Question about LG Computers & Internet
Hi my new monitors colour isnt working properly and when i turn my computer on it says found new hardware i dont have the install disk how do i fix this
    Scholar:
  • 135 Answers
Find the model no on back and go to http://www.lg.com/us/support/product/support-product.jsp
if its a crt pick it if a LCD pick model drivers are here for all models
Posted on Oct 11, 2010
My acer pc is not booting properly
there maybe faulty installed hardware on your PC. remove those hardware like sound & video card (if any), PCI modem, CD/DVD ROM, etc. turn on your PC without those hardware & if/ there's nothings change?..it means that there is no wrong with your PC's hardware. turn the PC off, re insert IDE & power supplies cable of your hard disk drive to make it sure that the HDD is properly connected & being detect by the system. remove the memory card and clean or wipe the connector surface of the RAM with tissue paper. (change new memory card if needed). check the mother board C-MOS 3 volts battery if it is volts sufficiently .turn your desktop on & wait for good results.( Reformatting your OS is also recommended.)GOOD LUCK!
Jul 09, 2014 | Acer X193W LCD Monitor
Laptop
Hi are you sure its not installed and just needs the lense cleaning if not then try this.
1 select start
2 select controll panel
3 select add hardware
4 let the laptop scan for hardware connected
5 when finished look down list untill you see cd dvd you want to use
6 select this if you have the disk then when it asks if you have disk check the box for you have.
Then follow instructions then it should install the correct setting from the disc you have if dont have disk then dont check box and then it will search the web for compatable software.
Let me know how you get on and if you need further help
Jan 08, 2008 | Toshiba Satellite A105 Notebook
I have the VE278Q which is connected by display port, every time i turn off my computer and then turn it back on the monitor can't be found, I have to unplug the display port cable, unplug the monitor,...
when you say monitor can't be found did you mean the monitor has no reactions when you turn on your pc?
here are some test you may need to do to know which part is faulty
1. Turn on your computer, did it display the monitor's logo on screen? When it does monitor is good, when only blank screen it could be the vga cable or the video card.
2. See if the led indication lit. When it lit to steady green, it's good signal is coming in from the video card. It should be followed by screen display. If no display it could be the backlight inverter lamp busted or faulty inverter board. When lit green then turns red, no signal coming from the video card. Check vga cable if fix properly to both monitor and video card. Or may need to reseat properly connection of video card from the motherboard. If no led indication lamp, then monitor is dead. Check ac power cord for continuity using multitester. Check power supply section in the monitor, replaced bulged or blown capacitor with exact value, this components were the first to get affected when lcd monitor failed o turn on.
3. When computer was turned on got display and then monitor turns black, go check the vga cable, Fix the connection properly or may need to replace it with new one.
4. When no signal appears or display blank screen after logo, then check video card. First remedy is to disconnect it the reseat properly to the motherboard. If this have no effect change your video card.
go follow these steps and let me know which is closely to your problem so I can give you a good advise.
Jan 30, 2011 | ASUS LCD Monitor
No sound on my pc!
step 1: check with the speakers on another computer to ensure the speakers are working fine.
1. Insert the CD-ROM titled 'Fujitsu Technology Solutions Drivers & Utilities CD' that came with the computer into the DVD tray and close it.
2. The Drivers & Utilities CD will start automatically.
3. Click on 'Driver Installation' option.
4. Click on INSTALL.
5. After the installation process the computer will automatically re-start. If not, for safety reasons (to not misinform/corrupt the information on the registry) restart the machine manually (Start Menu - Shut Down).
If you receive a message saying 'Found New Hardware Wizard' during the Drivers installation (Automatic recommended), ignore it and leave the Drivers & Utility CD to finish the installation. The D+U Setup is will detect the computer's hardware (it will not detect the drivers of any external devices you may have) and install the drivers needed. After you re-boot the machine you may get the Found New Hardware Wizard again, this will be your Monitor being detected, follow the on-screen instructions to install it properly (if you have a driver's disk, provided with your monitor or any other external device that you have connected, use this when prompted)
Jul 01, 2010 | Fujitsu Siemens SCALEO 600 (FSP:83C005617)...
I am unable to hear anything from my pc not even the click of the mouse
Please check following
1. Check You have pluged the speak output pin properly.if not put into the output socket.
2. Click on my computer property \advance\hardware and check any red colour showing for sound driver not detected. if yes the you can install the driver properly
3. Check your speaks are working properly, if not change and buy new one.
Thanks for your question, if this answer is helpful ,please click on rating.
Feb 26, 2010 | LG Studioworks 57M Monitor
My sound dont work
You need to install the correct driver for your Sounds, that disk might came with your motherboard. Thanks
Aug 15, 2009 | Audio Players & Recorders
Hard disk problem
neither, the new disk is in need of a driver to operate it it should be in the box with the drive
for some reason it is not seen as plug and play. you could delete it from system in device manager and try plugging it in again. Watch the bottom right of screen FOUND NEW Hware.... Installing new hardware Your hware is ready to use should then show. if that dont occur then the problem is an incompatible new hDD
Jul 28, 2009 | Computers & Internet
Prints light purple instead of grey
I think your Black Cartridge is Empty. Check it and replace it with the new one.
Your Printer is trying to produce Black Colour from your Colour Cartridge with a mix of Cyan, Magenta and Yellow.
Apr 23, 2009 | Canon PIXMA MX850 Multifunction Printer
New hardware might not work properly
Right guys, found the sollution:
Right click on My Computer, Choose Properties from the drop down list, then click on Device Manager.
Down the list, there will be Universal Serial Bus (USB) controlers. If this selection isnt expanded already, click on the + icon next to it.
In the list that pops down, there will be an entry called IPod and it will have a yellow question mark on it. Right click on this, choose properties and then click on update drivers. Follow the install wizard and then voila! It will be installed.
Have fun guys!
Jan 06, 2009 | Creative Labs Zen Micro MP3 Player
I have a creative zen touch and ive installed and un-installed the software needed for it to work properly numerous times but it keeps saying that i havent and that ma zen isnt connected?
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Aug 14, 2008 | Audio Players & Recorders
Computers & Internet Logo
Top LG Computers & Internet Experts
Michael Vincent Cruz
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
