Question about SanDisk Sansa e260 MP3 Player
My mp3 player port
I broke a piece of metal in the sansa mp3 player port is there a way to fix it. or is there a deskport charger for the battery inside it.
  • 8,596 Answers
Ohhh - you broke the port on the mp3 player itself - must be replaced - cannot be repaired for less than the cost of a new Mp3 player.
The battery can also be charged using an AC adapter (not included) or a car
adapter (not included) and you will be able to play your device while
charging with one of the adapters. The battery will reach approximately 70%
charge in 2.5 hours and full charge in about 3.5 hours.
-Tha Mp3 Doctor
Posted on Jun 07, 2008
The battery is not charging
You can try and reset the player. resetting a Clip player: 1. Slide and hold the Power switch up for approximately 20 seconds. 2. Release the Power switch. 3. To turn the player on, slide the Power switch up then release instantly.
Some things to check for when your player does not act like its taking a charge.
USB Cable Make sure that the USB cable is properly plugged in and use the original cable that came with your player.
Computer in Hibernation mode Make sure the computer isn't entering hibernation or sleep mode while the device is connected. The computer must be ON in order to charge your player.
USB Port 2.0 Make sure the player is connected to a USB 2.0 port (1.1 occasionally causes charging problems).
USB Port location Try plugging into different USB ports (i.e. USB port in the back of the computer); occasionally the front USB ports have limited power to charge up the device.
Battery Make sure the battery is fully charged. It takes approximately 3 hours to fully charge the battery.
Latest firmware Depending on what Sansa player you have, make sure it's up to date with the latest firmware.
AC charger (optional) AC chargers (sold separately) have a 500-1000 milliamp max output, which provides much better charging ability than a USB port.
I have some tips posted here on MP3 players and their problems. Connection problems MP3 player not found by computer
SanDisk Mp3 Player Frozen
Dec 25, 2010 | SanDisk Sansa Clip MP3 Player
My fuse wont charge at all. i bought a new charger and still get no charge
USB Port 2.0
USB Port location
Battery
Latest firmware
Depending on what Sansa player you have, make sure it's up to date with the latest Firmware.
AC chargers (sold separately) have a 500-1000 milliamp max output, which provides much better charging ability than a USB port. These accessories are available at SanDisk web site.
Dec 04, 2010 | SanDisk Sansa Fuse MP3 Player
My sansa mp3 will not charge on my computer it just drains the battery instead. I have tried rebooting my computer but it still will not charge.....help I miss my music !!
Not all computer USB ports put out enough current to charge the battery. If you're plugging the Sansa into a USB hub, try plugging it in directly. If there's another USB port available, try that.
If that doesn't work, you may have to get a separate USB charger, as used for some cell phones.
Also, bear in mind that when the Sansa is connected to a computer, you can't listen to your music on it.
Oct 21, 2010 | SanDisk Sansa e260 MP3 Player
How do i charge the battery for my sansa
Plug one end of the supplied cable into the bottom of the Sansa, with the Sansa logo on the cable facing up. Plug the other end of the cable into a computer's USB port or a USB charger (such as you might have for your cell phone). If the Sansa is charging, you'll see the battery gauge cycle from right to left.
Aug 30, 2010 | SanDisk Sansa e250 MP3 Player
Does not charge
Below are some things to check for when your Sansa player does not charge..
USB Cable Make sure that the USB cable is properly plugged in and use the original cable that came with your player. Also try ports on the back of your computer, these ports have more available power. Some computers have limited power to charge up the device...
AC charger (optional) AC chargers (sold separately) have a 500-1000 milliamp max output, which provides much better charging ability than a USB port. These accessories are available on our online store.
Jun 08, 2010 | SanDisk Sansa Fuse MP3 Player
Will not turn on.
It's likely your battery is flat. These devices are designed to run only from their internal battery. If the battery is flat, it won't turn on. To charge the battery connect your charging source (USB port or wall charger). Turn the player on with the mechanical swich. Next hold down the play button for more than 4 seconds. The player will turn off and begin to charge. After about 6 hrs the battery will be full and you can use the player.
Mar 21, 2010 | SanDisk Sansa Fuze MP3 Player
My mp3 will not charge
Eh, probably keep the needles well stowed in the future, and a silicone plug (if you have some spare all-silicone caulk...) in the port at the Sansa's base. You can of course repair or replace the socket; the easiest way is to find the wiring correspondence on the charger cable to the USB port (using a DVM in continuity test mode...and needles, but little force) and concentrate on restoring the position of those contacts so it recharges, epoxying things into place.
Try posting a (link to a) photo of the port, if that's easy for you.
Using a charger for the battery that has you unscrewing it often sounds unsettling, but of course you can. Interstate Battery and such can probably let you on to what they use (it's probably what I see on eBay for $40ish when I search for Li Polymer battery charger .
The low-cost way is to look at the charger descriptions at linear.com (e.g. http://www.linear.com/pc/productDetail.jsp?navId=H0,C1,C1003,C1037,C1078,P9551 or http://para.maxim-ic.com/search.mvp?fam=batt_chrg&hs=1 ) and buy that or a similar product and support components from an components vendor like Jameco.com or Electronics Goldmine, or a local store that has those things, building it to plug onto a spare USB header or port on a computer. You just want to match the charger type to the battery chemistry (LiMH or Li____ will be on the battery as a hint) and rely on the chip to handle all the charging current the smallish battery can take on.
Jun 02, 2008 | SanDisk Sansa e260 MP3 Player
Charger
Your USB port must be repaired. In the meantime, hopefully, your computer has another USB port that you can use. Battery is a replaceable lithium ion rechargeable battery. There are battery chargers that you can connect to wall outlets - the type that plug into the computer would probably require that you plug it into the USB port, which you said is broken - so that's a no-go. There are multiple vendors for battery chargers - one possibility is http://www.greenbatteries.com/
-Tha Mp3 Doctor
My Mp3 player cant charge
No - I know you may rate me poorly for this. But there is definitely not a wireless charger for this - i'm not guessing - it's a fact.
May 30, 2008 | SanDisk Sansa e260 MP3 Player
Wont turn on
I don't know if this applies to the Sansa for sure or not but many MP3 devices and smartphones if completely dischard will not charge back up via usb to computer, you have to use a wall jack charger. This is true for the Motorola Q and other smart phones I know for a fact, also the Apple Ipod Gen 5 has had some issues with charging after complete discharge of the battery. Try a wall charger if possible. I don't know much about the sansas.
Jan 07, 2008 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e260 MP3 Player Logo
91 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
