Washer stops spinning in the middle of the spin cycle
Sorry, I don't have a dependable MayTag. I have a GE Washer (Model #WPSF4170W0WW) and it has been working wonderfully until last week. Now, after spinning for about 5 to 10 seconds, the tub lurches sideways and stops spinning. I know it is not the belt, because we just replaced it and the problem still persists. Any suggestions??? Thanks loads!
No, the water does not come on. It is not a balance problem because it happens regardless of the size of the load or the wash cycle selected. Thanks for trying! Any other thoughts or suggestions?No, the water does not come on. It is not a balance problem because it happens regardless of the size of the load or the wash cycle selected. Thanks for trying! Any other thoughts or suggestions?
soccermom93 here again. I investigated our washer problem a bit more and it may not be just a spin problem. The washer will complete an entire cycle, but it will only agitate or spin for 5 to 7 seconds at a time; it will sit idle for about 3 minutes in between short agitations. Could this be a problem with the clutch or the timer??? Thanks!soccermom93 here again. I investigated our washer problem a bit more and it may not be just a spin problem. The washer will complete an entire cycle, but it will only agitate or spin for 5 to 7 seconds at a time; it will sit idle for about 3 minutes in between short agitations. Could this be a problem with the clutch or the timer??? Thanks!
AnonymousMar 25, 2014
had a heavy load washer stopped spinninghad a heavy load washer stopped spinning
You can't post conmments that contain an email address.
Re: washer stops spinning in the middle of the spin cycle
Doe,s the water come on when it stops, it may have something to do with the balance of the washing load, if the water comes on it,s trying to rebalance it self.
Apr 16, 2012 - When the washer enters the spin cycle but does not start to spin, you will need to see if there is ... West Los Angeles Washer and Dryer Repair Service ....After the water has drained, the spin cycle will start. .... Drive Motor, GE, Maytagwashing machine won't spin, spin bearing, washing machine clutch worn ...
My washing machine will wash but the spin cycle will not spin or drain the tub what do I do to repair that? By Shelly H. ... Question: Washer Stops After It Fills for Rinse Cycle and Does Not Spin. By henryj ... Our GE washer will not spin when it has a load of clothes. It washes .... I have a Frigidaire stackable washer and dryer.
? 3:56
https://www.youtube.com/watch?v=_8myOfPzGfM
Aug 4, 2012 - Uploaded by Brad Hyman
My washer did not spin but the belt drive worked to agitate the ...How to Fix a Washing Machine That Does Not Spin (Fast and Easy) - Duration: 8:45. ... Washer Top Load Not Spinning - Repair & Diagnostic- GE, General ...Missing: dryers
DSLReports
Aug 5, 2007 - 19 posts - ‎8 authors
Forum discussion: We have a Maytag Neptune front-loader washing machine that ...the drain/spin cycle after a wash even though the timer continues to ... related circuit board failure" their Neptune washer will lock the door, turn on the ... then will either not start tumbling or will stop operation mid-spin cycle.
May 13, 2013 - The absolute first thing to do to your washing machine that will notspin or drain (whether it. ... I was so fed up with the machine sometimes refusing to spin or drain the .... I just did a load and it stopped midcycle with e and f error codes.... I tried different cycles but all that happens is the door lock engages ...
? 8:30 https://www.youtube.com/watch?v=IEr9A7uhdN8
Sep 6, 2013 - Uploaded by ApplianceVideo.com
Repair your Kenmore Top Load Washer suffering from these following issues: Will Not Advance Past Rinse ...
The belt turn the pulley, but the height of the pulley is worn out so it didn't push up a mechanism to release the brake and to engage with the clutch to make the spin.
You have to takethe shaft out to study how it works then it makes sense on what I 'm talking.
The pulley cost only $11 but it is a major laboring exercise. It is a good learning to have hands on to this problem. Good luck on replacing the pulley.
Could be dirty bearings. As long as it is still spinning, it is nothing to worry about. If it suddenly stops one day, it is probably frozen bearings or the brushes in the motor.
well, you might have to get a new washer. It sounds like the control circut is going out and the door switch is also gone. it would cost about the same as a new washer. sorry.
