Question about Fossil Arkitekt watch
What do the top and bottom buttons on the side of the watch do, and what ar the three smaller dials for?
Are all steve madden watches water resistant where can I get a manual for my watch I bought it at ross store the back says MADDEN MENS SMMW009 and the asin at amazon is B072186DBL.
No, they're not all water-resistant, and yours certainly isn't (read the Amazon details).
I strongly suspect that the top and bottom buttons along with the 2 sub-dials are there for decoration only. I bet that if you examine the hands on the sub-dials carefully, you'll find they're glued on.
As for a manual - you don't need one, you set the watch like any other modern 3-hand quartz watch.
Oct 25, 2017 | The Watches
How do i change the time on the three small dials
Hello Garrett,
"Three small dials"... My guess is that we are talking
a chronometer... (stopwatch)... "ZERO Process".
Not only are the three sub-dials usually settable... but also the sweep second hand.
Trouble: After resetting the watch... the hands go back to the same position...
Solution: You want to "ZERO" your dials... one by one.
These watches typically need to have the stem out to the third position... then press the top "start" timer button... observe ONE of your dials is moving. As it approaches the desired number release the button and step it into position with single button pushes.
Go to the bottom "stop" button... Repeat the process!
Push the stem in to the middle "set" position...
Repeat the process!
Again... press the top "start" timer button... zero
and finally press the top "stop" timer button... and zero.
Set the time and date... push that stem back into the home position... and record 35 seconds on your watch... stop and reset...
If everything does not come back exactly to ZERO...
Then that is called an iterative process (do it again).
Fine tune it!
Good Job.
(comment me back if I didn't hit the spot)
Horology Wikipedia the free encyclopedia
Feb 10, 2016 | Watches
What are the buttons for on my bulova c975505
The top button on the right will start and stop the chronograph (basically fancy word for stopwatch) timer counting - when started you will see the smaller subdials inside start to move, they are counting time upwards. Hitting the top dial again will stop the time count. Hitting the bottom most button will reset the chronograph time counter dials back to zero, so that you can start them again to time something new and properly start the timing from zero. The center " button" is the pull- out crown which allows you to change the time and date as you pull it out to different notches. Hope this helps!
Sep 28, 2014 | Watches
Setting Time on Police Hammerhead Watch PL 13088 JS/02
the three dials are for three different time zones, there is no minutes or seconds.
to adjust the middle dial just push the small bottom which is located on the back side of the watch
Jan 04, 2013 | Police hammerhead pl13088js-04
I have model fs-2919 would like to know what the other dials are for i dont have the booklet thanks for your help
The three small dials on this watch are all part of a "stopwatch" system. The small dial at the 12 o'clock is for tenths of a second( each half circle completed is one second or 1 whole rotation equals 2 seconds.) the small dial at the 6 o'clock counts a full 60 seconds for each revolution, and the dial at the 9 o'clock counts minutes(one full circle equaling an hour.) when the stop watch is started the 12 o'clock and 6 o'clock dials will start at the same time. you will notice that every half turn on the top dial equals one "tick" on the bottom dial. After the first minute of timing the top dial will stop ticking as it is for more precise timing of things that take less than 1 minute. each full rotation of the bottom dial will then equate to one "tick" of the 9 o'clock dial. hence the three dials counting tenths of a second, seconds and minutes. the setting of these dials is fairly easy once you understand the purpose. on the side of the watch there are two buttons(one top and one bottom) with a setting wheel in the center. When in use the top button starts and stops the stopwatch and the bottom button resets the counters. To set the watch simply pull the center wheel away from the watch all the way(2 clicks) set your minute hand and hour hand and then tap the bottom button repeatedly until the small dials all line up straight up. once that is done push the center wheel button halfway into the watch or one click to set the date. then simply push the wheel the rest of the way in and voila!!! hope this answers some questions
Apr 05, 2011 | Fossil FS2919 Wrist Watch
Howdo I set time on a puma watch pu910222003 blockbuster circuit touch screen
Setting the time on the PU910222003 Puma ladies watch.
The process is actually less complicated than you would think.
First, a couple things you need to know and remember.
1. The watch has a safety feature which requires you to press the touch button on the right side of the watch before you can do anything as far as touching and changing anything. If it did not, every time you accidentally touched the dial something would change.
2. Touch means you are touching the dial and the (stones or outer edge)
To change the time, day, date etc, on your PU910222003 you must first press the touch button on the side. The word touch will light up (display) inside the watch on the right side of the dial.
Now you are ready to change stuff.
Touch the dial and the little what looks like bling at the bottom of the watch. You need to be touching the watch dial and these stones at the same time to do anything we are about to do.
While touching and holding the bottom of the dial you may see the back light turn on.
That is actually how you do that.
By continuing to touch and hold the bottom of the dial, you will then see the word hold at the top and then the hour of the time flash.
To increment the time or decrement the time, touch the right side of the dial or the left side of the dial. When you have arrived at the current hour, touch the hour at the top again and the minutes will begin to flash.
Continue to set all settings in this manner until you are satisfied. Touching the top to move to the next setting and right or left of dial to go up or down.
When you are done. Touch the bottom of the dial to exit this setting mode.
Day to day use,
Touch the time at the top of the dial to scroll through the time, chrono, alarm etc. To see time if the screen saver is on, touch the left side of the dial. Touching this repeatedly will also scroll through all the phrases programmed into the watch.
While touching and holding the bottom of the dial you will see the back light turn on.
Cool feature,
This watch actually has two displayable times you can use if you travel often to a second time zone. Press the touch button on the side and touch the right side of the dial. Touching it for a second or two will display the time of the second time zone. Touching and holding for a couple more seconds will cause the T2 on the display of the left side of the watch to flash and eventually switch to the second time. I am thinking that touching the bottom of the watch while displaying the second time should allow you to set this time also.
Feb 20, 2011 | Watches
I have Puma-Time touch screen watch (PUMA men's Blockbuster Circuit Touch Screen Black Watch but unable to set the time.
Dont have that particular watch, but see if this works.
The process may be less complicated than you would think.
To change the time, day, date etc, on your watch you must first press the touch button on the side. The word touch will light up (display) inside the watch on the right side of the dial.
Day to day use,
Cool feature,
Feb 12, 2011 | Puma Active Collection Dynamic Posh Black...
I have Puma-Time touch screen watch (PUMA Women's PU910222002 Blockbuster Circuit Touch Screen Crystal Accented Black Watch but unable to set the time.
Dont have that particular watch, but try this.
Day to day use,
Cool feature,
Sep 17, 2010 | Puma Active Collection Dynamic Posh Black...
Pod Watch, Trying to change the digital date
Somehow I have put mine right, I held the top lefthand button in and cycled using the bottom lefthand button, hope you can do the same.
Regards
Chris
P.S. If you get a copy of the instruction it would be nice to have a copy or the link.
May 19, 2009 | Watches
Cannot set dials on a Paul Jardin watch which came w/out instruct
THE OTHER 3 DIALS ARE FAKE AND DON'T DO ANYTHING,IF YOU LOOK CLOSELY THEY ARE JUST MORE OR LESS TACKED IN PLACE.
Feb 22, 2009 | Bulova Millennia Motion 96B34 Wristwatch
Fossil Arkitekt watch Logo
131 people viewed this question
Top Fossil Watches Experts
Ansel Alberto
Ansel Alberto
Jimmy Accardi
Are you a Fossil Watch Expert? Answer questions, earn points and help others
