Question about Samsung DVD-VR375 DVD Recorder/VCR
I am trying to record with VHS from TV and not using a cable box. No results. How do I do this?
  • Samsung Master
  • 5,471 Answers
This unit doesn't have a tuner. So unless your TV can provide video out (not a common feature) to the dvd/vcr recorder, you need a tuner. A set-top tuner box for OTA would work. With a little work, you could also use a tuner (USB or PCI slot card) in a computer. Usually you need a converter box unless your video card can output in a non-RGB format. The manual for this device is available here: http://www.samsung.com/us/support/downloads/DVD-VR375 .
I wish that I could be of more help.
Posted on Oct 12, 2010
  • pvandermill Oct 12, 2010
    Thank you so much!
    Paul
  • Cindy Wells Oct 12, 2010
    You're welcome.
How do I connect my cable box to my DVD/VHS recorder & to my TV?
Cable box-----(input)DVD/VHS(output)-------(input)tv
Dec 17, 2011 | Televison & Video
I have a new vhs dvd player recorder that will not record.
please note in your vhs dvd manual it tells which dvd (maxell, tdk etc.)are compatible with the recorder
okay do you have a cable/satellite box connected to tv/monitor? yes or no
yes- is the the tv on ch 3? cable connected to cable box in, cable box out connected to dvd in,(on dvd set up menu make sure broadcast is cable) dvd out connect to tv... ? please note some dvd recorder will not record HBO (you can record on vhs tape)
no connect antenna to dvd in, dvd out goes to tv.....
hope this help...
May 20, 2010 | Quasar VHQ400 VHS VCR
Taping to vhs from digital cable
You do not need to leave the TV on. To get the clearest picture you should connect the AV cables (yellow, white, red) from the cable box to the VCR, and from the VCR to the TV. There should be a setting on both the TV and the VCR to set the input to VIDEO so you don't have to use channel 3. You can shut the TV off while recording if you want. Also be careful because if you use the channel guide or info button while recording, it will show up on the tape.
May 20, 2009 | Samsung VR8460 VHS/S-VHS playback VCR
Quazar Model VHQ520/VHQ540 cannot record after inst Digital Conv
You need to set the vcr to channel 3 or 4 (whatever channel the digital converter box is set to broadcast on) to record a program. The digital converter box has to be set to the channel you want to record the show from.
Apr 09, 2009 | Quasar VHQ400 VHS VCR
VCR doesn't record since Comcast installed digital box
Try this..Run cable line into VCR in, cable from VCR out to box, then cable from box to TV..this might work...I have done this for YEARS and it is never failed. You can then watch and record 2 things at once.
Feb 12, 2009 | Proscan PSVR72 VHS VCR
How can i connect the dmres15 to my cable box, dvd/vhs player
Yea I have the same set up and did the same thing as that your trying to do and what you have to do is run both the cable box and the VCR through your TV using the inputs. As well as a PS2 running through imput 3.
Hope I helped
Jan 30, 2009 | Panasonic DMRES15 DVD Recorder
VCR will not record
yes your hook is all correct...but still will not work......unless this is a d-vhs recorder...(and the other way to record hd is dvr)....(note dont throw the standard vcr away) it might and can be use later down road
Jan 15, 2009 | Proscan PSVR73 VHS VCR
I cannot record using a DVD/VHS player.
You can record. From antenna to converter box, from converter box to vcr. From vcr to TV.
TV on Channnel 3 VCR on channel 3, and set channel on converter box. Then Record.
Time recording works the same way, but you can set for only one channel at a time. Tht is the only restriction that I have not overcome. The converter box sets the channel. Gee Whizz
Dec 14, 2008 | Philips Magnavox DVD/VCR Dual Player
Stupid question recording on a vcr
If you have a cable box:: the RF cable from the outside to BOX, the BOX to the INPUT of vhs video, the OUTPUT of video (VHS) to the back of TV.
Keep the channel for the reception of tv through CABLE BOX according to cable box directions.
Put the ch. on the cable box to ch. u want to record...place blank vhs tape ( with the TAB in back NOT broken off ) press [record] usually red button.
Oct 27, 2008 | Televison & Video
Magnavox PIP, Insight Cable box, Sony DVD/VHS
1st conect cable, then 2. VHS , Then 3 dvd to tv.
Then you can record Cable wile watching a DVD
Nov 07, 2007 | Philips Magnavox 9P6034C 60" Rear...
Samsung DVD-VR375 DVD Recorder/VCR Logo
369 people viewed this question
Jerry Greenberg
Jerry Greenberg
