Question about Sony PlayStation Portable (PSP) Console
When I turn my psp on, it starts to ckick. The Laser is not moving, and it looks like it is skipping in the track. The laser still works, but the UMD is not reading. The UMD worked on my firends psp but not on mine. All it does is make a clicking noise.
    Problem Solver:
  • 11 Answers
Man it sounds like your umd laser is been broke by getting hit by somthing. take it and return it
Posted on Jun 01, 2008
Hey there i bright a psp and its not reading the games wat can cause that???
Hello
Switch on on your PSP and remove the UMD that might be inside
When you open up the UMD door and look down inside you will see the Laser assembly.
If you look to the left there is a black tab that sticks up, this tells the PSP that there is a UMD in the drive.
If you press this down with a small probe, you should see the disc motor spin and the laser light up red (do not stare directly at the laser)
Inspect to see If the Motor is spinning or not.is it moving slightly?
Take the parts out and see if there is another problem also.
If the laser is not lighting up then it could be the laser,check the cables to the PSP and see if there is a bad connection.
If both are running well then put a disc in and get your ear up close so you can hear what is going on in there.
On a working PSP you will hear the disc start to spin up, then you can hear the laser start to twitch, followed by the laser motor moving the laser down the rails.
Can you hear the disc spin up? If not I would take the disc out again and press the switch with your probe again. if the disc motor is spinning again, look around to see if the metal housing is obstructing the disc when you put it in.. there could be too much pressure for the disc to spin freely
Can you hear the Laser focus? This might be hard to hear it will sound like a little tick. If you cant hear it tick I would move on and inspect this internally later.
Can you hear the Laser move down the rail? This will be a smooth sound of the gears, it should not be a really clicky sound.
If you can't hear it move down the track OR it is very clicky do the fpllowing;
You should open the UMD door and carefully manually move the laser to the right side of the assembly.
Use a sharp THIN probe to manually move the WHITE gear under the metal housing.
try and scrape the gears themselves to make sure there is no gunk or debris in the gear..
After this try and see if it is reading UMD again.
If none of this is working, it is time to open your PSP unit
If you are able to find out what's wrong from the troubleshooting steps above you can replace the problem by
Replacing the UMD, Assembly,Replacing UMD Disc Motor,Replacing UMD Laser Motor or by Replacing PSP Motherboard
Dec 15, 2010 | Sony Video Game Consoles & Games
My problem is my umd disc is not working in the psp.
I have seen many PSP's stop reading UMD discs and for the most part they are repairable with the least amount of opening your PSP.
First we will do some trouble shooting with what might be wrong with your PSP unit.
About 35% of the time I find that there is something stuck in the UMD gear. It is different every time, sometimes its a piece of dust, plastic, soda, and even hair.
Another 25% is the Disc Spinning motor. This will not let The disc in the UMD spin.
About 20% is the Laser motor, this might be hard to spot since it could be something in the gears.
About 10% is the actual laser itself. It will not focus the laser to read the UMD disc.
The Last 10% is the Motherboard. This is the worst outcome, since there is very little what we can do but replace the motherboard.
So first what we need to do is find out what is actually wrong with your PSP.
With your PSP in hand.
Turn on your PSP and remove any UMD that might be in there now.
If you open up the UMD door and look down inside you will see the Laser assembly.
*** CAUTION DO NOT STARE DIRECTLY AT THE LASER ***
If the Motor is not spinning. is it moving slightly? Maybe a little twitch?
I would lean more towards the bad motor problem BUT would not say for sure, I would recommend that you take the parts out and see if there is another problem also.
If the laser is not lighting up then it could be the laser, I would try and check the cables to the PSP and see if there is a bad connection.
If both are running well then lets put a disc in and get your ear up close so you can hear what is going on in there.
Can you hear the disc spin up? If not I would take the disc out again and press the switch with your probe again. if the disc motor is spinning again, look around to see if the metal housing is obstructing the disc when you put it in.. there could be to much pressure for the disc to spin freely.
If you can't hear it move down the track OR it is very clicky follow this.
It would look like this if your UMD door was off.
Use a sharp THIN probe to manually move the WHITE gear under the metal housing. It is quite hard to see it in the photos so I put a red star around it.
I usually try and scrape the gears themselves to make sure there is no gunk or debris in the gear.
This fixes it about 35% of the time.
If none of this is working, it is time to open your PSP unit Or send it in for repair.
If you know what's wrong you can replace the problem here
Replace UMD Assembly
Replace UMD Disc Motor
Replace UMD Laser Motor
Replace PSP Motherboard
Dec 03, 2010 | Sony PlayStation Portable (PSP) Console
I have the same problem
i had that problem once while i was trying to rip mp3 tracks it only rips wma's just check that you are only doing wma's plus it will not rip copy protected cds
Jun 30, 2009 | Sony PlayStation Portable (PSP) Slim...
My PSP cant play any games any more
update your PSP's firmware to 5.00 -thats my psp firmware
Jun 14, 2009 | Sony PlayStation Portable (PSP) Console
Game loads then freezes and psp turns off by itself
you have turn off the psp then take out battery then look at laser then move it to the right and put the game in then go to auto start if on turn off then go to ad hoc mode change channel to 6 reboot it
May 10, 2009 | Sony PlayStation Portable (PSP) Console
It won`t read my game
First we will do some trouble shooting with what might be wrong with your PSP unit. About 35% of the time I find that there is something stuck in the UMD gear. It is different every time, sometimes its a piece of dust, plastic, soda, and even hair.
if you need more infomation please just ask ... Symo02
Oct 19, 2008 | Sony PlayStation Portable (PSP) Console
I can not get my PSP to bring up games
open the door to the psp and turn it on. hold down a little black switch on the left side of the disc holder near the spindle. if the laser moves up and down and flashes red than the laser is fine. if the spindle spins ups a couple of times its fine. If both are functioning you need to take a qtip and move the laser all the way to the outside of the track b/c it is stuck and can't read the disc properly. let me know if you need more help. thanks
Aug 05, 2008 | Video Game Consoles & Games
PSP disk drive
your laser is either broken or unaligned. you have 2 options:
1. send it back to sony
2. or try and clean the laser track, remember the gear under the track also needs cleaning.
Mar 09, 2008 | Sony PlayStation Portable (PSP) Console
HELP PSP WONT READ UMDS!!!!
hi i just fixed my sons it wasnt reading umd's every thing else worked so have a look were the threaded rod runs threw the laser, in the centre at the back of the laser there is a little tab with a stamped groove in it make sure the laser is up against the disk spinner when turned off push the tab against the threaded rod hopefully it has seated (you ned a good light plus i used long metal twesers to push it down, easier to see on 2000 model than the fat one but you can manage good luck)
PSP GAME
My guess is you used a regular Q-tip to clean the laser lens and it left cotton hairs on the lens. I like to use the foam swabs. You can press the little swtich sticking up inside the UMD compartment. It is on the left and back about 1 inch. When you press it you should see your Laser light up and the spindle spin. This will tell you if the laser and spindlge work. You can physically move to Laser over to the right a few clicks and put the UMD back in it and look to see if the laser moves left and right. if it still does light up, spin the spindle and move left and right, then it probably will need its lens cleaned.
Jan 23, 2008 | Sony PlayStation Portable (PSP) Console
Sony PlayStation Portable (PSP) Console Logo
Top Sony Video Game Consoles & Games Experts
Iron
Iron
Troy Gorman
Troy Gorman
Jonathon summesfield
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
