Question about Pioneer SIR-PNR2 SIRIUS Radio Receiver
Shows "updating". Never completes. Pulled power plug and retried. No help. Displays channel 0 until antenna is pluged in then updating. Displays "antenna failure" if antenna is unpluged during "updating".
Posted on Nov 06, 2010
My box keeps saying boot. When I channel search, no channels appear. How do get channels to watch?
Plug the antenna into the ANT IN input of the STB. Forget about the RF IN output of the STB. Plug the 3-way output of the STB into the corresponding 3-way input on the rear panel of your LG TV.
Sep 18, 2016 | LG Televison & Video
I have an indoor digital aerial connected to a free view box but when I automatically tune the TV it comes up with no channels found check aerial connection
Possibly. Try rotating the antenna a little bit and retry tuning. Keep on doing this until you get your channels. If this doesn't work, raise the antenna as high as possible and try again.
Dec 20, 2014 | Goodmans GTVL19W17HDF 19 in. LCD TV
Hitachi l22d01ub
Make sure you have some sort of digital receiver attached. If you are using an antennae, you need an HD convertor box. If you have the necessary components to recieve a signal, make sure your TV is set to recieve the signal for the correct input in your options section. THen retry scanning for channels.
Aug 29, 2013 | Televison & Video
My CM7000PAL unit only displays "Channel Master CM-7000PAL..... Loading. Please wait..." then turns off and then repeats the same message. I don't know how to fix this issue. Has anyone found a solution?
To unlock the Channel Master CM7000PAL DVR:
1. Unplug the recorder from the wall outlet and DISCONNECT THE ANTENNA. Now plug it back into the wall power outlet.(This will keep the recorder from freezing and rebooting)
2. let it go thru it's normal bootup, tv guide search, etc.
3. When you are able to, hit MENU and then go up to TIMERS. Delete all of the record timers. Unplug it, re-connect the antenna, and plug it back in.
4. After a now a proper bootup, re-program you timers and you will be good to go.
5. And the best thing is, all of your pre-recorded shows will still be there on the hard drive.
I have 3 of these 7000pals and 2 have done this same thing, one of them did it twice. I would suggest that you do a yearly "TIMER CLEAN" to avoid this trouble in the future.
Aug 06, 2013 | Channel Master CM7000PAL HD DVR
Sharp Aquos 32 LCD freezes on air channel
I had the same problem, same channel, same day. It must be a problem with signal strength. With the TV on, I unplugged the coax cable that leads to my antenna (I am not on cable). As soon as I disconnected the antenna, I could change the channel off of 11.1. I plugged the antenna back in and all other channels work. Hope this helps.
Jan 27, 2013 | Sharp Aquos LC-32D42 TV
Says updating channels 0% complete. Has been doing this for a number of days. Contacted Sirius and they say they can't help me.
Antenna jack is busted, or you have no signal (also due to a bad antenna jack). Without a signal, it will just stay at that screen, since it's trying to download the update. You can purchase repair services for your model on eBay.
Aug 21, 2011 | Sirius Starmate ST2 Satellite Radio...
Can't find a manual online. What does 5/4 mean, and how do I turn it off? Same for E. My biggest problem is that when I add up numbers with the print function on (for depositing large batches of...
The manual for the Canon P1-DHV is online at http://www.usa.canon.com/app/pdf/calculator/P1-DHV_G_USA_HWB.pdf>.
When the display shows "5/4", the calculator is doing 5/4 rounding which means: 5 or above round up, 4 or below round down. To control rounding press the "5/4" key.
When the display shows "E" the calculator could not complete a calculation. It can be because of dividing by 0, or because the total exceeded 1 trillion, or because the operator entered calculations faster than the calculator could complete them. Press the CI/C key to clear it.
I can't explain why you are not getting a total on the tape. Try the following example from the manual exactly as shown, and let me know if your tape shows the total.
  1. Clear the calculator (press [CI/C])
  2. Choose 5/4 rounding (press [5/4] until "5/4" displays)
  3. Choose add mode (press [DEC] until "A" displays)
  4. Choose cost-sell-margin mode (press [B-T] until "B" displays)
  5. Turn printer on (press [PRINT] until "PRINT" displays)
  6. To calculate: $12.55 + $15.75 - $5.30
  7. Key in: 1255 [+] 1575 [-] 530 [=]
  8. Tape shows: [0. C] ... [12.55 +] ... [15.75 -] ... [5.30 =] ... [23.00 *]
Apr 07, 2011 | Office Equipment & Supplies
How to tune channels first time when you purchase a new Sony Kdl 32EX600 LED tv?
Hello
Do connection to the antena if you wants to set the TV auto tuned.
During this initial setup, you can perform the following:
1 Select the language for the on-screen display text.
2 Select HOME or Retail mode. [Here you have to select "Home" mode if the set displays "Retail"
3 Connect cable or antenna, then select OK to run Auto
Program
• If you have cable and antenna available, please connect cable first.
• IMPORTANT: Auto Program is only effective when cable or
antenna is connected. If you cancel Auto Program before completion some channels may not be
available.
4 Auto Program will scan for available channels from the signal source directly connected to
the TV's CABLE/ANTENNA input and may take sometime to complete the process. Follow
the help text provided on the screen to run Auto Program.
OK.
Feb 23, 2011 | Sony KDL40EX600 TV
No channels found with automatic channel search
You may need a new antenna.  Go to www.antenna.com for info and help.
May 30, 2009 | RCA Analog (RCA) to Digital (VGA)...
Auto Search for Local channels not responding
Hi elmergdavis,
Check and make sure your tv is set to CABLE and not to AIR or ANTENNA. This setting is usually just above the Auto Search utility on the meNU.
Let me know what you find and I can provide further assistance.
Lone99star
Jan 29, 2009 | Vizio GV42L 42 in. LCD Television
Pioneer SIR-PNR2 SIRIUS Radio Receiver Logo
391 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
T-Comtech Repairs
T-Comtech Repairs
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
