Question about RCA 32V420T 32" TV
Powers on by itself
Turns on by itself,goes to full volume,changes channels but picture is great.whats going on?
  • 1 more comment
  • drgnmstr901 Jun 01, 2008
    its the 32v432t tv.
  • crazleg Jun 06, 2008
    I have the same problem asdrgmstr901
  • Anonymous Jun 19, 2008
    same problem. I unplugged for 8 hours and it worked for 4 hours. then it started again. off on up down menu wierd stuff.
TV worked FINE for the past 2 yrs---this morning we woke up and the screen is totally BLACK! No sound..nothing. REmote doesn't do anything to the TV. Red light says ON unless we unplug it. Remote won't turn off the TV.
Any advise? Picture tube??
Worked great w/out any problems until we woke up today!
Thanks,
Tina
Posted on Sep 06, 2008
SOURCE:
LG 42LC7D-UB after few minutes the sound goes off and channel change by itself
When heats up, the supply voltage from the main power supply board goes less. Check all the soldering to this board for any loose solder terminals. Resolder all the suspected solder terminals by applying a little more solder. If it do not help you, replace the board as card basis.
Jan 09, 2013 | LG 42LC7D-UB Television
Bush lcd42f1080p100hz remote will not turn tv on
I had come home about a week ago and pushed the power button from my remote but my tv did not respond. So I just went to the front panel and pushed power but once the tv turned on, the volume was on full blast! I used the front panel volume decrease to get the volume down, but when I stopped pushing the button, the tv increased its volume to full blast again by itself! Naturally I just turned the tv off for a few moments. I tried the remote again, no response again, so I used the panel power button. The tv volume was still full blast when it turned on but after I decreased the volume it stayed this time. The picture is and has been perfectly fine and the tv was working fine. The next day the problem started all over and now once we turned it off from frustration of having to manually use the panel to change channels, it now will not turn on at all. I have changed batteries from my remote, reprogrammed my remote, pushed system reset several times, unplugged it for a while, bought a new surge charge, and even held the menu and device panel buttons for 10 sec and tried to turn the t.v. on again! What other options do I have or what may be the issue at hand and possible parts that may need to be replaced?? Thanks!!
Nov 02, 2012 | Televison & Video
I have an 1998 rca premiere and it keeps changing channels by itself and turning itself up
You need to change the picture-size by using the TV remote and or cable remote.
On the remote look for P-Size, Zoom, Sreen size or Ratio.
Nov 10, 2011 | RCA P52937 52" Rear Projection Television
Impossible to change channels, turn TV on, Power and Opc blinking
go into programming mode and search for channels   it will do this automatically to find all antennae and all cable channels    if this is hooked up to a receiver box then only channel 3 will be found or used    also most tvs are computerized these days and at times it will need to 'rebooted'     unplug the power and wait 10 seconds and plug it in again    this may have to be done whenever you are locked out from changing channels or using the volume controls
Nov 05, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Change channel, lose picture. power off/on, picture appears
switched HDMI plug from HDMI1 to HDMI2 port and that solved the problem
Oct 11, 2009 | Polaroid Televison & Video
Apex tv at2708s TV will come on by itself and will change channels on its own.
This is the common symptom of defected IC memory 24COxx,replaced this IC so it will works normal again.
Feel free to ask whatever the result...
Hope this may help you;
DON"T FORGET TO RATE:
Sep 07, 2008 | Apex Digital AT2708 27" TV
Powers on will not change channels or video inputs
Is your remote programmed properly? If it is a universal remote, try setting it to one of the different codes for your brand. Sometimes the power and mute buttons and things like that are the same for all different types of a brand, yet all of the channel and volume things are different. If it's the remote that came with the TV, then I would try to get a replacement, as it could be faulty. Hopefully this problem is with the remote, and not the TV. Find if this is the case by using the volume/channel buttons on the TV itself. If they work, then you can be reasurred you don't have to call the TV repairman, and you will probably be able to fix this problem yourself.
Mar 16, 2008 | Televison & Video
Help Finding Replacement Parts
I had the exact same problem with the channel/volume autoshifting. I found a electronic firm that would rebuilt the board for $185.00 plus shipping-----screw that. I cut the plastic hold down nubs on the channel/volume buttons itself and disassembled the contact. Inside the button was a copper metal disc showing arc tracks and "carbon scoring" on the underside. I just removed the button guts and now use the remote for channel and volume adjustments. So far the power button still works for me. I may try buffing and cleaning the disc and contacts later, but what the hey, I'd rather surf with the remote from the couch.
Jan 09, 2008 | GE 31GT740 31" TV
RCA 32V420T 32" TV Logo
224 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
