I need to change the video card in a Gateway desktop computer. Where is it located and how do I change it?
  • Computers & ... Master
  • 19,110 Answers
Turn off the computer, but leave it connected to the wall socket. Remove the case by removing the screws that you can see at the back of the computer which are obviously holding the case, as opposed to power supply unit etc. The video card will be fixed vertically to the motherboard. You can tell which card it is because it will have the connecter that goes to your monitor on the outside of it. There is usually one screw to remove it. Lift the card out.
Touch a bare part of the case to remove any static electricity in your body (this is why you leave the power cord connected as the case is earthed). Remove the new video card from the packaging. Press it firmly into the slot. Tighten the screw, refix the case.
There are numerous online tutorials with pictures. Just Google "replacing video card"
Posted on Oct 12, 2010
USB 3.0 upgrade
You might need to upgrade you graphics card.
USB 3.0 is the newest connection port upgrade, arriving on the market in 2010.
The cable port connection is far superior to the USB 2.0 port, as it is able to transport up to 5 gbps (gigabits per second), instead of the previous version's max speed of 480 mbps (megabits per second).
However, most computers do not yet have this connection port installed, in which case you are left to upgrade your own computer system to the newer, faster connection method.
Turn off your computer, then disconnect all of the cables running into the computer.
Remove the Phillips screws from the back side of the computer.
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL.
http://www.kitchentablecomputers.com/static.php - rules
Only work inside the computer case when the power has been switched off and disconnected. Never open the power source.
Some of the below steps recommend removing physical parts within the computer.
While in the computer it is highly recommend that you be aware of ESD and its potential hazards.
This unlocks the case, allowing you access to the interior of the system.
Slide open the computer case.
Inside the middle is a longer circuit board.
This is the motherboard of the computer.
On the back side of the motherboard, facing the rear of the computer, are PCI card slots.
These allow you to install additional hardware onto the computer.
Slide the USB 3.0 connection port into one of the open PCI card slots, then push down the plastic levers along each side of the slot to lock the card into place.
Close the computer cover, then tighten the Phillips screws and reattach the cables.
Power on the computer, then insert the driver installation CD into the disc drive of the computer.
Once the installation wizard loads, follow the prompts of the wizard to install the drivers.
Restart the computer once finished and the USB 3.0 connection ports are ready for use.
http://www.pcworld.com/article/186566/usb_30_finally_arrives.html
Compatible graphics cards for Gateway Computers
Just as a processor handles data and a sound card outputs sound, your computer's video card is responsible for processing graphics and displaying them on your monitor.
The video cards manufacturers build into computers typically have enough power for the average user, but it may be necessary to upgrade your video card for better performance in games or graphics heavy applications.
Understand which types of video cards are compatible with your Gateway computer and learn about all your options.
PCI Express Graphics Cards
Many newer Gateway computers have a Peripheral Component Interconnect (PCI) Express slot in which you can add any PCI Express compatible video card.
These devices range from budget cards suitable for everyday tasks to high end models for gaming that cost hundreds of dollars.
AGP Graphics Cards
Older Gateway computers likely have an Accelerated Graphics Port (AGP) slot for AGP compatible cards.
The AGP bus provides sufficient bandwidth for high performance graphics cards, but the technology is no longer in use and AGP cards are difficult to find.
PCI Video Cards
Nearly all Gateway computers should have at least one PCI (Peripheral Component Interconnect) slot regardless of age.
This slot has enough bandwidth to support a wide range of peripherals like sound cards and modems, but is not suitable for high end video cards.
You can find a number of low and mid-range cards for PCI slot computers, however.
USB Video Cards
USB video cards are also compatible with Gateway computers sporting USB 2.0 or USB 3.0 ports.
These external cards sit outside the computer and allow you to connect additional monitors to your system.
They are a good option for people who feel uncomfortable working inside computers.
http://www.pcmag.com/article2/0,2817,2371083,00.asp
How to buy a video card
http://support.gateway.com/us/en/support/default.aspx
Gateway Support
Upgrade My Video Card on My Gateway Desktop
Gateway desktops are affordable computers, but they often do not come with top-of-the-line video cards.
Computer games may run slowly or not at all on your Gateway desktop.
One way to solve this problem is to upgrade the video card.
Video cards come in PCI, PCI-E and AGP interfaces, so you should be able to find a video card upgrade no matter what Gateway desktop model you have.
Click "Start" and right-click "My Computer."
Select "Properties" from the menu that appears.
Go to the "Hardware" tab.
Choose "Device Manager."
Click the plus sign next to the Device Manager entry listed "Display Adapters."
Find your graphics card in this list.
Double-click it.
Go to the "Drivers" tab and click "Uninstall Drivers."
Click "OK" to confirm the uninstallation process.
Shut your Gateway desktop down.
Pull the power cable out of the back.
Look at the back of the Gateway computer tower for screws on the right side panel or on top of the case for a cover release handle.
Nov 29, 2013 | Gateway DX4200-09 PC Desktop
Gateway GT5040 Graphics Card
This model Gateway desktop computer has a built-in video card.
Connect the monitor to the Gateway motherboard video port and the boot up and go into the BIOS and select disable the built-in video.
Shut down then connect the monitor to the 8800GTX video card and boot up the Gateway computer. The video should then appear in the monitor.
Feb 14, 2013 | Gateway GT5040 PC Desktop
I have a Gateway DX210S Desktop Computer. I want to install a video card. What would you recommend?
Your computer has a One PCI Express ×16 slot so you will be able to use most modern video cards. Depending on your budget and needs (what you're running with the card) there is a large variety from which to choose. Here is a helpful link in guiding you to the right choice to meet your needs and your budget.
http://www.tomshardware.com/reviews/best-graphics-card,2964.html
Jul 14, 2011 | Gateway DX210S PC Desktop
My desktop gateway 3 series does not have a video card.....I would like to add one....is it hard to do so ??I want to buy a geforce 9600 or greater...
It is not so difficult as it seems to be.
First ensure that your computer meets the system requirement for installing a particular Video Card. You can get these details on the box of that card.
Once you are ready with all the details and the compatible card, follow the instructions as under:
  1. Turn off your computer and disconnect the power chord
  2. Open the Cover of your computer Tower.
  3. Disconnect the monitor cable from the Onboard VGA
  4. Locate the compatible card slot.
  5. GEForce 9600 would require a pci express slot
  6. Match the notch on the card with the Card slot and insert the card with a slight push.
  7. Fix the card to cabinet with a screw on top
  8. Connect the Monitor cable to the newly installed Video card
  9. Close the cover
  10. Connect the Power cable
  11. Restart the computer
  12. Your operating system will detect the new Video card and prompt you for drivers
  13. Installed the necessary drivers from the CD provided with the Video card
  14. Finish the installation and reboot the system
That's it you have a new Video card installed !!
Please let me know if you need any further help in regards to this.
Thank you for choosing Fixya
Oct 12, 2009 | Gateway GT5220 PC Desktop
Video card upgrade for Gateway GT4024
Try looking up for Updated drivers at Gateway for your Computer. Also find out what video it's using (ie. NVidia, Radeon, etc.) Many times the Video Card maker will have the latest updates for video cards before they get to the computer maker.
Jun 10, 2009 | Gateway GT4024 PC Desktop
Just a simple question
Open the desktop and wherever the monitor plugs into just follow that on the desktop. It will either be onboard video (on the motherboard) or a separate card.
Either way you can always change the video card.
You just need to make sure it's AGP 8x
That's what your board supports.
Best of luck!
Feb 27, 2009 | Gateway 614GE PC Desktop
How do I change the video card in my 610XL PC?
After the side of the case is opened and the computer unpluged and the video to the monitor unplugged, if it has a card already installed , remove the screw holding the card down then pull the old card straight up out of the card slot. Align the new card that you purchased , pushing it straight down into the slot. Install the hold down screw. Reinstall the side . Install the software after hooking  the computer and monitor up.   If you don;t jknow which type of card ,down load a manual and maybe even further instructions from the weblink I provided.
Below it the Gateway support center for your model. All you have to do is to put in your 22 digit serial number.
http://support.gateway.com/support/drivers/dlcenter.asp
Feb 16, 2009 | Gateway Media Center 610XL (610XLMDIA) PC...
Computers & Internet Logo
48 people viewed this question
David Payne
David Payne
