Where's the reset button located for the light bulb after the TV light bulb Have been replace for a PHILLIPS TV MODEL# 55PL9524137?
  • eugenetoves Oct 15, 2010
    Yes, the solution was very helpful, thankyou.
  • 11,800 Answers
Full instructions in the manual at the page 73. If you don't have it you can download it from here
http://download.p4c.philips.com/files/5/55pl9524_37/55pl9524_37_dfu_aen.pdf
By the way there is no reset button, it's an entire procedure done in the Menu.
Posted on Oct 12, 2010
Blinking power button
follow this test and fix it. GOd bless you
You simply need a screwdriver (Phillips-head) and then follow this guide:
  • Reset component settings. Usually, the problems you encounter with a projection TV may be resolved through the resetting to its factory settings. If you experience inaccuracies in the color, reset the television's PerfectTint/PerfectColor capabilities. Simply press the Menu tab and then highlight "Perfect Color" using your right key arrow. After this, press "Enter" and then "Reset" in order to reset to factory settings. If you have audio / video problems (VCR or DVD player), simply press "Menu" and highlight the "Reset" option.
  • Reset television controls. In case you cannot fix your TV via its component settings, there are other ways of resetting. Just select "Menu", key in "1, 2, 3", and then press "Enter." In doing this, the TV's manufacturer's specifications will all be restored. If your TV's power system does not function, you should perform a complete system reset. You can do this by clicking on Reset System button located at the TV's control panel. Your television will be turned off and then a green light (LED) will quickly flash for approximately one minute. Once the light has stopped flashing, your TV should immediately turn on.
  • Use your remote control. The first step is to inspect the batteries of the remote control and see if they are functioning. If its power button starts to blink several times once you turned it on, then the batteries need to be replaced. See to it that your remote control is used within about 20 feet from the television. Make sure also that nothing blocks the space between the remote control and the receiver.
  • Check the fan. Once the television is turned off, it is just normal for its fan to become louder. A projection TV actually depends on its lamp, which requires cooling so that it will not prematurely burn out. If the room where your TV is placed is very hot, the fan would also continue to run.
Replace projection lamp. To properly do this, make sure that the lamp's bulb has cooled down and the TV is unplugged. Carefully remove the cover of the lamp's compartment using your screwdriver (Phillips-head). Unscrew the sealed part of the lamp that can be found at the television's rear part. Take away the old lamp cartridge and then insert a new one. Seal the lamp with screws, replace its cover and then screw tightly.
Nov 04, 2013 | Toshiba TP50G50 50" Rear Projection...
I have a 57inch toshiba theaterwide HDTV projection screen tv and when I hit the power button all I get is a blinking red light with no picture or sound.
please make this adjustment, and fix it. God bless you
Nov 03, 2013 | Televison & Video
57 inch toshiba theaterwide HDTV projection. When you hit the power button there is a blinking red light and the tv doesn't power on. Is the tv shot
please this test and fix it. God bless you
Mitsubishi tv keeps turning off.
Hello there please check the following in your tv;
Reset the component settings. Most problems with Mitsubishi projection televisions can be resolved by resetting the television to factory settings
If this does not work then a full system reset should be performed on the control panel by pressing the System Reset button. The television will turn off and the green LED light will flash quickly for a minute. When the light stops flashing, the TV will turn on.
If that still doesn't work, then the projection lamp might need replacing and here is how to do that;
Ensure that the bulb is completely cooled and the television is unplugged. Use a Phillips-head screwdriver to remove the lamp compartment cover. Unscrew the lamp cartridge on the rear of the television. As opposed to the cover door, these screws do not actually come out of their chamber and simply loosen the lamp assembly. Remove the old cartridge and insert the new one. Secure the lamp with screws, then replace the cover and screw in tightly.
Please note that, Finger oils can cause the lamp to malfunction.
Projection lamps are powered by mercury. Wash hands thoroughly after replacing the projection bulb.
GOODLUCK
Jul 04, 2010 | Akai PT61DL34 Television
Recently my wd-52327 said it needed new bulb(steady orange light). i had replaced the bulb 7 months earlier and didn't want to see the light so i reset the lamp timer. well the bulb blew the next time i...
If you have a voltage meter you can pull the bulb out and check for continuity by placing the probes on the power plugs of the bulb. If you have continuity the bulb should be good, and it may be the lamp ballast.
Nov 21, 2009 | Mitsubishi WD-52327 52" Rear Projection...
I have a TV 48" PTV W/RemoteModel 6P4830W TV repair said that it
The problem is not in the bulb but in the display coolant... http://servicemanuals.vstore.ca/product_info.php/pName/phillips-crt-coolant-replacement-kit/cName/repair-kits...The step by step procedures and illustrations are included in the kit.
Sep 25, 2009 | Philips Magnavox 9P6034C 60" Rear...
Cannot find a replacement bulb (Phillips X4J-40 watt)
I had the same problem and found bulbs that fit through elightbulbs.com. You have to look for a European base, 40 Watt, 120 Volt incandescent light bulb. They are about $3.50 each plus shipping. I bought two and they are excellent. I've ordered another 6. They are shorter looking than the original Phillips bulbs, but just as bright and you don't have to replace the sockets. Good luck!
Apr 03, 2009 | TecnoWind 90 cm (approx. 36 in.) Classic...
Orange light on the front of the TV
Replaced bulb for zenith e44w46 lcd but the orange light is still on how can I reset the bulb timer on my own without throwing down another 85.00 for a repair guy to reset my T.V.
Jan 26, 2009 | Zenith E44W46LCD 44" Rear Projection...
Picture quality of my LG Projection TV is very poor
Bad Light engine call UED for price on rebuilt one if they have it!1-800-648-6657
Dec 19, 2008 | LG RU-52SZ51D 52" Rear Projection...
Televison & Video Logo
74 people viewed this question
Top Televison & Video Experts
Electro Med Services...
