Question about GE Dryers
Dryer will not heat up...it will spin and go through the cycle but it does not heat up
  • GE Master
  • 43,501 Answers
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Posted on Oct 12, 2010
How to fix dryer that will spin but not dry
STOPS MID CYCLE AS IF AROUND 20-30 MINUTES? IF SO U MAY HAVE BAD MOTOR WINDINGS? OH OH, CAN CHECK HEATING ELEMENT AND THERMOSTAS WITH A MULTIMETER FIRST
May 12, 2014 | Frigidaire AGQ6700F / AGQ6700FE Gas Dryer
Dryer wont stop buzzing
follow this steps and fix it. God bless you
Timer
The timer could be the problem. To check this, turn the timer to a timed cycle say 30 minutes or so then time it. If in 30 minutes the timer hasn't moved and the dryer is still on, the timer is bad and need replaced. If in 30 minutes the dryer is off, the heating element is your problem
Heating Element
This is the most likely cause for some dryers timer not advancing. Some dryers have two heating elements and if one goes out the timer will not advance if you use it on an automatic cycle but you will still feel heat inside the tub. replace the heating elements
Jul 09, 2013 | Dryers
Whirlpool dryer is not drying properly. Have to go through a couple of cycles to dry clothes.
2 things are needed to dry clothes. 1 is good air flow. Check to make sure that the dryer vent is not clogged or partially clogged with lint. Also make sure there are no kinks in the vent hose. With the dryer running you should feel good air flow blowing out of the outside house vent. The 2nd thing a dryer needs heat. Check to see that the dryer feels warm to hot when you reach in to tough the clothes. It is possible that the heat element has partially failed. Another thing to investigate is how well the laundry machine is spinning out the water in the spin cycle. This spin cycle is used to get as much water out as possible prior to placing the clothes in the dryer. The wetter the clothes when they come out of the laundry, the longer it takes to dry them.
Oct 01, 2010 | Whirlpool Dryers
Model # LEW0050PQ - The dryer heats and runs for designated cycle time, however does not spin. Will spin if you manyally "push start" it however will get stuck when cycle spin reverses. HELP!
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer is not Turning
Dryer Repair - The
heatman101
Jun 25, 2010 | Whirlpool LEW0050P Electric Dryer
GE spacesaver stack washer & dryer: The
the dryer won't heat up. everything else works. the drum goes around with clothes in it. it just won't heat up .
Jan 03, 2010 | GE Spacemaker Washer and Dryer Electric...
Maytag Dryer Cycle not Turning
if ther is heat, and the drum is spinning, the dial/control mechanism is faulty
Aug 08, 2009 | Dryers
The heating compenent works, but drum won't spin
Have you checked the belt? That's generally the problem when a dryer stops spinning.
May 19, 2009 | Whirlpool LEQ9858L Electric Dryer
Dryer won't heat
If it is an electric heater that means that either the heating element,or the thermistor , or the cirrcuit breaker connecting the element mustbe replaced.
You find diagrams and replacement parts here, just enter the model number.
See also following suggestions from repairclinic :
There's no heat.
How Dryers work
Find a part for your Dryer
Oct 14, 2008 | Malber WD1000 Front Load Washer/Dryer
Dryers Logo
48 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
