remote u hit the Menu button and hit #6 then #1 and #1 again (wait for each screen to change ) u should see a signal bar at the bottom. U will need to get someone to turn the dish a little at a time till u get a signal. once u get a strong signal u hit the Check Switch and let it program.
Sep 23, 2014 | DISH Network Televison & Video
Not receiving signal from wcyb channel 5 on winegard hd7697 antenna
try installing a tv signal amplifier on the line from the antenna just before the tv. Tv stations put out differing amts of power, one could be stronger than the other.
Mar 21, 2014 | Winegard HD7697 High Definition VHF/UHF...
My gm-1518 sounds like it is lining up on a satellite, but my receiver shows no satellites picked up. It has worked perfectly the last time I used it (July 4th week). Do you have any solutions to this...
This problem is a software glitch affecting 301, 311 receivers and the 5xx series DVRs. Even though the manual says not to, the solution is to select "Superdish" and "Alternate Dish" before doing a check switch.
Aug 30, 2011 | Winegard Gm 1518 Carryout (tm) Automatic...
Just moved my TV to a home with cable. It was hooked up to Dish network. there is no signal. Thank you.
We would be happy to help get your DISH Network signal back.The first thing we want to check is if there is anything blocking the signal toyour satellite dish like tree branches, severe cloud cover, or snow build-up.If it is safe to do so, remove the obstruction or wait for it to pass. If thatis not the case then reset your receiver by unplugging it for 10 seconds thenplugging it back in, the reset may take up to 5 minutes to finish (note: thereceiver's power plug usually has a red tag attached to it). At this point wewant to check the connection between your receiver and the outlet; please visitthis link and select the model receiver you are using to check the wiring ofyour receiver: you have check the connections perform a check switch test. Press the menubutton, then the numbers 6-1-1 on your DISH remote, this should take you to thepoint dish screen, select check switch on the right, then test on the bottom ofthe screen. Once the test is complete exit the menus and let the receiveracquire the signal (If Error 836 appears, do not save the matrix, cancelit and call our 24/7 customer support number listed below.). After all thesesteps if the receiver is still not getting the signal it should please give usa call on our 24/7 customer service line 1-800-333-DISH (3474) for additionaltroubleshooting.
We hope this gets your signal back. Thanks for choosing DISH Network!
Phillip Chang
DISH Network Customer Service Representative
Nov 12, 2010 | Olevia 742I 42 in. LCD TV
Does the dish network 322 receiver require two lines from the satellite to the receiver?
It does require 2 lines form dish unless you have a switch installed such as a dp34 or you have Dish Pro plus LNB"S on your dish and you can use 1 feed to the reciver and use a separator to separate the signal into sat 1 and sat 2 (note: a standard splitter is NOT a separator) a separator is dish brand equipment.
Oct 15, 2009 | DISH Network 322 DTV Receiver
Dish Network - Loss of signal after smart card upgrade.
Hi I will be more than glad to assist you in this concern.. Since you did already all the troubleshooting to fix the problem and according to the customer service, just run the check switch and test, that should fix the problem, but it didnt. The blue card that your refering is the g3 smartcard, it started when u insert to the 301 receiver.. It could be a bad smartcard or the receiver is bad, If you have another solo receiver in the house, just to isolate the problem, try to hook up the other solo receiver in the room where the 301 receiver is hook, run a check switch and test to the other solo receiver, once its done check your sat and signal, once its ok, cancel all the way out and it should acquire the sat will show attention 015 and let it finish the progress until it download the programming guide.. once u got a picture and the problem still exist with a different receiver. the problem is with the receiver and the receiver needs to be replace, if you call on dish network tech support, tell them that you try using another receiver and install to the room were the 301 is located, so that they wont do a troubleshooting again.. that is.. if you have another receiver to test and isolate the problem, but if not request for a service call so that they will send tech to your house.. please feel free to get in touch.
Sep 04, 2009 | DISH Network 322 DTV Receiver
I have a philips TV that is digital 27PT8302/37 32PT8302/37 and I cannot get any digital channels I also have a winegard amplified Antenna, and I am connected to dish, All was working well and now after...
you should have a seperate tuner [marked digital] to hook up the antenna then tell menue where to look and reprogram
you could use a box and use channel 3 or 4
i assume you have the dish hooked to auxilary in
Sep 01, 2009 | Philips 27PT8302 27" TV
Hooking up a tv
Hi first of all are you using scart leads to plug into each device here is how it should be set up ok
1. Scart lead from dish network into vcr
2. then other scart from vcr into tv
3. Now ti recieve the signal from the dish network you need to have the telly on the right av channel so that its picking up the signal from the vcr.
you can test this by changing the channel on the vcr controll or direct via buttons on vcr.
If the channels change then your on the right av channel.
Now when your on right channel on telly you need to now make sure dish network is on and on a channel or press the tv guide button just so you know what your looking for when the picture comes through.
You need to press av on the vcr controll this will then pick up the signal from the dish network via the scart lead as av is the channel for scart lead.
say if you was recording from dish net to vcr you would put the vcr on av to pick up the signal so press av on vcr controll this should then allow you to watch the dish network with no problems.
Let me know if you still cant and ill assist you further if it dont work tell me what you have done so i know how much you have done ok
Feb 10, 2008 | Toshiba TheaterWide 46HM94 46" Rear...
Computers & Internet Logo
63 people viewed this question
David Payne
David Payne
